Question about Honda Electrical Supplies
Stalling problem with a honda em5000sx generator
Generator stalls when an electrical load is applied. Also need to leave the choke on a little to keep the engine running when the auto throttle switch is turned off.
FRANKSFIXIT
  • 72 Answers
SOURCE: generator is stalling
My answer:
Not knowing your model # and how old your generator really is - as related to TOTAL RUN HOURS - I can only give you several possibilities of what the problem might be even though I don't know the make & model and what the rated WATTAGE output is.
I also don't know what LOAD you are putting on the Genset or at what RPM you are running the engine at as to half throttle or full throttle setting?? I take it that it's a Briggs & Stratton 4-stroke single cyl, or is it a Honda 4-stroke single/twin cyl engine?
Since it runs good for 30 mins, and then starts to cut out - I doubt that the OIL is a problem even though you ran straight 30 weight - seeings most small engines run 10-30 weight oil as a rule.
I seriously doubt you did any damage to the engine at all unless it was ran low on oil - in which case it should have a LOW OIL cutoff switch mounted in the lower engine case close to the CHECK OIL port.
If the LOW OIL switch is working properly and adjusted properly then you shouldn't be getting cutout unless this switch is mis-adjusted. (ie: mechanically set too low as then when the oil level is indeed at it's proper level the switch would be already shorting out to ground) (See your operators manual for proper setting)
A way to check for proper operation is to temporarily disconnect the (usually) BLACK wire from the LOW OIL switch when the engine starts to cut out. If the problem goes away completely then the LOW OIL switch is either mis-adjusted or else it is going bad from vibration. (Again see your operators manual for proper adjustment and/or check out procedure)
Electronically this LOW OIL switch should be the only thing that would protect the engine from damage should the oil level fall below recommended level. Other then that it may have an electronic REV LIMITER if it's a bigger and more expensive model, but usually not.
I doubt the Maintenance-free Magnetron® electronic ignition is at fault, but could be weak and going bad. Always a possibility, but I would 1st rule out everything else first. Since the Genset runs for 30 mins and then starts to cut out I would look more for like a fuel vapor lock (partially closed or clogged gas cap vent), a possible dirty fuel filter, possible water moisture in the gas tank or in the carb bowl, possibly dirty carb in general along with it's dirty Float Bowl, Float Pin, Float and Needle Valve, and any Adjustment Screws that go Into the Carb Body. That covers everything from a fuel standpoint.
You do know that all Gensets should be started and run for at least 10 mins every 30 days - right? If you didn't know this - now you do! Every good operators manual should state this.
It just doesn't sound like it's starving for gas unless it's building up a (vacuum) or vapor lock in the gas tank.
Having covered everything from an Electronics/electrical standpoint engine wise - there is only one other thing left Genset wise.
What it really sounds like to me (and I personally HAVE SEEN this happen myself firsthand) is that the generator brushes are nearly shot - as in almost worn out. They may be getting too too hot - as from excessive current draw at point of contact, and thus the generator sensing circuitry itself is doing an electrical CUTOUT!!
An added protective Genset circuit feature in that the generator itself may indeed be linked to the engine as a type of REV LIMITER on the Maintenance-free Magnetron® electronic ignition. Again - your operators or service manual should have a pretty good troubleshooting section in it unless you don't have that anymore or never got one if you bought it used to begin with.
It has to be one of the scenarios listed above.
Please post me a reply as to the found problem there, and the resolve to it by following my recommendations above. Also please rate my troubleshooting fix as well.
Best regards and thanks,
Frank
Posted on Sep 01, 2008
CarlGehrke
  • 169 Answers
SOURCE: powermate pm0545005 generator engine runs but no power out
I posted a general "how to" about troubleshooting Powermates here.
Don't forget to rate answers you like,
Carl
Posted on Dec 05, 2008
SOURCE: Honda EU3000is Generator is running poorly.
Can anyone help me with the eco-trottle switch when I switch it on it seems to run the same idle whether I have it off or on, what could be causing it not to work, is it a bad switch or I am running 89 octane could that be the problem.
Thanks
Alex
Posted on Oct 09, 2009
Richie_asg1
  • 1036 Answers
SOURCE: honda generator gx390 will only run with the choke
Most problems like this are a fouled inlet in the carb. Try adjusting the carb settings fully in - then back out tooriginal position. This often crushes any debris causing the problem.
Failing that, clean out the carb.
Posted on Feb 07, 2010
SOURCE: i have an aldi powercraft
Hi there, YES manual VERY misleading, starting it all revolves around the Choke, if I remember correctly, place lever on Choke, start then move lever to on position, good luck
Posted on Jan 26, 2011
Why wouldn't my em5000sx honda generator not run my rheem gas heater.
  • The Auto Throttle System switch needs to be in the off position.
  • If the generator has not been used for awhile than the fuel is stale and the generator may be slow in responding to the load change. Replace fuel with fresh fuel.
  • Attach a second load such as a 100 watt light bulb standard bulb with a tungsten filament. Observe the light as the heater cycles. If the light goes very dim than the generator is slow responding to a load change. Generator carburetor needs to be cleaned, tune-up. Run fresh fuel under load to see if carburetor will clean itself.
  • Try adding choke to see if richer mixture reduces voltage dip. Check manual for mixture adjustments.
Nov 30, 2015 | Heating & Cooling
Start the engine
I assume you refer to a 6500 watt Honda, if it's electric start/and manual(pull cord) First supply a 12 volt battery /if you haven't put fresh gas in it do the best you can to remove all the old gas from the tank and you should find drain screws and small hoses on the lower part of the carburetor. After completing this step add about 1 gallon or so of fresh gas, remove the air filter system from the face of the carburetor ,with a small squirt bottle put a tea spoon or so of gas into the of the carb, close the choke and turn the key, if it fires let it run with the choke closed for only a few seconds then slowly open the choke fully, if the engine stalls close the choke and start the engine again do not leave the choke closed for extended periods as this will cause engine flooding and spark plug failure. Also be sure you have inspected the existing spark plug to be sure it's clean if there is any question about the plug change it.
BR
Oct 20, 2014 | Honda 3000 Watt Portable Generator
Honda em5000sx generator won't start
I have a EM5000SX. My problem is my generator will not start unless I turn the fuel selector to off. Then crank it until it does start, turn the fuel back on. Run's normal . I run this generator for my cabin every weekend.
Aug 25, 2012 | Honda Electrical Supplies
2006 Honda 750cc Shadow Aero starts with choke, runs for a minute, sputters and stalls. Won't start again for a couple of days, then starts right up. Electrical?
Hi there
I once had a wee car,whenever it got too much petrol inside itself it refused to go anywhere and had to rest for some time and you had to be very careful with the choke and the petrol so it did not swallow too much of it and need another rest.
kolbrun
Apr 02, 2012 | 2004 Honda VT 750 Shadow Aero
Honda 2000 eu runs only at half choke once you shut choke all the way off it stalls
These motors have a heat automated choke release system and when it gets hot enough the choke will back off if the ports in the carb are clean and not blocked...if they are blocked clean the carb out real good.
Oct 13, 2009 | Honda Electrical Supplies
2004 honda vtx 1300 c stalls out after down
ever drain your carbs ? should be done seasonally . fuel filter problem, sounds like it is running out of gas.
Oct 10, 2009 | 2004 Honda VTX 1300 Retro
2006 kawasaki 750 vulcan will not idle , will idle with choke
ok buddy on the carb will be some sort of screw and idle screw turn this in 1/4 of a turn with the machine running until it idles at 1000rpm also the choke will stall the engine when warm the choke is only for cold starts get back to me more info or problems f4d68ca.jpg
Sep 24, 2009 | 1992 kawasaki VN 750 Vulcan
Engine keep turning off
It could be a part called the Idle control Valve. It regulates the Idle speed and keeps it smooth. If it is choked up with carbon gum or the little motor inside it is faulty then it will not allow enough air too pass for smooth idle. When you put your air con on the engine is under more load because it has too turn the aircon pump so it will stall. Also you have a little device on aircon cars that raise the idle a little to compensate for the extra aircon load. If this is not working it could be that.
Jul 06, 2009 | 1996 Mercedes-Benz C-Class
Engine stalls out
sounds like a dirty carb or need to rebuild the carb, adj valves, new plug, do a tune up
Oct 20, 2008 | Sport & Outdoor - Others
Electrical Supplies Logo
250 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
