Question about Air Tools & Compressors
Water separator not doing it job
I have this iwata is-925 air brush gun ,the water separator does not seem to be doing its job ,i am getting water come through the gun,when using the gun and looking at the water trap site glass the water seems to be splashed up against the glass,when i push the water release not much water comes out ie more water comes out of the gun than that what should be caught in the trap,looking at the lay out on the regulator there are 4 holes one is the air inlet which is what it is but for the hole marked out it is bunged off with a cap on the left and right which has no marking the pressure gauge is attached which operates fine on the oppisite side is the hose that goes to the gun is this the problem that i am having is this hose ment to be connected to the hole marked out one woul think so ,or does it not matter can either 3 holes be used and the water separator work on all of them ,hope you can under stand my english be good to here from you
    President:
  • 1,388 Answers
The iwata 925, although a good compressor, does not have a tank to store air and allow the air to cool somewhat before going into the water trap. For best results, the water trap needs to be far enough away from the compressor to allow the compressed air to cool allowing water to condense out. Go to a compressor repair shop in your area and have them make an air tank out of used parts and have them move the water seperator from the compressor to the remote tank. It should not cost more than thirty dollars or so. If space is a problem then just purchase an extra hose and attach an inline seperator like the one shown here: http://www.dickblick.com/zz269/23/ , Coil the hose and hang on wall. The coils will help to catch water. Be sure to empty the extra hose frequently. Good Luck
Posted on Jan 05, 2009
If your water separator is not doing the job then you have too much moisture in the compressor tank. Turn on the air relief valve to release the air. Be sure it is at a low point so that the moisture in the tank will also escape. Once the tank is completely empty screw the relief valve shut, start the compressor and then check the output for moisture. You should be good to go.
Hugh
Posted on Jan 04, 2009
I am using an iwata eclipse cs airbrush with an iwata compressor. the comopressor seems to be working fine when power, but the airbrush is not getting and air. when i push down for air release, nothing...
Air brushes us a Theory called a "venturi" in where air pressure lowers the pressure where the paint is kept and causes it to go out the nozzle. I would try seeing if there is an obstruction in the hoses to the brush and confirm that the compressor is moving air. If none of these things are an issue also while cleaning the parts may give the appearance that the item is clean then try soaking them over night in paint thinner and replacing the O-rings and gaskets.
Apr 27, 2011 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
Air compressor regulator
hi my iwata powerjet lite shut down.theres power but no performance.it only gets used for prob ten hours a week,somtimes weeks without use.is this common and expansive to repair.thank you.re ****.
May 01, 2010 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
Water coming out airbush from hose
An in-line water separator should be used before the supply line, a good air filter wouldn't hurt either.
Apr 23, 2010 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
After switching from a 1.2tip to a 1.4 tip when i
adjust the knob that holds the needle inside the gun
Mar 17, 2010 | Dmm Iwata LPH400 LVB Gravity Fed Spray...
I have some severe free flow goin on, on my hpbcs iwata eclipse
It sounds like you have a problem with the air valve. Possible deterioration of the valve material? I am not sure what they use, but if it is a rubber the cleaning thinner MAY have destroyed its properties if the cleaner got into the air path and valve.
Aug 12, 2009 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
Iwata w400 air leak behind trigger problem
Have you traced the exact spot of the leak?
I will assume you have not. the reason it's important is because if there is a crack in the o-ring seat there is nothing you can do. So trace the leak. Try a small amount of auto air conditioner leak detector or something similar even ink from an ink pen will work. Place it in the air inlet, hook up your air line and trigger your gun for a 10 to 15 seconds. disassemble your trigger and see if you can locate the offending spot. Though this method has worked for me in the past, it's not something I would normally recommend. However the gun you have is to expensive to just write off.
The alternative is to contact Iwata and seek help.
Good luck.
Jun 23, 2009 | RTO Iwata 1.4 W-400 Gravity Feed Spray...
My iwata hpc is pushing air back through the paint cup
Try replacing cup gasket first then clean all inlets and outlets completely, check that all valves operate properally, and all seals and o-rings are in good condition. Clean and lubricate adjustment fluid valve.
Jun 16, 2009 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
Spray gun leak
go to iwata site they will help
Apr 27, 2009 | Dmm Iwata LPH400 LVB Gravity Fed Spray...
Need a new paasche spray gun for bigger jobs
Anest-Iwata brand spray equipment has the most versatile line of airbrushes on the market. Im sure you will find one to meet your needs. well worth the money, it's all I spray
http://www.airbrush-iwata.com/
http://www.tcpglobal.com/airbrushdepot/iwata.aspx
check it out!!
Apr 07, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
89 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
