Question about Acer PD100 Multimedia Projector
Controls not working
The projector turns on and off but none of the other buttons work. I have tried using the remote and the buttons on the projector but these are not working. So there is no way to choose a source or view the menu items.
  • 3 more comments
  • towilco Jan 03, 2008
    My projector shows No Signal and I can't get into the menu
    The remote nor the onboard buttons operate.
  • frenchy_ber Jan 09, 2008
    After I changed the lamp, couldnt do a thing...
  • BakerJon Jan 29, 2008
    Project does not find device to connect to. Onboard controls do not work.
  • Anonymous Feb 07, 2008
    which buttons to advance slides?
  • wallini Aug 14, 2008
    Acer PD125. Only the POWER and HIDE buttons wrk.
    Stuck on Initial ACER screen image.
This is apparently a common fault and the unit must be returned to a service centre. Theyll put in a new motherboard for it and unless its under warranty this might actually be more expensive than buying a new unit.
Posted on Apr 04, 2008
My pioneer remote XXD3086 shows the display ,but doesn't function
clean the remote with an alcoholic solvent then try to look for any loose joint mostly near the LED transmeter then use your mobile phone camera to check whether light is visible when you press the remote buttons while directing it to the camera
Aug 03, 2014 | Pioneer New Original XXD3086 Remote...
My Panasonic PT-LB20NTU Multimedia Projector i locked my controls on the menu button and now it wont poer on and none of the buttons work
Use the remote control and press the MENU button and select the OPTION with the UP and DOWN arrow buttons. Press ENTER button and then press UP and DOWN arrow button to select CONTROL PANEL use LEFT and RIGHT arrow button to VALID the control panel buttons
If you have a loss of the remote control while the control panel is invalidated.
Press and hold the MENU button for 2 seconds with pressing the ENTER button to enter the MENU and VALID the control panel.
Nov 19, 2010 | Panasonic PT-LB20NTU Multimedia Projector
Remote won't turn on Eiki EIP-2500 projector
Try cleaning the IR port on the projector (and the remote itself). These can get enough of a dust layer build up that they can't "see" the infrared signal being sent.
Feb 08, 2010 | Eiki EIP-2500 Multimedia Projector
Projector screen displaying "Searching" message. Does not recognize computer. Worked with one of your associates (Guru?) and we tried a number of solutions but none worked. She asked that I come back to...
If you are connecting to a laptop then you may need to hold the function button down and press F1, F2, F3 etc. there should be a sign with the latop on there and a sign with an external device (monitor,PROJECOR)
hope this information was useful to you.
Jan 21, 2010 | InFocus Office Equipment & Supplies
Wat buttons do i push on the projector to get the menu on screen? it can turn on but none of the buttons i push will do anything. it's a x2 infocuse projector. wat can i do to fix that?
if none of the buttons work, the plug for the button panel board may be loose. remove the rear panel and secure the plug. otherwise, use the remote to get into the menu and factory reset the settings.
Nov 16, 2009 | InFocus SP-LAMP-018 Projector Lamp for X2,...
Menu screen won't come up on screen
The "CONTROL KEY" may be set to "OFF".
In order to set the "CONTROL KEY" to "ON" without using the remote control unit, keep holding
down the ENTER button on the projector and press the MENU button for more than 2 seconds
Mar 27, 2009 | Panasonic PT-LB30U Multimedia Projector
The projector lock button has locked me out
this can only be solved with remote control or connect the AC cord while pressing the SELECT button on top.
this will cancel the control lock
Mar 06, 2009 | Eiki LC-SB20 Projector Multimedia...
RCA remote
Could it be possible that the remote needs reconfigured? If none of the buttons work, the it could possibly be that you need to re-enter the TV code back into the remote.
Sep 24, 2008 | RCA 244889 Remote Control
Wont power up optoma movie time
it's probably not this: Try using the remote to turn it on. I cleaned out mine a while ago and the controls on the main unit stopped working. Only way to turn it on now (for me) is the remote.
Feb 12, 2008 | Optoma MovieTime DV10 Multimedia Projector
Electrical Problem? Projector works, but buttons don't.
IT MUST HAVE THE CARD INSIDE THE PROJECTOR WHICH IS DETACHABLE LIKE MEMORY/PCMCIA OR ANY OTHER. CHECK USB ALSO.
May 23, 2007 | Sharp Notevision PG-C30XU Multimedia...
Acer PD100 Multimedia Projector Logo
449 people viewed this question
Top Acer Office Equipment & Supplies Experts
Steve Allison
Steve Allison
Marvin
Marvin
syaiful ridlo
syaiful ridlo
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
