Question about Canon Office Equipment & Supplies
Canon ipf750 error 03130031-2618
Replaced printhead still same error.
4 Suggested Answers
  • 121 Answers
SOURCE: Canon imagePROGRAF W8200 InkJet Printer Problem Printhead Error! Turn Power Off!
You'll probably need to replace the whole printhead.  It's a bit of a job on that machine
Posted on Oct 27, 2007
SOURCE: I keep getting a printhead error....
are there air bubbles in the ink tube lines?
is your printhead draining ink onto the paper?
Most likely you need new ink tubes.
Posted on Apr 18, 2008
yooperbud
  • 8637 Answers
SOURCE: Canon Image Prograf w6400 error E02802
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 29, 2009
What does a Canon iPF750 Hardware Error 03800500-2F42 mean?
When the result of non-ejection detection is
as follows:
Complete non-ejection of one line in 1
chip.
(In either A line or B line, a complete
non-ejection of 1280 nozzles)
?Error code assuming broken flexible cable
or contact failure (heat enable line)
manual page 62
Jan 02, 2018 | Canon Office Equipment & Supplies
Error E161-403E
Go onto the Canon Europe site and locate the error codes for your device. It will indicate the type of problem but not how to fix it.
Jul 05, 2016 | Canon imagePROGRAF iPF750 MFP
Error e161 403e en canon ipf750
Canon IPF750 Error Code E161-403E - so, I understand this means the printer head is shot & needs to be replaced.
Feb 03, 2015 | Canon Office Equipment & Supplies
Canon ipf750 error 2F30
Esse error ? relacionado a troca da cabe?a de impress?o.
Nov 07, 2013 | Canon imagePROGRAF iPF750 Wide-Format...
Error code 03130031 2618 print
The hardware error code indicates that a print head failure has been detected. Other possible causes of this error are a faulty cable connection to either one of the PCB's.
First try replacing the Print Heads and if the problem persist, re-seat the cabling to the Relay PCB and the Carriage Unit PCB.
Since you are unable to access service mode, you will need to ignore the normal print head replacement procedure and replace the printheads whilst the plotter is turned off.
The plotter will need to be disassembled to access the print head.
See the following service manual for a detailed guide:
http://mail.davin.be:8888/CANON/BOOK%20IPF/IPF750/ipf750_755-sm.pdf
Nov 06, 2013 | Canon imagePROGRAF iPF8000 Printer
Canon ipf750/upgrade firmware
I would first check the linear scale.That`s a small plastic strip ,positioned along the total lenght of the rail.Mind you ,I don`t have a ipf8000.But maybe the systems are the same.The linear scale is under tension ,by a metal spring.Check if the strip is not hanging loose.Also check the strip (linear scale) on dirt or ink splashes.If so clean it with alcohol (that`s what I did on a ipf5000).The scale runs through a slit ,at the back of the carriage.There are light grey patterns on the scale.The sensor on the carriage reads them ,and thus knows the position of the printheads ,with respect to the rest position.Check if the scale runs smoothly through the slit.
Feb 27, 2013 | Canon imagePROGRAF iPF750 Wide-Format...
Hardware error. 03130031-2618
Turn off printer, wait, then turn on again.
03130031-2618 VH voltage error
Check the power supply unit.
Mar 01, 2012 | Canon imagePROGRAF Office Equipment &...
Canon IPF8100 error code 03130031-2F3A can you please help vicki@westcountry.com.au Thanks
Same error in my ipf755. Canon suggests replacement of carriage (700 eur)...
Feb 16, 2011 | Canon imagePROGRAF iPF8000 Printer
178 people viewed this question
old marine
old marine
