Question about Drills
Drill keeps on stopping and won't restart
Using a brand new Bosch PSB 650 RES (corded hammer drill) for the first time. It frequently stops drilling (often after a few seconds of use from cold) and takes tens of seconds before it allows me to start drilling again. My recollection is that the trigger was locked while it wouldn't restart.
(Bring back my old B&D)
  • 2 more comments
  • mjgg Jan 09, 2009
    It was bought in the UK (Argos), the drill says BOSCH PSB 650 RES on the side. The manual that came with it is for types :
    PSB 600 RE
    PSB 640 RE
    PSB 650 RE
    PSB 650-2
    PSB 700 RE
    So it's probably very similar to those.
  • Anonymous Jan 17, 2009
    DR601 black & decker hammerdrill quit wont run.something to do with forward and reverce switch. thanks steve.
  • mjgg Mar 15, 2009
    Thanks for the help. The cord looks good. I think it has to to go back to the shop now.
  • David Ford
    David Ford May 11, 2010
    I checked the Bosch website to see if I could help but the number given doesn't match up with any of theirs. Could you recheck both model and brand and let me know and I will try again
  • 3 Answers
Check the cord...sometimes if the brushes are not seated well or if there is a cut in the cord you will run into that problem....If it is not that then possibly you just have a faulty drill
Posted on Mar 12, 2009
How do you remove the keyless chuck on a Bosch PSB600 RES drill?
Here's a link to an exploded view:
Bosch PSB 600 2 0603338003 Spare Parts
If you need more help - you should contact Bosch directly:
Contact Bosch
Apr 14, 2015 | Bosch Drills
I have a bosch 11264EVS hammer drill that just stopped working. I checked the brushes and have continuity to the rotor. Is there somethingelse I need to check/replace before I hunt sown a service center?
Did you have continuity from one brush to the other? Some Bosch tools use "pop off" type of brushes. When they get worn down a spring loaded center pops out and keeps you from damaging the armature. If they are fine check cord continuity. If the cord is fine it is most likely the switch. You can test the field for continuity also but those rarely ever fail. Here is the parts diagram.
Bosch 11264EVS diagram
Aug 24, 2012 | Bosch 11264EVS 158 SDSMax Combination...
How do you replace the chuck on a Bosch 650 RE
while holding the drill like a gun, hold the lock button REALLY tight and pull the black part to the right really hard. this will unlock the chuck and if you keep twisting the black part to the right it will loosen it enough so that you can remove it
Jan 03, 2010 | Bosch Drills
Bosch GBH 2-20 SE hammer drill stopped working
check the cord and the switch to have continuity,the wires,the brushes,the rotor and stator.
regards savumihai71
Oct 11, 2009 | Bosch Drills
New bosch psb 550 re with hammer action. Hammer action does not seem to engage. even with 5mm bit progress is non existent. The bits were bosch masonary bits and I was drilling into concrete blocks
your pin under the selector switch my have broken off. also the hammer rod could have broken too. if its drilling and not hammering that more likely. you may be under warranty call bosch or log on and go to dealer locator's for the closes dealer to you. hope this helped
Oct 09, 2009 | Bosch Power Tools Hammer Drills
BOSH PSB 600 RES drill will not restart
Hi, Sounds like you have a pinched wire somewhere. When you say you somehow make it work are you bending the powercord, shaking the drill or what? Any of those things would suggest a pinched wire or broken switch. Make sure the switches for reverse and hammer work in both directions. You say it is relatively new and there is no smell so I would not suspect the brushes and it doesn,t sound like it is running long enough to overheat anyway. The best advice I can give you is that the drill needs to be opened and examined, and if you have an ohm meter check all of the connections from the power cord to the trigger. If you don't feel comfortable with that then you may want to return it under your warranty or you may want to do that anyway. Good Luck!
Feb 04, 2009 | Bosch Drills
Drills Logo
495 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
