Question about Garden
Primer bulb whistles
Will not prime engine for starting
trippssmengi
  • 76 Answers
SOURCE: Ariens st 622 string trimmer, starts but quickly
It isounds like your primer bulb may have a hole in it and is alowing air to get sucked in in stead of fuel
Posted on Mar 08, 2009
  • 376 Answers
SOURCE: Roto tiller won't start - primer bulb
Carburetor needs to be rebuilt or replaced. Replaced would be my choice.
Posted on May 23, 2009
#1 Taper
  • 1041 Answers
SOURCE: Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
Posted on May 26, 2009
  • 199 Answers
SOURCE: primer bulb won't prime
it sounds like the filter on the fule line is cloged try to remove the filter and then try to prime the trimmer. it it does you need to replace the filter. just about any filter that will fit will do.
Posted on Jun 10, 2009
wilsodfarm
  • 986 Answers
SOURCE: Edger will not stay running
Your diagfram is bad replace it in your carb and you will be ok
Posted on Apr 12, 2010
Why wontsmart carb engine start if primed runs for few seconds
dirt or water in the carby jets
priming it just puts a squirt of fuel in the manifold and that is the initial start run
Jun 19, 2015 | Garden
My quantum xts 50 after priming wont fire
does it start when you prime it or does it not start at all? if you prime it and it runs until the prime burns off then won't start again, try priming it again. If it starts and runs until the prime burns off again then it is a carburetor issue. It isn't supplying the engine with fuel to run after the prime is gone
Jan 20, 2013 | Garden
I have twin 135 hp Yamaha outboard engines. Neither engine will start when cold.Putting small amount of gas into air intake and engine starts, engine starts fine when hot. Choke solenoid working
just like a car before the car start the fuel pump shoots gas in the carb or a lawnmower you gotta prime it all the gas that was in the carbs when you shut them motors off has done evaporated check your fuel cells see if there is a hand pump to prime the carbs unless its electric fuel pumps either way them carbs have to be primed
Dec 22, 2012 | Motorcycles
2006 monte carlo wont start without priming
sounds like your fuel pump weak, need to check fuel pressure when engine won;t start and check with engine running
Sep 03, 2012 | 2006 Chevrolet Monte Carlo
Wont start unless manually primed
Turn the ignition key to the ON position without starting the engine
You should hear the fuel pump priming for about a few seconds then shutting itself off.
If not hear replace the engine oil pressure switch
The 3rd wire to that switch is the pumps prime switch lead.
When the engines oil pressure is reached the computer will shut that circuit off and turn on the fuel pump relay
If you hear the pump prime the relay maybe at fault instead
Jan 19, 2011 | Chevrolet 1500 Cars & Trucks
Engine won't start
Try spray starting fluid into the air intake, that may get it going.
Sep 26, 2017 | Briggs & Stratton Prosumer 20324 Gas...
2000 Chevy K2500 will not start reliably. It has
cant lose prime...it gets primed everythime you turn the key off and back on for more than 10 seconds.
have you had the coil pack controller checked?
any Check engine light when its running?
Jan 19, 2010 | Chevrolet K2500 Cars & Trucks
Could this be a cold start problem
defective fuel pump the check valve is allowing it to lose prime replace fuel pump.
May 28, 2009 | 1996 Chevrolet Blazer
Engine wont start without priming with gas first, then runs well
i have the same problem on a 98 jimmy 4.3 4x4.
i replaced the fule pump and have good pressure.
new wiers & coil (good spark) no MIL & no codes.
will only start when primed. it will run & drive all day
with no problems.
but once it has been turned off (warm or cold) i will
have to prime it once again to start it.
i have another engine that was in it before it spun a bearing.
it ran fine so i know all parts are good.
i swaped the mass air flow and throttle body but i still have
to prime it everytime to start it. am i forgetting something?
should i swap out the intake with the injectors?
any help would be sweet. thanks.
Apr 28, 2009 | 2000 Chevrolet Blazer
Garden Logo
297 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
