Question about Garden
Ryobi tp30. Do you mix oil with the gas? - Garden
  • 22 Answers
SOURCE: what is the ratio of gas and oil mix for a ryobi 31cc trimmer
just use about 3 to 4 ounces of 2 cycle oil per gallon and you should be fine. a little extra lubrication wont hurt it
Posted on May 18, 2009
  • 323 Answers
SOURCE: do you use mixed gas for a ryobi weed eater??
Unless it has a tag or decal on it saying it is a 4 cycle then it uses mixed gas/oil at about a 50:1 ratio. Straight gasoline will freeze the piston in the cylinder in mere minutes.
Posted on May 23, 2009
mattofilms
  • 110 Answers
SOURCE: i just picked up a used ryobi rgbv3100 mulcher
test for spark.
while spark plug is out - put finger over hole see how much compression there is.
If good spark - look for holes in fuel line.
Posted on Jul 06, 2009
wireguy212
  • 1627 Answers
SOURCE: What type of oil goes in the Ryobi 08570 Blower?
You need 2 stroke motor oil or chain saw oil.Mix it according to the lable to make up 50:1 oil/gas mix.
Posted on Nov 07, 2009
  • 183 Answers
SOURCE: is my ryobi cs30 gas only or gas and oil mix
gas oil mix
Posted on Sep 03, 2010
What is oil to gas ratio for a Ryobi TP30 pull start trimmer?
The Ryobi TP30 also has the model number RY52014. This 2-cycle engine uses a 50:1 gas to oil ratio. That means that for every gallon of gasoline, you need 2.6 oz. of 2-cycle engine oil. This information is available on page 9 of the manual. Manuals Lib has the manual for the TP30 trimmer here: https://www.manualslib.com/manual/143217/Ryobi-Ry52014.html .
I hope this helps.
Jan 29, 2017 | Ryobi Garden
My Ryobi 700R "EZ" weedeater smokes excessively.
Check the fuel/oil mix ratio you are using. Some Ryobis use a 32:1 mix and some use a 40:1 mix. There isn't much difference there. To be on the safe side, if you machine is possibly running or tuned a little "lean" I would start off with about 4 oz/gallon oil to gas mix. Use synthetic 2-stroke oil also. Your machine will perform much better.
Nov 27, 2010 | Ryobi Garden
My TP30 Ryobi weed eater turns and stays on while
You have a hairline leak in one of your hoses or a small gasket under primer bulb.
Jul 05, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
What type of oil goes in the Ryobi 08570 Blower? What is the oil gas mix ratio?
Nov 07, 2009 | Ryobi Backpack Blower 25.4cc
How to mix gas and oil ratio
hello. the mix has not changed over the years. it is important however to use ryobi oil. go to any home depot and get the small bottle of ryobi oil that is enough for just one gallon of gas, use new gas fresh from the pump, and enjoy.
Aug 18, 2009 | Ryobi Factory-Reconditioned ZRDS11008...
Do you use mixed gas for a ryobi weed eater??
May 23, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi string trimmer 32.1 what do mix gas and oil or just gas?
Ryobi trimmers I have had use a 32:1 oil mix. Just pick up a little bottle of Ryobi 2-cycle oil and read it to see that it will give a 32:1 mix in a gallon of gas. Pour it into a gallon of gas, and maybe a little fuel stabilizer too, shake it up and you should be good for the season.
May 28, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
153 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
