Question about Hotpoint First Edition FEW12 Front Load Washer
Hotpoint wma12 not draining help please my work clothes are stuck
I have put it on cycles wash, rinse and spin but none are empting the water out well they must be as it has had 3 cycles and the drum isnt full to the top etc
it says prog end but the drum has water in it and the door wont open due to the drum still having water in etc
how would i know if the pump is not working etc
bring back the old fashioned ones where you click it to just spin they were so much easier thanks
  • charlie Jan 05, 2009
    did this
    Hi my wma12 has a filter. Turn all electrics off. Take off the back
    panel at bottom left is a black bendy pipe with a clip on it. Obviously
    drain all water via the hose lower than the washer first. remove the
    clip from the black pipe that connect to the washer this is the filter
    it has a plastic ball inside. Remove all debris inside replace ball and
    reconnect to the washer drum with clip. Hope this works. If not it
    sounds as if your drain pump has died. These are around £16 to replace
    it is the part the outlet hose connects to it is helf on with plastic
    clips and should be easy to replace. Thanks
    definate not just the filter
    so ebay
    310110614596 £10 delivered great price
    Looks easy enought to replace thanks
  • Hotpoint Master
  • 3,463 Answers
You need to check the pump filter which is accessed by removing lower rear panel of washer.
On the right you will see a large black hose, ondo securing clip and remove hose, be careful because there will still be water in it.
Better still , lay hose down into a bowl or similar to drain any remaining water in m/c.
Inside you will see the plastic filter, remove and clean, refit filter and hose, make sure you get it on properly
Test it for leaks, and that should be it.
If it still does not drain then you need to check the pump is o/k.
You can do this by listening or feeling if you can hear the pump going.
Any more info , let me know.
Plz rate my solution.
Posted on Jan 04, 2009
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Aug 15, 2015 | AEG Washing Machines
My Kenmore 500 top loading washing machine wont work right. sometimes it will work and other times it wont. I will put a load in it and sometimes when it hits the rinse cycle it seems like it gets stuck...
for the top loading washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.and the unit top load have drain pump you must be up the drain hose up to 90cm from floor lever to make the water lever is make in normal,the water automatically goes out by drain pump.
and for unbalance most of all top loader have problem in unbalance, the main reason is overload or the type of cloth you wash.
Nov 02, 2013 | Kenmore 24032\24036 Top Load Washer
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
The wash cycle is not working. It doesn't agitate. Then the water drains and starts the rinse cycle. Then the spin. The spin cycle doesn't get all of the water out of the washing machine. Laundry...
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Nov 29, 2010 | GE Washing Machines
Wont adavace after wash cycle like its stuck replying back
Hi just read your posting. The problem appears to be your drain pump is either blocked or faulty.If you would like I can guide you throe the removal of the pump. The reason it does not reach full spin speed is there is still water under the bowl slowing it down.It is impossible to drain the machine by hand completely.Please reply If you require extra help on the pump removal.
Jun 07, 2010 | Fisher Paykel EcoSmart GWL15
I have just run a wash cycle and when it had finished the clothes were still very wet and water was laying in the bottom of the drum. I have tried to do a repeat wash but the machine will not work but...
You have most likely selected by mistake the no spin option coupled with extra rinse  - press again the rinse button to unselect that and put the spin speed at max.
Jan 16, 2010 | Hotpoint WMA50 Front Load Washer
Hotpoint WD420 Washer/Dryer - Not completing cycle
Jun 25, 2008 | Hotpoint Aquarius WD63 Front Load...
Spin/rinse cycle
find tech sheet at bottom of washer and follow instructions for checking motor controller (at bottom rear)
Apr 13, 2008 | Frigidaire Affinity ATF7000E Front Load...
The water will not drain on my first edition wma 10 hotpoint washing machine so does not spin either any clues to where the filter is???????
Most likely something stuck in the pump. Remove front panel and hose that goes into pump. usually you will see the object. if not remove pump and look inside.
Jan 06, 2008 | Hotpoint First Edition WMA12 Front Load...
Hotpoint First Edition FEW12 Front Load Washer Logo
242 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
