Question about Canon Office Equipment & Supplies
Canon Copier Model C122F - error light flashing
Error light is flashing that represents (I assume) that the excess toner receiver is full/worn out. Emptied container worked for maybe 100 copies. Now after power-up can print 1 - 2 copies then light starts flashing and won't continue to copy.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
A common mistake is that people think that the waste toner needs to be emptied and instead the toner needs to be replaced --- and vice versa. Check to make sure that the toner bottle is not empty. Also, if you made copies that took ( used ) more toner then the machine was able to replenish, the machine has not had a chance to catch up. Place a white sheet of paper on the platen glass and make blank white copies. You may only be able to get 1-2 copies at first but as the device catches up with the toner replenish you should be able to make more. The blank copies you make -- do NOT put that paper right back into the machine. Lay it flat and let it cool, this will help prevent unwanted jamming due to heat build up in the paper. IF you have good amount of new toner in the machine, gently tap the front line ( or rear line) that feeds the used toner into the waste bottle. Sometimes the waste toner will clog and back up into the machine giving false 'waste toner full' message.
Posted on Jan 04, 2009
Canon ir 2016 toner bag full
I'm assuming it is the waste toner full message. Power down copier- Main Power. Open front door and gray handle to open left side door and pull out drum. On the top there should be an opaque disk to be removed and then you can dump the waste toner into the trash. BE VERY CAREFUL THIS COULD GET MESSY.! Slide the drum back back into position, close the left door and front door. Power up the copier and all should be good.
Mar 13, 2017 | Canon iR 2016i Black and White Copier
Showing toner error after installing NON Canon toner cartridge. Will not clear.
Yes...Duct tape works wonders. Most of these printer cartridge
have built in chips that match to the printers they were designed for. This is the manufactures way of saying "Hey, we practically gave away our printers, so now you have to pay outrageous prices for the ink"!!! Place the tape on the light and enjoy the savings ;-)
Nov 08, 2013 | Canon Laser imageCLASS MF4890dw Wireless...
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
Error code E000013-0001
getfile.asp?rid=1258 February 2, 2005 getfile.asp?rid=3215 Product : imageRUNNER C5800 / C6800 Title : E013 code and Waste Toner Full message Question :
The copier shows an E013-0001 and "Waste Toner Full" message. The Waste Toner Bottle has been emptied and SW1 is operating properly but the code and the message are still appearing on the display.
Answer :
The counter for the Waste Toner Bottle needs to be reset back to zero in Service Mode.
Enter Service Mode level 1 by pressing * 2 8 *, select Copier > Counters > MISC, then highlight WST-TNR, press Clear - the counter will zero out.
Power off the copier, turn the copier back on, the Waste Toner Full message on the display should clear out.
Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
Dec 22, 2010 | Canon imageRUNNER C6800 Copier
E019 in canon copier 2016 j.the machine runs n at last error comes E019, may be toner censer has problem how can i solve this.where would be the censer pls help me .
You need to replace the drum unit. The E019 error code means that the Waste Toner is full, but the problem with this model is that the waste toner cartidge is built in the drum unit so you have to replace the whole drum unit.
Nov 11, 2010 | Canon iR 2016i Black and White Copier
Blinng orange light
Answer Part 1 of 2
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take appropriate action.
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Ink tank is not installed properly
Open the Print Head Cover and check whether an ink tank is installed. If an ink tank is installed, push the button of the ink tank, and reinstall the ink tank properly.
Five flashes: No Print Head installed, or Print Head failure
Install a Print Head.
When the error continues, contact a Canon service representative.
Eight flashes: Waste ink absorber almost full
Ink used for cleaning is absorbed in a waste ink absorber placed in the printer. Eight flashes indicate that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so that you can continue printing.
Important
If this error occurs, replacement of the waste ink absorber and maintenance of the printer are required. Canon recommends to contact a Canon service representative as soon as possible. Once the waste ink absorber becomes completely full, it cannot be printed until the Waste ink tank is exchanged.
Nine flashes: A specified period of time has lapsed without receiving a response from a digital camera or digital video camcorder / The digital camera or digital video camcorder connected is not compatible with this printer
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
Canon 2200 error code 000019-0000
This error code means that the waste toner bottle is full. Most likely it is not full, the waste toner bottle neck gets some waste toner on it and it blocks the sensor.... It is a bad design by Canon. The waste toner bottle is on the Left side of the copier, toward the rear of the copier. The cover is held in by one screw, the cover comes off and the Waste Toner Bottle is inside. Turn the copier OFF by the Main Power Switch on the Right side of the copier. Carefully, dump the waste toner out in a plastic bag. Hopefully, without any holes in it. Wipe OFF all the toner OFF the neck of the bottle. You will see what looks like a DOT on each side of the neck.Make sure the inside and out side is clean. Reinstall the bottle and cover and then turn the Main power ON and the Code should be gone. Good Luck....
Mar 29, 2009 | Canon imageRUNNER 2200
Copier ha a message that says replace toner drum.
It means that the internal drum unit is full of waste toner and that the drum is worn out too. The people at cannon made the drum unit to last when the waste toner internal compartment is full.
When you buy a new drum the instructions are in the box and very easy to install.
hope it helps
Mar 24, 2009 | Canon ImageRUNNER 1670F Copier
I receive an error E000013-0000
Check your toner waste bottle it may be full. Also the tube that transports the wast toner may be clogged. In which case its time to call a tech. John
Jul 02, 2007 | Canon imageRUNNER C3170U Color Copier
179 people viewed this question
old marine
old marine
