Bosch washing machine modelwfl2450
Starts to fill with water then drum should rotate but nothingelse happens?
  • 15,935 Answers
It appears your timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Bosch error E24 after 2 minutes into cycle, along with grinding noise.
Bearings or a belt have gone bad on the drum. After water fills and the agitator starts the drum begins to move and that's when you hear the grinding. error code stops the machine from further damage.
Jul 19, 2016 | Bosch Washing Machines
Why do the capsules not dissolve properly
Liquid washing capsules should be placed at the very back and bottom of the drum. This is where the water enters the drum first and gives the capsule casings more time to dissolve before the drum starts rotating. If you throw the capsules in after loading the machine there is a good chance they won't fully dissolve.
Jan 14, 2015 | Bosch Washing Machines
I have a bosch washing machine Maxx WF1200.The machines fills with water than stops. Nothing happens. Also does not spin to release the water. What is the problem?
If the machine heats the water and finishes the cycle without the drum turning it is most likely your motor or what controls it.
Sep 30, 2014 | Bosch Washing Machines
Have a Model 100 bosch washing machine will fill but does nothing after that .Doesn't seem to wanna spin or move Drum/
Try rotating the load size / water level selector switch back and forth. If this works, then your switch is going out. If it keeps on filling and doesn't stop, then your selector switch OR the level sensor (both located in compartment behind controls) is bad (probably level sensor).
The motor is locked out until the water level requirement is met, then the level switch allows the motor to be turned on.
Sep 10, 2010 | Bosch Washing Machines
Bosch WFMC 3200UC can't rotate the drum
that test indicates a faulty speed sensor or wiring harness.
Jan 23, 2010 | Bosch WFMC 3200 Front Load Washer
Washing machine wfm 2010 not rotate just fill and drain water
sounds like the carbon brushes in motor,Or motor has had it.
Oct 11, 2008 | Bosch Washing Machines
Bosch WFMC3200UC
I'm having a hard time understanding what is happening with my Bosch. Mine is filling and then immediately emptying out. Then the door unlocks but the timer indicates 45 minutes left (or so) and the door lock light is still on. Usually the only cycle that spins now is the spin cycle, but this doesn't help me get the soap out of the clothes still in the drum.
When the machine fills but doesn't rotate, the water level seems low as well. I had a repair man out who thought it might be the door latch sensor needing replacing (honestly, my toddler was pushing that button repeatedly), but I don't think that's it.
What does work: I unplug it for a while. Then if I'm lucky and the laundry Gods are shining down on me, I can wash normally (usually I'm luckier on Permanent Press but I always used to use the Cotton side). However, once I turn the machine "off," that's it all the problems persist so I have to wash it all, one load after another.
Jul 25, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch WFX Excel
You have to replace the water inlet valve, the valve where water enters your machine.
Jan 22, 2008 | Bosch Exxcel WFX 2467 Front Load Washer
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
