Question about Garden
Installed new pto clutch on JD lx277 pull pto switch out and you have nothing but when you get off the seat with switch engaged it will die. Is it my switch??
2 Suggested Answers
nova2nv
  • 197 Answers
SOURCE: Engine dies when engaging PTO switch on a John
Check and adjust your RIO switch{reverse implement option}near the trans if so equipped.What happens when you press forward pedal then engage blades?Would also check the lower bearing on your pto clutch to see if its seized up.
Posted on Nov 14, 2009
JD X595 4x4 mower - Starts OK, BUT, as soon as the brake is released, the motor cuts out.
I would try bypassing the seat switch and the brake switch. Do this one at a time to determine if the switch is bad. Also buy some Sta-bil fuel stabilizer and gel remover. I recommend this for any seasonal equipment. Often the engine is not getting enough fuel and will stall when the pto is engaged. Sta-bil often rectifies this problem.
Mar 06, 2015 | Light Garden
On john deere la150, if i sit on seat and engage blades,,,nothing, but when i lift of seat, blades engage and motor shuts off. Replaced seat switch and did not fix problem
"On john deere la150, if i sit on seat and engage blades,,,nothing, but when i lift of seat, blades engage and motor shuts off. Replaced seat switch and did not fix problem" Okay, what I'm hearing is that "nothing" means the blades-driving PTO won't engage (declutch) when you switch on mower; but then, (say) as you start to dismount the mower (seat) the mower (drive clutch) engages even as the deadman switch (seat switch) kills the engine (and the drive/pto shaft starts to slow down. The key here seems to be that at full engine torque the clutch is unable to remain engaged but, rather, slips so that mower blade inertia (resistence) cannot be overcome...but as engine/pto rotation slows the clutch is able not to slip. First place to consider is the clutch gap which is probably to0 large (possibly from wear and tear, possibly not). So check specs and how-to from manual or factory and reset the pto drive clutch gap...not hard to do. If clutch gap is not the problem then most likely rehab or replacement of the clutch assy will be needed...is the mower has many years use sufficient to wear out the clutch. Another possiblity is an electic (wring/switching/grounding) problem involving mower and deadman switches.
Aug 19, 2014 | Garden
X520 jd mower trouble
Sounds like a problem with the governor. Start it up. Don't engage the blades. Drive to a hill. Idle all the way down. Try driving up the hill. The motor should pick up when it slows while pulling up the hill. If it doesn't, the governor isn't working right.
Jul 16, 2013 | Garden
John deere lx277 goes dead when clutch or pto is engaged
check the safety switch on the brake/clutch pedal
May 11, 2012 | Garden
Craftsman ZTS 7500 dies when engage blades or when engage transmission
check the "kill switch" they are usually located in the seating area. it senses for pressure or seat angle and will kill the mower if nobody is sitting on the mower. Good Luck
Apr 17, 2012 | Craftsman Garden
My dad is trying to fix a lawn mower for a friend. It is a John Deere LX172. Whenever the mower deck is engaged or the unit is put into gear, the engine dies as if the ignition were shut off. I think...
Check the seat switch. That will cause your problem. It happened to me when I was not sitting on seat and turned deck on. Mine is a LX172 also.
Aug 12, 2011 | Garden
Bobcat ZTR new blade brake won't engage while engine is running
SOUDS LIKE THE CLUCH SAFTEY SWICH IS BAD OR THE SEAT SWICH MAY BE BAD CK THAT OUT AND LET ME KNOW OK THANKS
Aug 18, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
