Question about Kitchen Ranges
I have a cavaliere island range hood, model #sv218d-im & lights won't turn off.
  • 171 Answers
SOURCE: Futuro Island Vent Hood
Hi snuds1369,
I'm Harvey the Master Plumber.
Your question is: You have a situation that recently has started with your Futuro Island Vent Hood. In the past a blue light would be on the display (4 buttons) when the hood was on. Recently the blue light for the hood is now on when the hood is off. Is there a way to reset this?
Yes. Turn off at the breaker for 30 min. If this doesn't work it's an indication the control chip has a problem.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 14, 2008
SOURCE: I have a Cavaliere 218 range hood and the lights
We have a Cavalier range hood as well that the two halogen lights stopped working. Bulbs were good and the light switch illuminated. I ended up ordering and replacing the transformer and it works great:
https://www.lightsonrus.com/store/products/Hatch-RS12%252d80M-(RS)-Series-Electronic-Transformer-80Watts.html
Posted on Jan 20, 2010
SOURCE: Cavaliere 218 series range hood lights don't work.
It's the connectors that lead from the transformer to the lights.
I had the same problem with the Vetron series and hard wiring them with new clips fixed the problem.
Posted on Nov 24, 2010
  • 11 Answers
SOURCE: can this be installed over an island?
Bring a focal point to your kitchen by having an island range hood, combining function and elegant form. A suspended hood is also an efficient way to vent
grease, odors and smoke to the outside from a island stovetop while you cook. You can install an island range hood in just a few hours with the right tools
and knowledge.
1.Wear safety glasses and work gloves. Turn off the electricity to your kitchen at the circuit panel. Cover the circuit breaker with a piece of electrical
tape to prevent people from turning the on switch while you are at work.
2.Lay work drop cloths on your cooktop and floor to catch dust and debris. Mark the duct opening with a pencil in the ceiling, where the island hood will be
installed. Be sure the opening is centered directly above your cooktop. Cut the opening using a hacksaw.
3.Go up to the roof, using a cat's claw and hammer to remove stucco, tiles, sheathing and insulation to make way for the steel venting duct. Drop a
plumb bob down the roof, making sure the line is straight down for the ductwork.
4.Follow the manufacturer's instructions for locations, installing 2-by-2 wooden blocks in the ceiling to hold the ductwork hangers.
5.Install the venting duct from the outside of the home, down to the location of the exhaust vents on the island hood. The ducts should easily slip into each
other. Secure all the duct sections with duct sealing putty, using a putty knife.
6.Screw a roof cap on the end of the duct at the roof. Seal any openings or gaps where the roof, ceiling and duct meet with silicon sealant. Let the sealant
dry, then paint with colors matched to the surrounds.
7.Place your hood upside-down on the floor, with the fan and filter facing upward. Locate and unscrew the metal electrical box cover on the island range
hood, to expose the wiring
8.Install the hood cover to the load-bearing ceiling frame with the package hardware through the four inside mounting corner flanges on the cover.
9.Measure what will be the distance from the bottom of your hood to the cooktop; it should not exceed 30 inches for exhaust efficiency. Have a helper hold
the hood in place while you attach the hood on the hood cover using the included screws. Use a level be sure the hood is level as mounted.
10.Connect the electrical wiring by consulting the manufacturer's suggestions or hire an electrician if you are not familiar with house wiring. Tuck the wires neatly in the hood electrical box and then replace the cover, after connecting the hood wires to the wall wiring.
11.Remove the electrical tape on the circuit breaker, turn on the electricity to your kitchen and test your island range hood.
Posted on Aug 09, 2012
richroth
  • 9472 Answers
SOURCE: Pilot light won't stay on
What is the model number of the unit?
Posted on Nov 28, 2012
Looking for repair parts for a buf03r
Air-Pro (Formerly Fujioh) Range Hoods & Ventilator Power ...
www.kitchensource.com > Kitchen > Range Hoods
Items 1 - 24 of 125 - This page contains Air-Pro (Formerly Fujioh) Range Hoods from ... Air-Pro (Formerly Fujioh) Double Panel Island Mount Wood Hood, Multiple Sizes & Finishes Available (CFM depends on. .... Ductfree Kits, Filters & Traps (4)
Sep 15, 2015 | Fujioh Kitchen Ranges
My Fanimation Islander FP320 stopped working, I've replaced the wall switch but fan won't spin and lights won't dim.
Check to make sure your fan is set on the high speed & the light is at the on possition with the pull chains.
Jan 01, 2013 | Fanimation FP320OB The Islander® FP320...
Cavaliere 218 series range hood light stopped working. tried changing the bulbs still not working. what could be problem, maybe internal electrcal problem?
We have the same exact problem with our--218 series. The lights started going out, then just stopped coming on at all. It is not the bulbs--other people are having this problem. It must be a manufacturing issue.
Mar 18, 2010 | ewatchfactory Ewatch Cleveland Cavaliers...
How do I contact the manufacturer of the Cavaliere range hoods? The variable intensity lights on my island range hood are no longer operational.
http://www.cavalierehoods.com/productdetails.asp?CatID=4&HCID=1&PG=I&ccode=SV218D-36I&CPG=Features
Jan 15, 2010 | Kitchen Ranges
I have a Cavaliere 218 range hood and the lights don't come on. Lamp button illuminates, but no lights come on. Bulbs are good.
Dec 30, 2009 | Kitchen Ranges
Nov 14, 2009 | Kitchen Ranges
Can this be installed over an island?
and knowledge.
May 26, 2009 | KitchenAid KHVU781RSS Stainless Steel...
Hi snuds1369,
Thank you,
Oct 12, 2008 | Futuro Kitchen Ranges
Kitchen Ranges Logo
169 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
