Question about CTL Tablets & eReaders
Classmate NL1 tablet all drivers - CTL Tablets & eReaders
How to check for missing drivers
Adb Drivers in windows for interfacing with the tablet or drivers within the tablet?
If its within the tablet you will need to shell su and have the device rooted - In other words you will need to be technically savvy and good with linux command line!
May 12, 2014 | Craig CMP741d Tablet
Noria driver not working
Hello..
install Nokia Cd. it'll come along with phone box.. there u might fin the USB driver.. install it or download the Drivers
Apr 06, 2014 | Noria 7 Android 4.2 Tablet - White
Need usb,drivers for xp .So i may hook tablet up to my pc.Thank you anyone can please provide me with this .I thank you so much.
Hi the drivers should be installed when you connect your tablet to pc, look for icon in notification area when you connect the device and also check tablet. It should recognize it as a storage device.
Apr 03, 2014 | Craig CMP741d Tablet
My intel classmate pc was lock by 10 code machine?
Try this:
On the screen where it says "Sorry, the computer boot certificate has expired and the machine is now locked" press "DEL". Now it says "Entering setup" but nothing happens. Then press "CTRL+INS" and you will enter setup. Now change the year to the year 2000 and save the changes. Your PC should now boot normally until tou change the date again. I have found no solution to that yet,
Jul 24, 2012 | Mirus Intel Classmate Touchscreen 89''...
How do I replace monitor?
Hi Ken,
Replacing a monitor on a laptop should not be attempted unless you have prior experience with it. Laptops are very tricky and attempting to replace the screen yourself could damage the laptop further. If you are comfortable attempting this, please let me know and I will help guide you through it, otherwise please take it to a reputable computer repair store for assistance.
Cheers,
aexl
May 22, 2012 | CTL 2go Classmate Convertible Pc Nl2 Dark...
After formating using window xp,cant find sound drivers
You need to install all the necessary drivers to your Tablet PC, including the Sound Card Driver & Video Card Driver to be able to use properly your Tablet PC. Use the installation disk that came with the product when you've purchased it.
Apr 05, 2011 | Toshiba Satellite R15-S822 Tablet PC
Can't use tablet option in M200 (is there a stand alone driver?)
yes it can be done,
you need the tablet pc driver from wacom.com
i use only normal xp not tablet and the touch screen and pen work 100%
so go yo wacom.com search there drivers and you should find it,
i did answer another post with a similar problem and gave the exact driver details so search other problems and you should find it.
hope that helps
Feb 14, 2010 | Toshiba Portege M200 Tablet PC
Where can i download sofware of gateway
For your tablet to function again, you'll need the WACOM tablet driver which is NOT provided by Gateway, since they do not manufacture the tablet themselves.
You'll need the following drivers from the GATEWAY site to fix your button issue:
9524572.exe - Gateway M275 Button driver, version 5.01.2600.2156
and from the WACOM site you'll need the Tablet PC driver.
-Go to www.Wacom.com
-Select your location and language on the right
-On the next page, choose downloads from the top navigation bar
-In Step 1 scroll down and pick Tablet PC
-In Step 2 choose your operating system
-Follow the download instructions provided on the site from there
Jan 17, 2009 | Gateway M275 Tablet PC
Tablets & eReaders Logo
97 people viewed this question
Top CTL Tablets & eReaders Experts
Are you a CTL Tablet and eReader Expert? Answer questions, earn points and help others
