Question about Sony Playstation 3 (PS3) Console
My tv-screen is black. Seems there is no connection from the console. Brand new PS3. I might have used the main power switch when system was not at stand by. Is there a way to reset the system to origional? I have tried to keep my finger at the switch at start up until the second beep - but nu result.
  • cmvb Jan 04, 2009
    Got it for Christmas 2008, worked great for movies and games for a few days, then one day nothing but a black screen when I turned it on. Switched cables and ports into tv, didn't help.  No red lights.
I had this same problem but was finally able to fix it (immediately after I posted about it) by keeping my finger on the button until after the second beep.  I had tried this a couple of times before but it turns out I was keeping my finger on there too long.  Try lifting your finger right after the second beep.  You'll need to have a controller connected via a cable, as well.
We had to choose RESTORE PS3 SYSTEM from the options menu. If you choose this you will lose all saved  settings and data.  My husband is going through the new setup process now.  We tried a couple of the other less drastic options from the menu at first, but they didn't work.  After we chose the Restore PS3 System, it took a minute or two for anything to show up on the screen, but it was our last try before taking it in to a pro, so we tried to be patient let it do it's thing and it eventually came up on the screen.
We only got the system a couple of weeks ago and are very casual game players so it didn't bother us to lose saved data, but it is a pain in the **** redoing the setup.  I just hope this isn't a re-occurring problem.
Hope this helps, good luck.
Posted on Jan 04, 2009
My tv screen is black no connection
Samsung smart tv no picture and sound. Replaced T-CON and Main Board. Same result. Any ideas?
did you change power supply? how many times does light flash (red) you didnt change the power supply did you use a vom on connections?
We Are Here To Help !!!
Donal Deane MCSE,ASE,CPO
Aug 18, 2017 | Samsung Televison & Video
Samsung TV, UN60EH6003FXZA, Black screen, has audio. Replaced t-con board and TV worked fine for 5 minutes, then black wave came across screen. Can replace main board, is the new t-con board ruined?
If the new T'Con too have damaged, surely its main power supply regulator board is faulty. Over voltage to T'Con board. Replace it and the T'Con board. Never switch on the set, without proper fittings to T'Con board. Its protective cover should be fitted before you switch On the set. It acts as a shield as well as a heat-sink to the IC at the T'Con. If you switch On without properly fitted, the IC will overheat within minutes and will be damaged. Keep this in mind next time.
https://electronicshelponline.blogspot.com/
Oct 26, 2016 | Samsung Televison & Video
How do i get my hdmi to work for my ps3 system
Note: How to reset video output settings
If you are attempting to change to an HDMI cable from a different video cable or if the video output settings do not match those required for the display in use, the screen may stay black. If the screen stays black for more than 30 seconds, you may need to reset the video output settings of the PS3.
To reset video output settings:
  1. Turn the PS3 system off by holding the Power button on the front of the console till you see the power light turn red.
  2. Then hold the power button on the front of the console for at least five seconds until you hear a second beep to turn the system on again. The video output settings will automatically be reset to the standard resolution.
[TOP]
HDMI Cable Installation
Interactive Video Tutorial
Click below for an interactive video walkthrough on connecting your PS3 to your television or display device (including HDMI).
alt="Click to play tutorial">
[TOP]
Minimum Requirements
  • PlayStation®3 computer entertainment system
  • SIXAXISTM wireless controller (and USB cable)
  • AC power cord
  • HDMI cable1 (sold separately)
  • TV or display monitor with HDMI port and capable of displaying picture in HD resolution
  • Updated system software installed on your PS3
    Visit PS3 System Software Update to download and install the most recent version.
  • TV "Input" or "Video" channel for the HDMI port
    You need to know the TV "Input" or "Video" channel for the HDMI port on your TV. For instance, if your TV has multiple "Input" or "Video" channels, (i.e., "Input 1", "Input 2", "Input 3", etc.), you will need to toggle through each "Input" channel on your TV until you find the correct channel that displays the HDMI picture. This is important to remember, especially if you do not see the HDMI picture after you connect the cable and configure the PS3 settings. Please refer to the TV instruction manual for more information.
[TOP]
Instructions
  1. Before you begin installation:
    • Turn OFF the PS3TM system using the [MAIN POWER] switch (in the back)
    • Unplug the AC power cord from the electrical outlet
    • Turn OFF and unplug the TV
  2. Connect one end of the HDMI cable into the [HDMI OUT] port on the back of the PS3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
    alt="line drawing of HDMI connection">
  3. Plug in the AC power cord by connecting one end of the AC power cord into the [AC IN] port on the back of the PS3 system and the other end into an electrical outlet.
    alt="line drawing of AC power cord">
  4. Press the [MAIN POWER] switch on the rear of the system. A red light should appear on the front of the system indicating power is available.
  5. Turn on the PS3 by pressing the touch-sensitive [On/Off button] on the system front. The red light will turn green, indicating the PS3 is now turned on.
    Note: The blue light will also appear on the front of the system if you have a disc inserted.
  6. Plug in the TV and turn the power on. The PS3 should detect the HDMI display device automatically. When prompted, "Do you want to output video and audio using HDMI?", select YES and press the alt="X button icon">button. (You may need to press the PS button on the center of the SIXAXISTMcontroller to enable the controller first).
  7. The next screen will ask, "Do you want to automatically switch to the optimal setting?" Select YES and press the alt="X button icon">button.
  8. On the next screen, the PS3 will display the maximum resolution capable on the display (i.e., 1080p). The screen will display, "Do you accept the setting?" You will have 30 seconds to confirm your answer.2 Select YES and press the alt="X button icon">button to save your settings. You have now completed the HDMI installation.
[TOP]
Feb 15, 2015 | Video Game Consoles & Games
My coby lcd tv won't work for my ps3 what wires would I need to make it work
You will need an HDMI cable. Please follow the below instructions.
Instructions
  2. Connect one end of the HDMI cable into the [HDMI OUT] port on the back of the PS3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor. ps3_8_hdmiconnecttv.gif
  3. Plug in the AC power cord by connecting one end of the AC power cord into the [AC IN] port on the back of the PS3 system and the other end into an electrical outlet. ps3_11_connectacpower.gif
  6. Plug in the TV and turn the power on. The PS3 should detect the HDMI display device automatically. When prompted, "Do you want to output video and audio using HDMI?", select YES and press the icn_btnx_color.gifbutton. (You may need to press the PS button on the center of the SIXAXISTM controller to enable the controller first).
  7. The next screen will ask, "Do you want to automatically switch to the optimal setting?" Select YES and press the icn_btnx_color.gifbutton.
  8. On the next screen, the PS3 will display the maximum resolution capable on the display (i.e., 1080p). The screen will display, "Do you accept the setting?" You will have 30 seconds to confirm your answer.2 Select YES and press the icn_btnx_color.gifbutton to save your settings. You have now completed the HDMI installation.
Dec 01, 2014 | Televison & Video
Hi, I bought a brand new ps3 console yesterday and everything worked fine when I set it up. I did not have to change any settings in relation to the display at all and it was perfect when I tried out my...
Hi.
No you shouldn't need a new TV, all you need to do is reset the video settings, follow the guide below >>>>>
  1. Make sure that you have only 1 type of video cable connected between your PS3 and your TV or monitor, an HDMI cable is optimal. If you have multiple video connections the reset sometimes does not work.
  2. Make sure that your TV or monitor is turned on and set to the proper input for your PS3.
  3. With your PS3 in standby mode, turn your console on using the front power button and hold the button down.With the button held down, You will here one beep when the console first turns on, and, after about 4-5 seconds, you will here a second beep. When you here the second beep let go of the button.
  4. If you watch the screen you should see it flicker once or twice and then your system should boot up and go to a screen to confirm your video settings. Simply confirm the settings and you should be able to resume playing your PS3 as normal.
  5. If your system does not boot up and give you the confirmation screen for your video settings, then you should shut the system off and restart the system as normal. This will usually finalize the reset of the video settings.
  6. If your system still is not displaying video then please repeat steps 1-5 again. It is unlikely but, you may have to reset the video 3-4 times before it works with your console. The reason for this is unknown.
  7. The procedure to reset video ,on your PS3, should be complete at this point and you should be back up and running as normal.
NOTES: PS3 "slim" models are always in standby mode when plugged in. PS3 "fat" models must have the rear power switch turned on. If you are only using the composite video cables, then there will be no confirmation screens for your video settings.
Regards.
Jan 01, 2013 | Video Game Consoles & Games
Ps3 remote wont work
you can try to reset the power switch in the back with the ps3 controller connect via the usb cable.
After you turn main switch in the rear on try using the controller's "PS" button to power on the system. If this does not work then power on the console using the button in front then use the PS button to sync....watching the top of the controller for recognition.
IF YOU ARE HAVING A PROBLEM WITH YOUR PS3 THE LAST THING TO DO IS TO TRY AND BOOT INTO DIAGNOSTIC SCREEN AND CHOOSE "RESTORE PS3 SYSTEM" or "REBUILD FILE SYSTEM". This can erase all saved data but is a good starting point for problem solving your PS3 before sending it to me for repair :-)
Nov 25, 2011 | Sony Playstation 3 (PS3) Console
I have a black screen when I connect the HDMI cable. When I connected it originally it worked for about 5 minutes but now I get nothing but the black screen. I tried connecting a different HDMI cable to it...
The main reason of HDMI black screen problem due to HDMI cable may damage and not proper connected to the PS3 console. Please follow below step to troubleshoot PS3 HDMI cables problem:1) Restart your PlayStation 3.
2) Look for loose cables.
3) Try to unplug all cables except the power cord, and plug them back in. If you found out that your HDMI cable is damage, do borrow your friend cable and have a try. If your friend cable work fine, and the black screen error disappear. Then you can buy a brand new HDMI cable for replacement.
Tips 2: If tips 1 not working, you need to go another step deeper by reset your console. Most of the PS3 gamers not aware that Sony actually done include in the black screen troubleshooting method and other HDMI problems in the PS3 manual, you can find it under troubleshooting section - topic "console reset".
If you do it correctly, the console reset fix will allow you to reset back your PS3 to its default HDMI settings without impacting your gamer profile, and other storage data in hard drive.
You will need to perform the following steps:
1. Place your PS3 in stand-by mode.
2. Hold down the touch power button until a series of beeps are heard.
3. Listen for one long beep, followed to two shorter beeps.
4. Release the power button.
5. Follow the instructions on screen.
Jan 11, 2011 | Sony Playstation 3 (PS3) Console
I connected my sons ps3 to our new hd tv and now it wont connect to his tv as it only seems to be using the hdmi output which his tv does not support
Turn the PS3 off and make sure it is just showing a red light,
Then, with the PS3 connected to the TV with the regular (not HDMI) connections, press and hold the power button.
As soon as you see the screen flicker, release the power button.
That should do it!
Jan 27, 2010 | Sony Playstation 3 (PS3) Console
PS3 can turn on, but T.V screen is black
turn power switch on in the back. red light on in the front, hold the power button until system turns back off. this resets all hardware settings. if this doesn't work and the system is ok (green light) then you have a connection problem to the tv
Jul 14, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
250 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
