Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA rear projection TV power light blinks for a few seconds but
TV does not come on started as intermitent now is permanent
  • RCA Master
  • 5,138 Answers
Look on Deflection board If cp150 capacitor is puffed up on top it is bad there is 3 caps to replace cp150(,2200uf 16v ) cp114,cp120.(220uf 35v). The SSB board can also shut set down.
Posted on Jan 04, 2009
I have a 60" RCA D56W02B rear projection TV. I've
Yes,the power supply board,where the actual power a/c cord plug into it,are most of the causes of power LED light blinking problems.
Feb 17, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W19 52 doesn't power up and have a picture
press and hold the power button for a few seconds. it should blink some codes. does your tv try and power itself on a few times. does it not show power at all. need more info to determine cause.
Jun 13, 2010 | RCA D52W19 52" Rear Projection Television
I have an RCA D52W20 with chassis ATC 221 that no longer works. When plugged in, the green power light blinks twice and then goes out. When the power button is pushed the light blinks twice, then about 4...
The tv is going into protection shutdown. It will try to power up three times, but each time it tries, the microprocessor recognizes an overvoltage, or overcurrent draw, and after three attempts it will place the unit into protection shutdown. There can be many causes of this, but the most likely one is that there is a short circuit in the high voltage circuits. You probably have a shorted flyback and associated components.
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power switch doesnt work. It blinks for a few seconds then turns power button goes off all together. Tv wont turn on at all.
Hi jenna;
We need a little more info like Brand, Model # and how many times the light blinks.
Good luck
Buck
Nov 14, 2009 | RCA D61W20 61" Rear Projection Television
RCA D52W20 52 in. Rear Projection HDTV power light blinking
Liz, yes it is a power supply problem, better question is; low voltage or high voltage power supply ? count the blink code, it should repeat the code, once you have the code call your local tv shops and give them the model number of your tv and the blink amount and they`ll tell you price to fix, gl, video-tek
Jun 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a similar problem with the Sony 60" wega SXRD rear projection TV. The green light blinks on the power/display LED and the picture comes on for a few seconds and then the screen goes black . Then the...
I believe 4 blinks is fan error. You can take back off and watch fans in particular the fan for the lamp (this one goes out the most) The TV has a sensor so it knows if the fan turns.You can take a pencil and use it to spin fan sometimes that will jump start it (not a permanent fix just a test). You can try cleaning dust off fan and replugging the connector on the wires coming from fan.Might fix it if not fan will need replacement.
Apr 27, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Need solution
Appreciate the direct "Ask Me".
Your concern with an RCA D52W26 is when you attempt to turn it on, it powers up as indicated by the LED lights but they then power OFF a few seconds later? or it powers on then you get to see bright line(s) left to right, then the TV powers OFF? or it powers on but only bklinking LED lights? If yes on the last any sequence to the flashing/blinking?
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 28, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52" rca projection screen tv
If the light blinks 3 times its most likely the flyback. Your model uses flyback 259296 and you can get a replacement at the following link and they have free online instant messageing with a tech when you replace the flyback so they can take you step by step while you change it. Hers the link its flyback 259296.
http://servicemanuals.vstore.ca/
Aug 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W23 tv will not work
does the power light blink? If so how many blinks does it blink
Jun 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
108 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
