Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Problem for Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA,...
Seagate Freeagent 500 GB does not detect
By manjit21 on Jan 04, 2009
Dear ... I have recently purchased Seagate's Freeagent External Hard Drive (500 GB Capacity). It was working all right for about 10 Days, but now I face a peculiar Problem. This drive does not show in the My Computer at all. I tried connecting it on several (about 6) other PCs and Laptops and this is what exactly happens - 1. When I connect it to a fresh PC where it has not been connected earlier, The PC starts the New Hardware found procedure. 2. It shows, "New Hardware found", "Seagate Freeagent Found" etc., then suddenly either the PC hangs or simply reboots. 3. There seems to be nothing wrong with the External HDD's Power Supply or the USB cabling, as both have been thoroughly checked. All the above PCs/Laptops were loaded with Windows XP + Service Pack 2 The HDD's LED glows as usual and does not sho any power problems. I feel that there is some virus activity that stops this Drive from giving access (Maybe some boot sector Virus) Pls help. With warm regards, Manjit Singh New Delhi
Same Problem
May 03, 2009
-   i have use 500 gb hdd after 2month hdd dos not dedect in my pc/other pc maybee sum voice cut,cut in the hdd what i can do for my importent data .
thanks
-   hanifkhan34
Mar 23, 2009
-   same issue can not be detected by win xp -   Guest
Jan 25, 2009
-   yes i got same problem on my computer -   rajesh745
Jan 12, 2009
-   I have a very similar prob. I was transferring files from the Free Agent, when suddenly I got an error bubble in the task bar saying
E:Mft cannot be found. The data has been lost.
I could find directories on the drive, but they appeared emty. Upon reboot, the drive was not found in My Computer, device manager or anywhere else. I can hear the hard drive working, but cannot detect it. The power lights turn on and stay on solid and will still shut down. Any ideas?
-   olGabby
Solution #1
posted on Mar 21, 2009
Somewhat Helpful)
rakshit2001
Rank: Master
Rating: 78%, 9 votes
please format theExt HDD as soon as possible
Was this helpful?
Yes
No
Solution #2
posted on Mar 23, 2009
Not Rated)
xiaolaba
Rank: Guide
Rating: 75%, 3 votes
if USB does not goes away, only 1394 has this problem, you can check the following to ensure the grounding is ok in between PC and FreeAgent Pro.
http://hk.myblog.yahoo.com/xiao-laba/article?mid=1861
Was this helpful?
Yes
No
Popular Solutions for Seagate FreeAgent Pro - 500GB,
Questions and Unsolved Problems for Seagate FreeAgent Pro - 500GB,
Do you recommend Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive?
Answer
Answer
The socket where I connect my USB cable to the Seagate Freeagent Drive has fallen off so I cannot... (More)
Answer
i dropped my Seagate Freeagent 1.5 TB drive and now my Mac won't recognize it.
Answer
I have a 500GB External HDD (Seagate made in china). I need a driver for it.
Describe your Hard Drives problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Hard Drive Experts
Top Computer & Laptop Repairmen
in Newport, KY
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
