Question about Supersonic SC-301MP3 MP3 Player
Sumvision m18, 2GB
I just bought MP3 player, when I put battery in or connect to the PC a short message appears on the screen saying: starting... and nothing happens. I tried all buttons it jusy does not work. Help!
SOURCE: sumvision SV04-M18
hold down the play button for a bit and then it will say welcome
Posted on May 17, 2007
0 characters
1 Points
Sumvision cyclone not working
i am having the same problem.
can anyone explain.
Power tries to turn on but fails to come up with screen that says HELLO.
It just flickers on for a second and then powers down straight away.
Apr 26, 2010 | Sumvision Sempra PRO Digital Media Player
Sumvision Cyclone Media Player with Mac Computers
The sumvision cyclone media player is not compatible with Mac computers so you cant erase or reformat the player you will be able to put files on the player using windows xp or vista only
Jul 11, 2009 | Sumvision Sempra PRO Digital Media Player
Firmware for cyclone mmp Its the second one down where it says firmware when its downloaded extract it onto the hard drive make sure there isnt much files on the hard drive then connect to tv go to setup select firmware and press play to update.
Jun 16, 2009 | Sumvision Sempra PRO Digital Media Player
Girlfreinds old MP3 player. We have no disk and I cant get it to upload new music. Computer gives the message: 'please insert a disk in drive F:'
The driver you would need would be the one that has the same model number as yours, the mp3 player may say what model it is on the case
Apr 13, 2009 | MP3 & Digital Media Players
Is there any such thing as charging my mps nextar MA933a via the USB port? I just get sleepy z's on the display when I connect it to my computer.
Here is what I found:
Connected the player to the PC with and without prior power on successfully
OSD first displays message “Starting…” then:
Icon appears on screen with a picture of a computer monitor to right and mp3 player icon to left
When mp3 player is communicating with computer or sending information, an appropriate directional arrow appears between the two icons; when transferring files using Windows Explorer, the arrow reverses direction appropriately; when there is no activity either way, a series of “Z z z” ‘s appear on screen
Battery indicator icon also appears to right – new AAA battery resulted in a fully charged icon upon startup; no battery whatsoever resulted also in a fully charged battery icon appearing
-Tha Mp3 Doctor
Feb 02, 2009 | Nextar MA933A MP3 Player
Samsung YP-Z5F MP3 player malfunction
I have that kind of Mp3 Player too... that happened to me, but the PC was able to read mine. However, the reason why the message: "Low Battery USB Disabled" appears, is that you still have remaining battery life, but will only last for less than an hour (indicated by low light and red empty battery sign) you have to make sure the Mp3 is completely discharged. (you'll be notified when you turn on the device while it says: "Low Battery") once that it is completely discharged, you can now plug in the USB cable with the device to the PC... if problem persists, check your PC.. can it read the device? Check if a notification balloon appears at the bottom right corner of the monitor screen. It should say, "Found New Hardware... Samsung YP-Z5F..." if it did not appear, try to INSTALL using the Installation CD given when you bought the product. Just insert the disk into the PC and continue on, then when it is already installed and ready for use, plug in the device! This may be a little hard, but this is the only way I know. Feel free to ask me! I am no technician but I know a lot on devices and fine mechanics. Good luck!
Oct 11, 2008 | Samsung YP-Z5 MP3 Player
Boot Error
u have to update ur player from the sony site to solve this issue..
Jun 24, 2008 | Sony NWZ-B103FBLK MP3 Player
Sumvision SV04-M18
May 11, 2007 | Supersonic SC-301MP3 MP3 Player
MP3 & Digital Media Players Logo
21 people viewed this question
Top Supersonic MP3 & Digital Media Players Experts
Gyula Lacz
Are you a Supersonic MP3 and Digital Media Player Expert? Answer questions, earn points and help others
