I have a problem with my dishwasher, when I switch it on, it knocks the electric off for the whole house! I have checked the fuse, ( ok ), changed the socket that the machine is plugged in to so that is ok, but it still happens. Help!!
The probably cause is a component in the dishwasher is leaking current to earth and tripping out an RCD. Common causes are the heater , pump and circulation pump. Also the wiring which goes into the door is prone to damage and rubbing on the metalwork of the door. You really need a multimeter to check components and isolate the offending component. It is possible to unplug individual parts , carefully insulate the wires , and see if it then trips.
I had the same problem. Rather than pay 'an expert' to come round and try and fix it I thought I'd have a look myself first to see if there was anything obvious. After unplugging, safety first, I went to put it on it's side. As I did so water flowed from the bottom.
After cleaning up and taking the bottom panel off I found there was actually an overflow well at the bottom with a trip switch. There's a float which, if this well fills with water, rises and trips the dishwasher. Now I'm not sure if this trip swtich should just trip the dishwasher only and not the whole house ... so maybe there was another issue related to the water in the well touching something else. However, having emptied the well, tidied and dried things up a bit, put things back together ... it worked.
So ... before paying through the nose to get someone to come out and do this ... try it yourself first.
Please note, I'm not an expert, just someone who wanted to see if I could fix my dishwasher on my own. Just take care making sure your dishwasher is disconnected from the power, I mean totally unplugged before taking things apart. Good luck
on any cycle dishwasher drains, then fills but does not wash - is it the main motor or could it be...
(More)
on any cycle dishwasher drains, then fills but does not wash - is it the main motor or could it be the motor start cpacitor?
When I turn the d/washer on the main switch, The pump starts trying to pump and the first cycle...
(More)
When I turn the d/washer on the main switch, The pump starts trying to pump and the first cycle light starts to flash. That is as far as it will go through cleaning cycle! I've unplugged and tried to reset but always the same problem? Thanks
My dishwasher is approx 10 yrs old works fine but does not clean - the filters are cleaned out and i...
(More)
My dishwasher is approx 10 yrs old works fine but does not clean - the filters are cleaned out and i have put a dishwasher cleaner through it
The light that indicates the salt is always on, despite that i done it twice. Plus the dishes dont...
(More)
The light that indicates the salt is always on, despite that i done it twice. Plus the dishes dont come out clean and often covered in a white powdery substance. Any ideas. I havent use it much because of it. it is such a waste of money. Thank you
