Question about Reddy Heating & Cooling
Kerosene heater flame is fluttering - Reddy Heating & Cooling
4 Suggested Answers
SOURCE: kerosene reddy heater flame is intermitent
Heater had a cracked fuel line that was not visiable on original inspection.
Posted on Jan 26, 2009
  • 288 Answers
SOURCE: I have reddy heater125t the flame lite
It sounds more like airflow and too high of a temp. The fan blades and return vent side must be very clean to keep this big guy pushing the btus out of the heater. A restriction of any kind could cause this overheating situation causing it the shut itself down. If you are confident that air is not the problem, make sure the nozzle that the kerosene comes out of is clean also.
Posted on Jan 09, 2010
Testimonial: "Thank you it gets good air flow I will try to clean the tip"
SOURCE: Dyna glo RMC 95 C6 kerosene heater, BRAND NEW.
1. Check to make sure you using fresh clean kerosene fuel. 2. Make sure you fill the heater and let it set for at least an hour, 2 hours is better. 3. If either of those solutions don't fix the problem, return to the store.
I have the same heater and just changed the wick. When working correctly, it should be so hot that it's uncomfortable to hold your hand 2 feet over it.
Posted on Jan 04, 2011
What is a cad cell and what does it do
A cad cell is a photo-electric device that reads the UV rays given off by flame after it has ignited. If it does not 'see' the flame, due to a flame failure OR a cad cell failure, the control circuit is locked out.
Make sure there is no carbon on the front (window)of the cell and make sure its adjustment is in perfect alignment to the flame.
Feb 19, 2015 | All-Pro Kerosene Garage Shop Heaters - All...
Kerosene garage heater (Desco) fan starts, burst of kerosene, and the heating element is red. Within a few seconds, heater stops abruptly. Email address: p.s.stohr@sbcglobal.net Thanks for your help.
Remove the top from the heater and clean the flame sensor. It should be the photo eye type. Remove it from it hold and clean inside with soft cloth or cotton swab with alcohol. If this doesn't help, let me know what you find. nitensheaterservice@earthlink.net
Jan 11, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
It is kerosene, it ignites, runs from 1 - 5 minutes and loses flame
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Dec 14, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Flame ignites for several seconds and then stops
there is a flame rod that looks like a thermocouple. Clean it with a pencil eraser or scotch brite pad. The carbon build up on it acts as an insulator and it wont rectify the flame
Dec 06, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Kerosene Portable Forced Air heater comes on, runs awhile
The unit should have a fuel & air filter. Check that both are clear. Inside the burner tube, there will be a photo-cell, if the lense is dirty it will shut the flame off. The photo-cell needs to see the flame. You can carefully and gently, clean the lens with a tissue, soft cloth, or Q-tip. Please let me know how its coming along.
Feb 09, 2009 | Desa International Reddy Heater R115DT...
Kerosene reddy heater flame is intermitent
Jan 25, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
All Pro Heater
most parts for kero heaters are interchangable. go to desatech dot com for parts. check for a reset button for your heater. if no reset, does the fan run? your unit can use one of two ignition parts. a spark generator with a spark plug or a hot surface igniter. the unit uses a cad cell flame detector. you might need to replace this.
Nov 18, 2007 | All-Pro Kerosene Garage Shop Heaters - All...
Heating & Cooling Logo
184 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
