Question about Dishwashers
Maytag quiet series 200 won't drain
Washer will not drain
  • 6 Answers
SOURCE: quiet series 300 maytag water won't drain
This is more of a tip than a solution as I am having a partial-draining problem and have discovered by accident how to have the Quiet Series 300 "drain only" (which is not an option on the control board and the manual doesn't seem to address this).
TIP 1:  The "drain-only" function can be activated by selecting "Rinse Only", pushing the "Start" button, and then pushing the "Start" button again (which cancels the start).  This activates the drain pump which will drain any remaining water.
I think I might have a partial clog below which I have been able to access so far as I removed the top drain cover (3 --I think the term is star screws) and used a screw driver to take debris out from between the drain blades.  This improved things but didn't solve the problem. As of now, I just completely drain the machine by cancelling the "Rinse only" as described in TIP 1 above.
TIP 2: If you don't have a star or hex screwdriver, you can pick up one very cheaply at a discount store (e.g., Odd Lots, Marcs, or even some Dollar Stores).  Check out their tool section.  I've bought a bunch of stuff, sure it is not the highest qualilty, but how often do you use most of your tools?  I bought the star-screwdriver set for about $1-2 and will probably use it 10-20 times in my lifetime. I bought it to change a bulb in out minivan and have now used it again.  In my cynical opinion, more and more companies are NOT using straight or phillips-head screws as a way to force many to use their repair services.  I'm not a professional, just a guy who's using the internet to feel his way around in the dark.
Posted on Mar 25, 2009
SOURCE: Maytag Quiet Series 300 Dishwasher will not turn off after it com
MY DISHWASHER KEEPS RUNNING, IT IS A WHIRLPOOL GOLD QUIET PARTNER IV
Posted on Apr 06, 2009
StarGGundam2
  • 24 Answers
SOURCE: Maytag Quiet Series dishwasher won't start
Sounds like you have a bad Control Board
http://www.partstore.com/Part/Maytag/Maytag/MDB6600AWW/Maytag/Maytag/99003160/New.aspx
But with the price it cost, you might be better off buying a new dishwasher, preferably a different brand, cause that washer has some bad reviews
Posted on Oct 12, 2009
  • 10865 Answers
SOURCE: Is there a reset button
Go to the electrical panel of the house or apartment and turn off the power to the dishwasher for two full minutes, then turn the power back on. This will reset it. J.
Posted on Sep 23, 2010
SOURCE: Maytag Quiet Series 300 owners manual
my dishwasher does not want to work anymore it has a big L flashing
Posted on Sep 28, 2010
Maytag Quiet series broken?
Check the door switch.
May 03, 2013 | Dishwashers
Maytag quiet series 200 dishwasher spray arms won't turn
Have you tried tighten the spray arms? They may have come lose at the fittings so need to be tightened up. You can normally tighten them with your hand. Take any traps/filters out of the dishwasher and clean them.
You may find answers here: https://www.maytag.com
Jan 15, 2013 | Maytag 24 in. MDB4000 Built-in Dishwasher
I'm moving and need to drain the washer. How do I
What is the model number of your unit?
Nov 03, 2012 | Washing Machines
I have a Maytag Quiet Series 200. In the beginning of the cycle, it makes a weird 'whirrrring' noise that goes away right after the first wash cycle. It's getting water. It's very noticable and I worry...
I have a quiet series 300 and it does that, too. I think it just balances the load before washing and is normal. I found this in the manual:
Normal Sounds
Your new washer may make sounds your old one didn
Sep 05, 2010 | Washing Machines
I have a maytag quiet series 200 type 777-0 when i push the start/cancle it will not start?
We had the same issue with our Maytag quiet series 200 dishwasher. The Start/cancel button would not work all the time. We ended up removing the front panel from the machine and on the backside of the panel there is a plastic ultra thin ribbon cable that runs from the computer box to the push button control panel. We wiggled the ribbon cable and the start button began to work, but only if the ribbon cable was held in a certain position. So we super glued the cable in that position and it's been working consistently now.
Upon closer inspection the ribbon cable appeared to have 3 or 4 very tiny dark spots on the wires.
That would indicate to me that somehow moisture slowly eroded the tiny wires and bending the cable made the connections touch again, but for how long it will work like this is anyone's guess.
Also, it appears that the ribbon cable is permanently attached to the push button control panel. So you can't replace the ribbon cable itself without buying the hole front panel.
Aug 19, 2010 | Maytag Dishwashers
Maytag MDBF750AWZ, Quiet Series 200 - sticking, stiff door handle
There are lot of handy sprays available. Try your super market or the hard ware stores where plumbing materials or sold.
May 03, 2010 | Dishwashers
Oct 12, 2009 | Dishwashers
Maytag Quiet Series 200 Electric Dryer
I also had a similar problem with my maytag dryer which is 3 1/2 years old. It was the idler lever assembly with pulley. The part number is 11222607JG and the cost is about $20.00. Hope this helps.
Apr 04, 2009 | Maytag Dryers
Dishwashers Logo
89 people viewed this question
Top Dishwashers Experts
Owen Barnes
