Magellan eXplorist 400 GPS Receiver Logo
Posted on Jan 04, 2009
Need to know how to get to point a and b which is heavily wooded anp 1200hd feet apart just want to make sure im programing it right
Anonymous
Level 1:
  • Contributor 32 Answers
  • Posted on Jan 21, 2009
Anonymous
Contributor
Level 1:
Answers
32
Questions
Helped
20084
Points
46
Not sure if this helps but you can download the manual from the Magellan site
I need instructions for a wilson &fisher sonoma 10x12 resin wicker gazebo
Let us know if this is the wrong model, please.
The PDF seems to me to show the same model number:
SPECIFICATIONS
Model number: L-GZ815PST-1
12'L x 10'W x 9.8'H
Home
Wilson & Fisher Sonoma Gazebo, (10' x 12')
This item is currently out of stock.
View More Products
No Reviews
Sonoma Gazebo, (10' x 12') 10 feet x 12 feet Sonoma Gazebo Open 10 feet x 12 feet Sonoma Gazebo 10 feet x 12 feet Sonoma Gazebo Silo 10 feet x 12 feet Sonoma Gazebo Closed 10 feet x 12 feet Sonoma Gazebo outdoor shot 10' x 12' SONOMA RESIN GAZEBO SONOMA RW 6 PC SECTIONAL SEATING SET - 37 IN SQUARE FAUX WOOD/RESIN WICKER TABLE 10' x 12' SONOMA RESIN GAZEBO SONOMA RW 6 PC SECTIONAL SEATING SET - 37 IN SQUARE FAUX WOOD/RESIN WICKER TABLE SONOMA RW 6 PC SECTIONAL SEATING SET - 37 IN SQUARE FAUX WOOD/RESIN WICKER TABLE Sonoma Gazebo, (10' x 12') 10 feet x 12 feet Sonoma Gazebo Open
10 feet x 12 feet Sonoma Gazebo Open10 feet x 12 feet Sonoma Gazebo10 feet x 12 feet Sonoma Gazebo Silo10 feet x 12 feet Sonoma Gazebo Closed10 feet x 12 feet Sonoma Gazebo outdoor shot10' x 12' SONOMA RESIN GAZEBOSONOMA RW 6 PC SECTIONAL SEATING SET - 37 IN SQUARE FAUX WOOD/RESIN WICKER TABLE10' x 12' SONOMA RESIN GAZEBOSONOMA RW 6 PC SECTIONAL SEATING SET - 37 IN SQUARE FAUX WOOD/RESIN WICKER TABLESONOMA RW 6 PC SECTIONAL SEATING SET - 37 IN SQUARE FAUX WOOD/RESIN WICKER TABLESonoma Gazebo, (10' x 12')
PreviousNext
This Sonoma gazebo gives your patio star-studded style when it comes to entertaining guests. Featuring a decorative keystone centerpiece, weather-resistant domed canopy, vented double roof and four zipping side panels for added privacy, this gazebo will help you feel right at home. Other Sonoma outdoor furniture collection pieces sold separately.
SKU 810280578
Pin It Email a Friend Print
FEATURES
Scratch and rust-resistant frame ensures durability
4 - Sided zippered netting for protection from bugs
4 - Sided privacy panels for even more protection
Center hook for hanging lights or plants
120 sq. ft. coverage
Pairs with the Sonoma resin wicker furniture collection, (sold separately)
Other accessories and d?cor not included as shown
SPECIFICATIONS
12'L x 10'W x 9.8'H
Material: Steel, fabric, rattan
Weight: 114.54 lbs.
(I tried to upload a copy of the manual in PDF format to FIXYA - it required a category and item and only thing close was a Sonoma car : http://www.fixya.com/cars/p694698-gmc_1999_sonoma/usermanual-7db1393-pdf
http://www.biglots.com/images/marketing/pdfs/810347372.pdf
Jul 10, 2018 • Garden
My HP notebook wont connect to internet unless im next to router. what do i need to do to be able to access internet in another room
what notebook (model
what router,. name and model , endless choices here.
the router can be bad, how old is it, ?
what room, how far.? 10ft, 100 feet? distance matters.
is home wood, or concrete walls or brick walls.
the RF energy is weak and does travel far.
unless only air is between point A TO B.
Ever drive into a tunnel and have radio go dead, same thing happens here.
as you walk , look at the signal strength. see it drop
the lower it goes, the slower it goes.
or you are using same channels are your neighbors.
use the program to learn how to stay off busy channels.
the rounter
insidder 4,
learn how wifi works then play with this magic tool,
I run my channels where others are not.
http://www.metageek.com/support/downloads//
1helpful
I have two stacks of fire wood cut and split. I would like to know how many cubic feet of fire wood did I cut and stack.1st pile is 118x88x23=need cubic feet 2nd pile is 88x23x143= need cubic
I...don't understand. The question answers itself. Assuming no air pockets, you will have (118x88x23) + (88x23x143) cubic feet of firewood.
1.500 sq ft to how many linear ft?
Are you trying to convert 1,500 square feet to linear feet for wood flooring? You will need to know the width of the planks you are going to use in order to complete the formula; so multiply square feet times 12 and divide by the width of the wood (in inches) to get lineal feet.
Add 10% to that figure to compensate for waste cut outs and mistakes
Feb 19, 2015 • Vacuums
How do you attach the feet to the sofa? Came without pre-drilled or tapped starter holes or a diagram.
Are you sure there are no existing holes? I have seen where they are actually covered by the material/felt that they staple to the bottom. On the other hand, if it doesn't have holes, try this. I will assume that the feet have a course type wood screw thread. Take a piece of cardboard and cut it to a 4" X 4" square, this should be enough to cover the corner of the sofa. (if not make it as big as needed) Locate the wood corner of the sofa and mark that area on the cardboard. Now you have a template for your feet. Given the center of the wood location on the cardboard, punch a hole through it. This is where you will have to hold the cardboard to the bottom and with a drill, mark a hole on the sofa. Repeat this for as many legs it has. Now judging what size screw the feet have is a matter of gauging it, like stick it into a straw, or next to a pencil. You want a drill bit smaller than the screw size. (15% smaller is good) When you drill the sofa wood, I suggest measuring the screw of the foot and mark the drill bit for that depth. (a small piece of masking tape around the bit will do fine- blue painters tape works better) Once you have drilled all required holes for the feet, proceed to screw them on. If they are a bit tight, or not going all the way in, use your drill bit and make minor adjustments to the depth or diameter of the drilled hole.
Dec 30, 2014 • Furniture
1helpful
What r the parametric specs for the ma audio hk15x2
Fo (Hz) : 29.581 QMS : 3.965 QES : .517 QTS : .457
VAS (liters) : 147.723 REVC (Parallel-Ohms) 1 SPL @ 1 watt/ 1 meter (dB) : 90.6 X-Max Linear peak-peak (mm) 70 LEVC @ 1kHz (mH) : 1.043 Enclosure Volume (Sealed) : minimum 2 cubic feet Fill Required % : 0 3dB down point (-3dB) : 43 maximum sealed: 2.5 cubic feet n fill required: 39 at 3 dB down point Enclosure Volume Ported Vented (cubic feet) : 5.0 Vented to Hz: 35 3dB down point (-3dB Hz) : 28 Square port area Sq/In : 80 Port Length : 13" Power Handling : 2000 Watt RMS & 4000 Watt Max. Make sure to use MDF for the enclosure and use 1 inch thickness and use braces as well. This is a beast of a sub woofer. So give it the proper power it needs and make sure that your box is very solid in construction. If installed correctly and given the right power, this sub woofer is bound to put a smile on your face and rattle your bones. I hit 142dB with only one of these subs and im sure if i gave it more power i could hit the 150dB range. DON'T FORGET TO GIVE IT THE POWER IT DESERVES. Have fun dreamsystems.
1helpful
I need to know how to aling the the out feet table heighth to that of the blade heighth. In moving, the out feet table is higher than the blade on a Delta wood jointer 37-196.
I assume you want to know how to get it adjusted just right, not how to move the outfeed table up and down. The easiest way I have found is to lay a metal ruler on edge on the outfeed table so that it extends over the blades. Slowly turn the blade forward by hand while you lower the outfeed table. Do that until the blade snags the metal ruler. Then raise the table until the blades just stop snagging the straight-edge.
9helpful
2answers
2000 Lincoln Navigator, How do you get the heater core out?
the door squeezes in on the side to open all the way to reviel the screws
128helpful
How large a room does a 10,000 btu air conditioner cool
What size unit do I need for my room? Use the following chart to find the appropriate size air conditioner to use:
AREA TO BE COOLED / CAPACITY (BTU/HR)
100 to 150 square feet = 5,000
150 to 250 square feet = 6,000
250 to 300 square feet = 7,000
300 to 350 square feet = 8,000
350 to 400 square feet = 9,000
400 to 450 square feet = 10,000
450 to 550 square feet = 12,000
550 to 700 square feet = 14,000
700 to 1000 square feet = 18,000
If the room is heavily shaded, reduce needed capacity by 10%
If the room receives a lot of direct sun, increase needed capacity by 10%
Add 600 Btu/Hr for each person in the room if there are more than two people
If the unit is for a kitchen, increase the capacity by 4,000-6,000 Btu/Hr.
if this helps please vote me a fix ya
Top Magellan GPS Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Magellan GPS Expert? Answer questions, earn points and help others
