Question about Neff Microwave Ovens
Bosch quantum speed microwave combination oven door handle loose
The handle is loose on the right hand side need to be able to take it off to tighten or replace
silly girl
  • 513 Answers
SOURCE: loose door handle
DON'T remove the cover yourself unless you fully undertand the SAFETY issues involved in working inside a microwave oven. A microwave oven is possibly THE MOST DANGEROUS common consumer product to service. Usually with these doors, the latching parts tend to loosen up at times, thus requiring some re-adjustment and tightening. Sometimes they get a bit warn and require to be replaced. The handle by itself about $40, apparently GE doesn't know how to make a door handle that will hold up for more than a year or so. I just bought a new door off of eBay for $20 + $20 shipping ... a deal compared to the $135 + tax and shipping that most of the web sites want! All you need is a phillips screwdriver and a 5/16" socket. To get to 3 screws that anchor the TOP hinge, simply remove the vent grill (open the door and remove the 2 white screws that hold it in place). To get to the 2 screws that anchor the BOTTOM hinge, simply remove the 6 screws that hold the grey bottom pan of the microwave in place. The pan will swivel down, remaining attached in the back panel. Once you've removed the 5 hinge screws, the door should pull pretty much straight out. Reverse the procedure with the new door, which should come with hinges attached. Could be that the place the spring sits in is a little broken, so theres no stop for the spring. open it up and see if there's anything you can do with it, try some epoxy putty maybe. Good luck
Posted on Apr 30, 2006
MicrowaveSvc
  • 9047 Answers
SOURCE: jenn air microwave oven door handle
You can find helpful exploded view diagrams for the similar model M438 here: http://tinyurl.com/gv383
The model M437 is not listed, but the M438 is, and it should be similar enough to guide you. Just don't count on the part numbers being the same.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 30, 2008
reg501
  • 413 Answers
SOURCE: microwave ovens
The Magnetron has failed, causing the waveguide to become damaged. If the waveguide is damaged/burned the microwave can not be repaired and should be replaced.
Posted on Dec 25, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: replace door handle on mco153uq
Normally You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can order parts here.
Posted on Aug 30, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: How do I replace a LG LMV1630ST microwave oven door handle?
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Nov 25, 2009
Have loose handle on electrolux icon microwave. How to repair.
There is screws inside the door when you openi it so you tight them thats all
Sep 15, 2014 | Electrolux ICON Microwave Combination Oven
Tighten the door
Unplug the oven and remove the top/side cover. Check for loose screws on the hinge mounts, and examine the door carefully there to see just where the play is if the screws are tight. There's a high probability it's due to worn pivot bushings. I haven't yet taken a door apart to fix this problem (although I need to do it on my 30-year old Panasonic unit), so I'm not prepared to describe how to do that. Depending on how it's put together, you may be able to loosen the screws, adjust the door so it fits better, then tighten the screws again.
May 19, 2014 | Bosch Microwave Ovens
Operating interior light of bosch quantum speed microwave oven
Replacing the bulb is not really that tricky, and they only cost a few quid, so definitely worth doing:
1. unplug and take the cover off,
2. remove the two screws at the sides of the control panel, and move the panel out the way,
3. remove the metal plate covering the bulb area (5 screws),
4. squeeze and detach the springy fold of metal holding the bulb,
5. pull off the the bulb's electrical connections
6. unscrew and unhook the bulb, and replace!
My bulb was a 240V 25W T170 with right angled terminals.
Aug 18, 2013 | Microwave Ovens
Bosch Oven Manual HBC86Q650I need a manual for the above oven/microwave
go to www. fitness.manualsonline.com or www. retrevo.com and download for free.
God bless you
Jul 09, 2013 | Microwave Ovens
Loose microwave handle
The handle screws are installed from inside the door, so it would be necessary to disassemble the door to tighten them. You have to decide whether the time and labor involved are worth it.
May 19, 2013 | Microwave Ovens
E30so75fps loose handle
Amanda,
You need to carefully try to remove the plastic frame around the outside edge of the inside of the door and hopefully that should expose the screws that you need to tighten for the handle. I say carefully because that frame can be very expensive to replace if you break it. It is currently listing on Sears site for $95!
Jun 06, 2012 | Electrolux ICON Microwave Combination Oven
Bosch combination oven/microwave HMG 8220GB start button doesn't work
This is a door switch problem, one of the door switches has malfunctioned preventing the microwave oven from running.
May 14, 2012 | Bosch Microwave Ovens
How to fix loose handle on Electrolux TINSEB4225MRRO
you must open the door in two parts, for that unsrew the screw from the door sides, remoove carfuly the isolation and screw the handle.
Feb 20, 2010 | Electrolux ICON Microwave Combination Oven
Loose handle.
To access the door screws on MOST microwave ovens, you need to remove the inner door panel that goes around the perimeter of the glass. The following link explains:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
This can be peroformed with the door in place, or with the door removed. If you have any questions, please post back with your complete model number and let me know. I hope this helps you.
Feb 18, 2010 | Kenmore 62622 Microwave Oven
Loose Door handle
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Sorry, but I can't be more specific on non-US models.
Hope this helps!
Jun 17, 2008 | Neff B7740N0GB Microwave Oven
Microwave Ovens Logo
143 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
