Question about D-Link AirPlus DI-524 Wireless Router
Problem using di 524
Hi! i am having problem with my DI 524 wireless router. I have two of this, one is connected to the modem and i am planning to use the other one as a repeater or bridge. One wireless router's range which is connected to modem is not sufficient co'z of wide space of our house.So i decided to buy another one to extend the range of my wireless connectivity. I am expecting buying another router will solve the problem but it's not. Can anyone help me with my problem please? I want to use both of the router to expand the range. What am i suppose to do? Hope you can help me. Your response is highly appreciated. Thank you very much.
  • sxxxs May 11, 2010
    DI-524 can't be used as a repeater or a bridge.
  • 623 Answers
Ubiman is right - in order to make a router into a repeater, you need a different firmware, which is not available for your model.
Think of it like this: you would need one antenna to receive the signal from the first router, and another antenna to relay the signal to your computer(s). Since your router only has one antenna, this is not possible.
The easiest way to solve this problem is to go and exchange the router into a repeater. That's the device you actually need.
Posted on Jan 17, 2009
I Have a D-link DI-524 wireless router and verizon Broadband modem w/USB conection the G router only has ethernet connections .How can I make this Combo work?
If your Broadband modem is only with w/USB connection you have to change modem/router, you won't connect it with usb to di-524.
Jul 05, 2009 | D-Link AirPlus DI-524 Wireless Router
Can't get my di-524 router to work
no a straight are going to need to clone your MAC address on your router so that your ISP can see it.. email me at
Jun 02, 2009 | D-Link AirPlus DI-524 Wireless Router
Cannot connect DI-524 to VISTA
There is nothing on DI-524 what is Vista specific. Make sure you installed your dirivers properly. I have the same , works without problems.
Jan 22, 2009 | D-Link DI-624 Air Plus XtremeG Wireless...
Dlink di-524 connect to RV042
You need to cascade the Dlink wireless router to your RV042.
Suppose your RV042 has a default IP Address of, and the DLINK IP uses Your Physical connection is from the regular port of the RV042 going to the WAN/Internet Port of the DLink wireless router.
Once you do that, your Dlink router should automatically obtain an IP from the main router. If it did, configure your wireless settings and you should be able to connect via wireless.
This is just one way to cascade your router to another router.
For more information, click here.
Jul 21, 2008 | D-Link AirPlus DI-524 Wireless Router
Connecting to internet
you need to configure wireless on router panel using the browser.
Apr 16, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 Wireless
Yes you can, it's easy.
1. Just connect one of the LAN ports of the DI-524 to a LAN port of your other router. Leave the DI-524 WAN port empty.
2. Disable the DHCP server on your DI-524, your other router will be the DHCP server.
3. Assign a static IP address to you DI-524, different from your other router's. Example, if your other router has, you may assign Make sure that the IP address you assign is outside the DHCP range configured in your other router and that the subnet mask is identical on both.
Feb 20, 2008 | D-Link AirPlus DI-524 Wireless Router
How to connect wireless router to adsl router?
You're wanting to connect the directly connect the DI-514 to the ASDL modem to give you a wireless network, right? If so here's what you do:
Connect an ethernet line from the modem to the Internet/Wan port of your DI-514 and then you're set. I recommend you then follow the directions in the manual to setup wireless security.
If you're wanting to have your DI-514 wirelessly connect to the ASDL modem, then connect your PC to one of the LAN ports of the DI-514 and open the administrative web interface (usually located at and go to the wireless section and select "Wireless Client" and input the MAC of the ASDL modem's wireless interface (you can find this on the administration web interface of the ASDL modem) and you should be good to go.
Feb 10, 2008 | D-Link DI 514 Wireless Router (DI-514)
DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Jan 24, 2008 | D-Link AirPlus DI-524 Wireless Router
Connect to wireless D-Link and Westell6100
I am assuming that you have a functional LAN cable connecting the Westell and the DI 524, right? If you are unsure, replace it with a cable you know is good.
If the 524 is turned on downstream of the Westell modem, it should find what it wants. You may try rebooting the Westell and seeing if the 524 finds it, and you maybe should reboot the 524.
Sometimes, when the world gets jiggered up I have to work pretty hard to get my DI-524 resync'd to my DSL modem.
Oct 26, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
156 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
