Question about Whirlpool RBS245PDS Electric Single Oven
Electric oven not working
Nothing works oven lights out, trips in meter room ok,under two years old model 60094741
  • 979 Answers
You have a dead short if it trips the breaker right away. You have wiring that has or is touching the metal or frame.
Posted on Jan 30, 2009
The oven is on and lights work. When I select a function, cooker remains on but when I select a temperature the cooker trips the mains
In a simple oven, this could be be due to a heavy current due to a fault (check with resistance meter) or if the resistance is OK the tripping could be cased by an 'earth leakage' which typically presents when an appliance is damp or a heating element has not been used for a while...
Aug 18, 2014 | AEG B8139-4-M Electric Single Oven
The oven was on and working..then the electric tripped and all power went off...after putting the switch back up on the fuse box everything on the oven started working but it does not get...
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please How to Video Tutorials on Domestic Appliances
Mar 04, 2011 | Zanussi ZBF260 Electric Single Oven
Smeg cucina SE375 single electric oven not heating-grill and lights etc working ok and fan making noise-oven approx 18 months old
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jan 14, 2011 | Smeg Ovens
The fan and oven light in bottom oven works but not heat.
The heating element is the likely culprit as they burn out and go open
circuit..(ie ...disconnected and will not heat up )
If you can use a multi-meter , then the element can be tested using the resistance range (with the oven SWITCHED OFF )
Aug 30, 2009 | Neff U1721 Double circotherm Electric Oven
The fans arn't working, have checked the element both visually and with a meter it's ok - any ideas? The cooker is approx 17 yers old, no identifable model on front, single oven
if the elements work but the fans dont are you talking about circotherm main oven fan or cooling fans ? there are 2 if its a double oven ,the age of your oven suggests they are gummed up with carbon after years of use and will have seized up.
hope this helps
Jul 04, 2009 | Neff B1421 Electric Single Oven
I have a GE Single Wall electric oven.(JTP25SOH2) The heating elements just stop getting hot. unit is about 4 years old purchased brand new. first the broiler stop getting hot then the baking heating...
First your broiler heating element may have gone bad and now you oven heating element may have gone bad. Using an OHM meter disconnect them and test for their value.Full scale on the meter means it is shorted. No meter movement means that it is open.Eitehr means to obtain a new element(s) and replace it/them.
Jun 11, 2009 | Ovens
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
Beko s512 oven wont heat up light not on hob works ok ,,electric oven
you probabbly have some burnt out elements or switches gone bad use a meter and check for current coming to your element when you have it on if no current its a switch if there is current then its an element problem
Mar 15, 2009 | Ovens
I was baking something and all of a sudden the lights in our house went dim and our oven glowed bright orange and when I opened it, smoke came out but my food was still uncooked. Now the oven won't heat...
Sounds like you had an element burn out and tripped a breaker.
Find the breaker to the oven. If its tripped it should be in the middle position, not "off" they are sometimes easy to mistake for being on.
If you have a volt.ohm meter we can doagnose the problem and confirm if it is the element or not. (90% chance thats it.)
They are fairly easy to replace and usually pretty cheap.
But before you buy parts, make sure if its still under warranty or not. If it is, it could save you some time and money.
Jan 07, 2009 | Ovens
Bottom oven not working Tecnik 8525/2
To be certain the element is o/k , you need to test it with a meter.
The fact that it looks o/k proves nothing. If you know how to use a meter, then remove element from oven, and with the meter set on the continuity range, test across the terminals of the heater, if you get fsd, ( full scale deflectoin) then the element should be o/k.
If no deflection , then element is no good.
If in doubt, remove the wires from the element , and try the oven, if it does not trip, then it proves element faulty.
Plz rate my solution.
Thanks.
Jan 05, 2009 | Tecnik TKC8525 Double Oven
Whirlpool RBS245PDS Electric Single Oven Logo
115 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Richard Roth
Richard Roth
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
