Question about Power Acoustik Car Audio & Video
Bamf 2200 overheating - Power Acoustik Car Audio & Video
2 Suggested Answers
raberd14
  • 60 Answers
SOURCE: My power acoustic BAMF 2200 amp wont power subs
Check all of your connections, make sure your RCAs are hooked up correctly, and aren't pinched anywhere, make sure your subs are hooked up right, and making good contact, if the amp turns on and doesn't go into protect mode it should be alright. If you can't get it going, take it to an audio shop and have them test it...
Posted on Sep 18, 2009
Can you bridge a bamf 5500 to two mofodvc2 15's speakers that are wired at two ohm? If so how do you do it?
The BAMF 5500 is 1 ohm stable, so if each sub has their respective DVCs wired as 2 ohms, connecting the subs to the amp in parallel will give you 1 ohm on the amp.
May 04, 2015 | Car Audio & Video
My power acoustik bamf 2200 amp keeps blowing its fuses, why?
another couple of things is a bad ground wire. a sub going bad( causing a different ohm load then before) ive run into a bad fuse link in the amp before as well
Aug 04, 2014 | Power Acoustik BAMF2000/1D Car Amp
I have a power acoustik bamf 1600/4. not working 5 hours later
use a multimeter to see if the amp has good power wire and remote turn on voltage. then check the ground and make sure its a good strong ground. check the sub to make sure its not bad. make sure it reads whatever ohm its supposed to. anything less than 4 ohms will clip the amp if bridged. if alll that is good then the only thing left is the amp. it sounds like the power supply is bad but check everything else just to make sure. good luck.
Dec 29, 2009 | Power Acoustik BAMF1600/4 Car Amp
Sep 17, 2009 | Car Audio & Video
When I bridge the BAMF 2200/2 Power Acoustik amp it cuts off
Hello munchisfun,
I'd suspect that the amp is operating into too low of an impedance and going into protection.
The 2200/2 is not rated to drive a 2ohm load when bridged (most 2-channel amps aren't) and when you connect 2 4ohm subs in parallel, the load is 2ohms. I'd run one sub from each channel.
Hope this helps.
Jul 26, 2009 | Power Acoustik BAMF2200/2 Car Amp
My 99 malibu is overheating after a headgasket job.i need possible solutions. thermost?
aluminum heads may be worped. have them checked and possibly reground to a flat surface.
May 14, 2009 | Dell Inspiron 2200 Notebook
OVERHEATING 99 MALIBU
could be hydraulic lifters need cleaning, depends on car, engine, condition,it should tick like that if it didnt before. take it back!
May 10, 2009 | Dell Inspiron 2200 Notebook
Connection overheating
If it is the external adapter that is overheating and stopping after a while yes, replace it immediately. Fact that power adaptor is overheating means that there is a short inside the adaptor, this may damage the laptop, then change it as soon as possible.
If the laptop itself is overheating, check if the cpu fan is working, and eventually replace it.
regards
Mar 19, 2008 | Dell Inspiron 2200 Notebook
Car Audio & Video Logo
18 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Jose Velazquez
Jose Velazquez
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
