Question about Dishwashers
Asko dishwasher N516 F2 code - Dishwashers
  • 351 Answers
SOURCE: Dishwasher Asko D 1776
you may need to reset the inlet time on the board do you have the instuction book,turn the power on then press the fifth button five times within 15 sec then press third button normal wash this should fix your problem
Posted on Apr 09, 2008
SOURCE: Asko Dishwasher F2 Error Flashing
i have the same problem (F2) with my 1776. they said it was a overfill sensor. I pulled to first kick plate off but can't get to the 2nd. any suggestions on how to do this? thanks!
Posted on Jul 29, 2008
  • 351 Answers
SOURCE: asko dw95.4 dishwasher flashing f2
remove the dishwasher from under the bench and tip it back to let the water run out from underneath,remove the rear panel at the bottom and run test for leaks or blockages.
Posted on Oct 09, 2008
SOURCE: How do I reset an F2 warning on my dishwasher
Hold in the start stop button till it resets
Posted on Dec 11, 2009
SOURCE: My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
Posted on Jan 19, 2010
How do I test the float switch and the pressure switch in an Asko D1976 dishwasher? Getting F2 with no water in the pan or in the machine.
i would assume be n/o.
if have VOM put on OHMS setting. touch ur leads together listen for tone. once verified it works. put on the terminals on switch. and manully switch it, to see if makes or breaks the contact
Nov 22, 2014 | Asko D1976 Built-in Dishwasher
I need a manual for my dishwasher ASKO N516 type: DW 20.2
I went to the Askousa website and located manuals for your model, the link below will direct you to select your current model, you can download all your information and manuals from this site.
I hope this helps
www.askousa.com/customer-care/technical_documentation/
Aug 14, 2011 | Dishwashers
F2 error message after dishwasher backed up when draining. Asko brand.
Hi
Thanks for using FixYa. Error F2 in your Asko Dishwasher means high water level. This error occurs due to plugged/bad water pump and/or a bad inlet valve. If the water pump and/or water inlet valve are bad it should be replaced to resolve this issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 26, 2010 | Dishwashers
Asko 3350 F2 fault meassage keeps flashing
you have a blockage try the drain spigot under the sink or the pump may be blocked.
Apr 23, 2010 | Asko 24 in. D3350 Dishwasher
Jan 19, 2010 | Asko D1976 Built-in Dishwasher
MY DISHWASHER DON'T WORK THE FAULT CODE IS f. wHAT
The F2 problem in Asko dishwasher is due to the high water level condition.The reason is bad water pump or a defective water inlet valve. you should try replacing this and your problem will be fixed.
Sep 10, 2009 | Asko Dishwashers
Apr 06, 2008 | Asko D1776 Stainless Steel Built-in...
Dishwashers Logo
47 people viewed this question
Top Dishwashers Experts
