I have a 5100 error on my canon pixma mx430. how do i fix that?
SOURCE: Service error 5100 on my canon Pixma mp110
just replaced the ink cartridges and reset the counters, evrth ok now :-)
Posted on Nov 09, 2008
  • 412 Answers
SOURCE: Canon Pixma MP830 error 5100
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 09, 2009
  • 92 Answers
SOURCE: Canon PIXMA iP90v Service error 5100
Error 5100 is mostly because of some obstruction in the print path, the gears, or ink on the clear plastic encoder strip.
There is the purge cap (the white sliding mechanism that the print head parks to when it's not in use) which was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display)
Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on).
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Apr 26, 2009
pineworks
  • 4041 Answers
SOURCE: canon pixma ip1700 printer error 5100?
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 20, 2010
alpug
  • 1961 Answers
SOURCE: Hi: My Canon Printer Pixma
Turn off printer.
Remove both the cartridges from the printer. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches.
Return the cartridges and turn on the printer.
Error 5100 means that the cartridge can not be detected by the printer.
Hope it helps1
Posted on Dec 24, 2010
What does 5100 code mean?
What is error code 5100 on the MP460? - Canon Community
community.usa.canon.com/t5/Personal.../What...code-5100.../103212
Jul 7, 2014 - Please remove foreign objects so that the print head holder can move: ... closet and hooked it up this morning, I was getting the 5100 message.
How to resolve error 5100 on an MX452 / MX459 - Canon
https://support.usa.canon.com/kb/index?page=content&id...
There are several reasons for error 5100 to appear. ... If the above recommendations donot help you resolve the error, the printer will need to be repaired.
How To Fix Canon Printer Error 5100 - YouTube
? 2:23
https://www.youtube.com/watch?v=rJQVwwRxPv4
Mar 14, 2013 - Uploaded by ITJungles
Learn how to fix the Canon printer error 5100, and have your printer running again. ... Reset error Canon ...
Jan 05, 2016 | Canon PIXMA MX340 Wireless Office...
Canon pixma mg2120 error 5100
I just bought this Canon PIXMA MG2120 PRINTER about 2 weeksago, I've been able to print untillast night, it's giving me error message 5100, what do I do to fix this?
Jul 15, 2012 | Canon Office Equipment & Supplies
ERROR 5100
you have a carriage error thats what the error code refers to.
can depends on a lot things but usally not worth fixing if its done lots of prints
canon tech
Apr 09, 2009 | Canon PIXMA MP150 All-In-One InkJet...
PIXMA iP8500
Error 5100 on Canon Pixma iP8500. flashes orange 2 times. Sounds like the paper isn't being picked up. But I don't know how to fix it.
Jan 03, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Canon ip2000 service error 5100
I have been facing same error and this was the solution.
Canon Error 5100
Sep 08, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
940 people viewed this question
k24674
jasbo
jasbo
