Question about Dell W3706MC 37 in. LCD HDTV
Digital tuner frozen will not scan
Digital tuner frozen tried switching off and restarting several times to no avail.
  • 6 more comments
  • sccmillhouse Jan 26, 2009
    I have the same problem. Rescanned and got 90 channels - clicked save and after 10 minutes nothing had happened so switched set off. Since then cannot access DTT channels or able to rescan.
  • markc2502 Feb 05, 2009
    My Dell has done exactly the same, I did a re-scan and it found 113 channels, it Ok to save nothing happened for 15 minutes so switched unit off and found that the DTT no longer initializes, I have tried to re-scan but just freezes at channel 21, Dell don't want to know so I have just subscribed to Sky and using the unit as a monitor.
  • jmdalloa Feb 07, 2009
    I have the same problem as above Dell are terrible I was told to switch off TV wait 3 minutes this worked but then Dell refused to extend warranty ?? now TV digital tuner will not work it has freezed on CH 21 tried the solution but it does not work any help please
  • Anonymous Feb 15, 2009
    Dell (Hell) Knew about this problem for the past three years they have compensated all buyers in the USA including full refunds and replacement TV's but refuse to repair or extend warranties in the UK , dell asked for £1048 to repair my set, having written to dell many times I still get a phone call from the supposed great customer care telling me theres nothing they can do I contacted them when my TV was only 3 months old I was told to switch it off for three minutes and then back on again it did work for a couple of months then nothing (fantastic repair service ??) then when I asked for an extended warranty I was told the service was not available for non constructed dell tv's VERY SUSPICIOUS
  • Dave Myers Feb 19, 2009
    Same problem here - factory reset simply doesnt work and the digital tuner has ceased to function!
  • Anonymous Mar 30, 2009
    I have the same problem. Scan freezes at channel 21. No help from Dell.
  • Anonymous Apr 14, 2009
    what is part number so i too can order the piece and if poosible provide link
  • jmdalloa May 11, 2010
    sorry but this does not work as whilst pressing input source no other functions work thanks any way
While the TV is turned on, perform the following steps to hard reset the TV:
  1. Press and hold the Input Source button.
  2. Press and release the Power button.
    The TV turns off.
  3. Press and release the Power button.
    The TV turns on.
  4. Wait 10 seconds.
    A message appears saying the TV has been reset.
  5. Release the Input Source button.
Posted on Feb 05, 2009
How can i rechannel my tv according to our local tv here in the philippines?
You will need to do a channel scan to locate the local signals.
This is in the menu of the TV format. The scan will go thru all of the tuners available channels both digital and analog, could take several minutes to complete depending on your set.
Feb 05, 2016 | Televison & Video
Sony bravia no digital channels
If you've tried different antennas did you attempt to re-tune/re-scan for additional channels after switching? For digital channels to be detected they must be scanned for, so consult your manual on how to perform an automatic scan of the digital channels available in your area.
Mar 27, 2014 | Televison & Video
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
My Sony Bravia television froze on a digital picture today and now when I change channels there is no picture and no sound. I tried to do a digital scan and it picked up no digital signals,. The analogue...
Your TV has a dual tuner - one for analogue and one for digital although they are contained on the same tuner board. It's possible that the digital tuner has failed, in which case the tuner board will most likely need to be replaced, but often this problem can be resolved with a "hard" reset. Turn the TV off and unplug it. Remove all the cables from the back, leave it for at least 5 minutes and then re-connect only the cable from the tuner source. i.e aerial/antenna. Make sure you are in Digital TV mode (DTV), then run the channel scan again.
If it works turn the TV off, re-connect all of your other devices and you should be able to resume using the TV as normal.
If this doesn't work, you may need to have the digital tuner replaced. The analogue and digital channel feeds are from the same source. As the analogue channels are working there is no obvious fault with the feed or cables.
Please try this first and then post back for further assistance if needed.
Dec 23, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
How do I connect antenna for digital tv and program/scan for available channels
Hello Scott:
The unit must have a digital Tuner in it. This model do not come with a digital turner, so you are going to need a digital to analog converter box. And a High Definition Antenna. Once you have obtained these units go to your menu and select setup and switch to the the air mode and select channel scan.
Nov 26, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Not able to scan for digital OTA channels on a JVC LT-32X667 LCD
Seeing as it does not have a digital tuner in it, I would think this would be the problem, you will have to get a box for it.
Aug 23, 2009 | JVC LT32X667 32 in. LCD Television
Locked out of digital antenna in setup. I had it
1. ensure that you are on the TV tuner when you are trying to scan channels
2. if analog tuner works, but you cannot access digital tuner....the digital tuner is broken
When you turned channels before, did it switch between analog and digital channels seamlessly or did you need to press a button to acces digital channels seperately?
If you accesed digital channels seamlessly, #2 is not likely
If seperately, #2 is very likely.
Jul 10, 2009 | Sharp Televison & Video
Have a vizio lcd tv . can not get any channels today with the switch over to digital. i use an antenna
Your TV probably does not have a digital tuner connected to the DTV/ANT input. Mine didn't. I had to connect the digital antenna to a digital converter box THEN go to the DTV/ANT input. Only then would it activate the DTV menu and allow me to scan for channels. If your TV worked fine with Cable TV connected to the input, it was because your signal was coming from the digital tuner in your DVR, or your cable provider was sending you an unscrambled digital signal (not likely).
I used a digital converter box I had purchased with the government $40 coupon back in 2009 but the resolution is only 480 and looks like a Monet or Renoir. Now I am shopping for a high quality tuner.
Jun 13, 2009 | Vizio L32 32 in. LCD HDTV
Problem with digital tuner.
Talked to Hitach and yes a dicky tuner. but it's ok they will replace the tuner card but it will take 4 weeks to get one. :o(
So I have my nice new TV but I can not use it for 4 weeks
Not happy.
Jan 13, 2008 | Hitachi 42PD7800 42 in. HD-Ready Plasma...
Dell W3706MC 37 in. LCD HDTV Logo
601 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
