the same problem happened to me, and i just pressed the sync buttons on the guitar and the wireless adaptor at the same time and let it sit. it started syncing fine after that. I hope i helped! :)
okay, try this:
1. Start up PS2 with no disc
2. select 'Browser', press triangle.
3. select 'Console', press triangle.
4. select 'Diagnostics', press X, select 'ON'.
5. press 'O' to back out of this menu.
6. select 'Playstation Drive', press triangle.
7. select 'Disc Speed', press X, select 'FAST'.
8. press 'O' to back out of menu.
9. turn off PS2.
10. insert disc.
The Diagnostics should run and automatically
adjust your PS2 to play the game.
I got this "FIX" from someone who had the same problem. Hope this helps :D
The discs are flawed. Activision
has worked with Nintendo to improve the audio experience and has
re-mastered the game. They are offering Wii consumers who have Dolby
capabilities or audio issues free replacement discs.
Customers based in North America that want to register for a free replacement disc can call (866) 780-8286 from 8:00am-8:00pm EST, Monday-Friday, or register online at the following website http://www.activisiongameexchange.com/.
First of all, make sure the card is in slot one. I'm not sure about Guitar Hero 3, but I know many games default to searching the first slot (the one on your left as you look at the system).
Assuming that's not the problem, it could be a sign that your memory card is wearing out. Do you have a second memory card? If not, I suggest getting one. Either way, put one card in each slot, and go into the browser. Copy the Guitar Hero saves over to the other card, then put that card in slot 1 and see if it works. If it does, I suggest copying all your saved games over to the new card, and throwing the old one out before you lose any save games permanently.
Is the guitar wireless, if it is check the batteries.
My friend had a problem with his guitar hero 3 game and was forced to take it back.
Before returning it though and again this only applies if the guitar is wirelss. Have you synched it with the console.
The little button just next to the memory card slots needs to be held in for a few seconds and the same needs to be done on the guitars sync button. If you get 4 gree rings of light when you try and turn the guitar on i'm almost certain its the fact that the guitar isn't synchronised with the console.
i'm having the same problem. theyre not playing bass because it's on face off and pro face off too. it's also not the gh 3 disc because it does the same thing to me on gh 2 and rocks the 80s. it has something to do with the ps2.
I'm using the slim... maybe it is the type of memory card but guitar hero is the only game I've had a problem with. I just restarted the game and then beat it over again. After it said that there wasn't any data and I chose to make a new one, it said that there was data but it was corrupt. Hopefully it doesn't happen again, but I haven't had any trouble since I started over the other one.
