Question about Watches
Casio aq 160 how do I adjust the band? - Watches
  • Thomas Langham Nov 02, 2012
    Figured it out. Not easy. Just have to drive the pins out with something very small. I used a cut-off large safety pin. Once slightly protruding, pull out with pliers. No inner sleeve. Nothing about this on the Casio website.
  • 4 Answers
SOURCE: how to adjust metal wrist band on casio watch?
  1. Pop out one spring pin to disconnect the band from the watch or from itself at the clasp. If you don't have a special tool for this, a needle or a pin will probably work. A straightened paper clip may be too thick, but they are cheap so you could try it. Now the watch and band can sit flat on the work table.
  2. Examine the links. If some of them have little arrows on them (usually the ones closest to both sides of the clasp), they are removable.
  3. These removable links are held together by a "U" shaped (actually a squared off "U" - sort of like this |_| ) pin that is inserted into the link. There may should be some kind of window-like opening in the link into which you can insert a narrow screwdriver or similar tool or even a small nail (around 6-penny size) and push out the |_| shaped pin. A straightened paper clip is probably not sturdy enough, but you could try it. Push in the direction of the arrow (from tail to point). The links that were joined by the |_| pin can now be separated.
  4. Remove a second such pin from another adjacent link. Now a single link is free and can be discarded (or kept). Reconnect the remaining adjustable links with one of the |_| pins and re-attach the spring pin from step 1 so the band is reunited with itself or with the watch.
  5. Try it on. If it is still too long, repeat the process. Good luck.
Posted on Mar 24, 2009
SOURCE: ADJUSTING ANALOGUE CLOCK
Keep pressing 'select mode' button until you get to H-SET. Than hold 'adjust' button until screen starts to blink. Now you can adjust analog clock by pressing 'start/stop (search)' button. When you are finished, just press 'adjust' button once. That's all.
Posted on Apr 24, 2009
  • 12 Answers
SOURCE: Adjust-a-Casio-S-1087DY-Watch-Band
On most brands, there are pins that form hinges for the links of strap. You need to push them out to remove links. Usually you would find arrows marked from inside of the metal bracelet which show you the direction in which to remove the pins. You can remove it if you have a small watch maker's screwdriver but you have to be careful. or get one of these ..
http://www.amazon.co.uk/Watch-bracelet-link-adjuster-remover/dp/B001ZKIL2S/ref=sr_1_1?ie=UTF8&s=watch&qid=1254695541&sr=8-1
which should help you to remove the link pins safely without scratching.
Posted on Oct 04, 2009
SOURCE: casio pathfinder SPF 70-s titanium band adjustment
I purchased a Casio Pathfinder solar/atomic watch, with compass, altimeter, barometer, thermometer, model 1200T-7WC (titanium).
Has the titanium band - on this particular band each link is somewhat waveshaped {i.e., there are 2 "arms" from the link making contact with the middle part of the link above (above meaning towards the watch body), and 1 arm fitting between the 2 arms of the next link down). Unlike described in the first solution, the pin is not split, but solid (doesn't look like a slotted screw on 1 end, so the solution at http://www.wikihow.com/Adjust-a-Casio-S-935L-Watch-Band is no help). Here's what to do if you have this band:
1. Note: before you start, be advised there is a tiny loose 1/8" part (sleeve) that will fall out as you pull the links apart, so work over an appropriate surface to "catch" it. Push pin (from the upper "arrow end) of one of the removeable links (those with the arrows on the backside) out of its hole with a fine poker (I used a 1/32" jeweler's screwdriver, an unbent paperclip would also work, just more likely to bend as you push pin out). This takes some force to do - in my case, after pushing, the pin projected out about 1/2 of it's length, I used needle-nosed pliers to gently pull it out the rest of the way). CAREFUL - once pin is removed and you pull the link away from the one above, a small (1/8") constriction sleeve should fall out of the center arm of the link above. SAVE THIS SLEEVE!
2. Using the same procedure, remove the pin from the bottom end of the link you're removing. again, SAVE THE SLEEVE.
3. to rejoin the band once the link is removed, look at the single/middle "arm" of the upper link, looking for the hole where the pin goes through. One side of the hole should be noticeably larger/wider than the other side - this is where you will place the SLEEVE - I used tweezers, or needle-nosed pliers will work - it will drop into hole. Keep this upright so that sleeve doesn't fall out, and slide the 2 arms of the lower link in place around the center arm.
4. Slide the pin you removed into one of the outer link arm holes - I found it easier if I started from below, pushing it into the center arm - it will stop when it reaches that 1/8" constriction sleeve. I set the extruded end on the pin on a magazine (i.e., slightly padded surface) and then pushed the top side of the band down, forcing the pin through the constriction sleeve and up into the upper arm hole, and Voila, your band is reconnected. The sleeve is important (without the sleeve in place, the pin will simply fall back out).
Posted on Mar 07, 2010
  • 2501 Answers
SOURCE: how do i change the analogue time for my Casio Aq-180W-1Bvef Mens
If you haven't got instructions on how to do this, you can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Posted on Apr 11, 2010
Testimonial: "Thank you very much this is exactly what i wanted "
How do I adjust the band on a Casio AQ 160 watch?
try this link below there are several diffarant band adjustments that may help you
http://www.watchmaterial.com/How_to_size_a_watch_band.asp
Nov 02, 2012 | Casio Watches
How do i adjust my casio illuminator 3793 AQ-180W
This watch actually is very complicating. It took me a year just to get use to it. Just hold the adjust button (top left hand button) until the seconds starts blinking. Then you can adjust the time, date, telememo, the alarms and the timer
Oct 23, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
How do I set a casio digital-analog watch, model aq-160?
you can get
watches;
Accept terms
Oct 03, 2010 | Casio Watches
English Manual for the Casio watch model AQ-163W-1B1JF
You can get instructions from the Casio web site.
Select "support" and the "manuals", watches;
Accept terms
Click on "search" and the download your instructions.
Feb 11, 2010 | Casio Analog Digital Chronograph Alarm...
The strap is broken on casio watch
I had exactly the same problem with exactly the same model watch, and it happened to me twice. The AQ-160 is the important part of the model number as far as replacement parts are concerned. The first time, I took it to the shop where I bought the watch, and they replaced the band, but it cost me $50. The second time, I looked up the Web for the master agent for Casio in Australia, and they said I could buy the end piece, not the whole band, for $6. I found I could replace it quite easily myself by using a drawing pin to remove the spring pin that holds it together. A bit fiddly to reassemble but not too bad. In fact, I didn't wait for the new part to arrive, just used the unbroken end of the old band. So now I have a repaired band plus the old band and a new end piece, in case it ever happens again.
I really like this watch, but it is a pity the bands are so weak.
Aug 14, 2009 | Casio Watches
Adjust the band links for Casio MTP4500D-1AV ( model #4755 )
You can tap out the pins in the band with a small punch. a ground off needle may do it
Jun 22, 2009 | Casio MTP4500D 1AV Analog with Chronograph...
How to change the time
You can find the instructions at this web site http://www.casio-europe.com/euro/watch/collection/aq-230ga-9dmqyes/ :)
Jun 05, 2009 | Casio Analog Digital 2 Time Silver Metal...
Feb 18, 2009 | Casio AQ163WG 1BV Casual Sports Watch with...
Band size adjustment
Try entering Casio`s page and search the manual.
Jul 29, 2008 | Casio AW80-7AV Wrist Watch
Casio AQ-161 combi watch - unable to set the digital time
The Casio web site has all manula on line. The model no is 3352
Good luck
Jun 25, 2008 | Casio Watches
Watches Logo
43 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
