Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
I'm trying to hook up a honeywell touchscreen thermostat and need to know what wires go where.
  • carl carpenter
    carl carpenter May 11, 2010
    what are the color of wires and did you remove old tstat yet
I have a vison pro th8320u and i cant get aux heat to operate also aux heat on will not come up on the touch screen.
Posted on Jan 10, 2009
2 Suggested Answers
  • 70 Answers
SOURCE: Install a digital Honeywell thermostat
What kind of system do you have (furnace with heatcool, heat pum or boiler )? Is there a themostat there now. How many wires does it have. If you have a furnace and you have heat&cooling install red wire to r on thermostat white wire to w and green wire to g. The g wire is usually for the fan. If there is a thermostat there now the old one should have the same letters on the back by where the wires hook up. The color of the might be diffrent than the ones i used for an idea.
Posted on Jan 18, 2009
My heating unit does not have C connector to put my G wire on. What do I do
What is the make / model of your heating unit. With out that information i cant help you with your ac repair problem. If you have any other AC Repair Questions don't be afraid to let us know.
Jul 06, 2016 | Honeywell Rth8500d 7-day Touchscreen...
I would like to know how to wire honeywell dt90e thermostat which wires where i have 5 wires from wall
It helps to know which wires went to the terminals on the old thermostat, if it had one. Otherwise, you would really need to know how they are hooked up inside the furnace/air handler. Some technicians hook them up differently, but I can give you the basics and most commonly used wires. R terminal- red/power wire G terminal- green/ fan wire Y terminal- yellow/ cooling or condenser wire W terminal- white/ heating wire C terminal- blue/black/ common or ground wire If you have a rc/rh terminal, they are usually jumpered with a small wire and your power wire still hooks to that. Hope this helps and good luck!
Jun 25, 2011 | Honeywell Heat/Cool Thermostat
I am trying to replace my honeywell T834C2499 with a programmable RTH221. I have hooked the wires as follows: G to G, W to W, Y to Y and R to Rh - leaving the jumper between Rh & rc. My problem is that...
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
May 31, 2010 | Honeywell Programmable Thermostat Heater
Hooking up new thermostat to new furnace
Letter designations for honeywell tsats R=24 volt power, W=heat, Y=cooling, G=fan, C=common wire for the 24volt power to tstat. Generally R is the red tstat wire and so on. Blue tstat wire can be hooked up to common at the tstat. On the heater the blue tstat wire would be hooked up to the C terminal. But this also depends on the manufacturer of heating unit.
Jan 22, 2009 | Honeywell Programmable Thermostat Heater
Jan 17, 2009 | Honeywell Programmable Thermostat Heater
Replacing aging erratic honeywell chronotherm III
Hi, your replacement part can be purchased on amazon, take a look here: Amazon com honeywell chronotherm III thermostat. I hope this was helpful. Cheers
Nov 30, 2008 | Honeywell Programmable Thermostat Heater
Honeywell TH8000 5 wire
7wires? wtf with that! how many things you got runnin there. you need to give way more info to get a decent reply.
Feb 04, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
130 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
