Question about Dictaphone Audio Players & Recorders
Need download for Dictaphone 177585 foot pedal
Need download
5 Suggested Answers
  • 61 Answers
SOURCE: Pedal problems
If the tape re-winds when you take your foot off the pedal then the auto-rewind switch on the right side of the machine at the back is set to number 3. Move it forward to number 1 or 0. If it really does rewind while your foot is on the pedal then I don't know what is causing that. Sorry.
Posted on May 18, 2010
  • 43 Answers
SOURCE: Foot pedal does not work
Make sure the foot pedal is plugged into the SIDE of the machine and not the BACK of the machine. I've seen many people make this mistake...
Posted on Jun 18, 2010
  • 5 Answers
SOURCE: foot pedal won't work with hands free microphone
The Unit will require a special port to be install for the use of an external micro phone. This company will do this for a nominal fee. www.dtpss.com 1-877-387-2838
Posted on Nov 08, 2011
  • 5 Answers
SOURCE: Dictaphone foot pedal
www.dtpss.com is a great source for foot pedals for all makes including Dictaphone transcribers, Olympus, Philips, and others.
My dictaphone is playing super fast. I do not know what is wrong with it. If anyone can help me that would be great. Thx!
Hello make sure the Speed control at front is on center if yes when is hapening make sure that you press the play button on the unit wile this is hapening just unplug the pedal if the problem get fix playing, your unit with out foot control you need a foot pedal replacement if not sounds like a bad motor I'm senting a link for a replacement pedal and a service place in case you need to send your unit to repair http://www.tvps.com/Products/ECS-IN-585-Heavy-Duty-Foot-Pedal---Pre-Owned-IN585__ECS-P-IN-585.aspx
Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Nov 08, 2010 | Dictaphone 1740 Desktop Cassette...
Foot pedal does not work for my Dictaphone model 2750 Where can I purchase a replacement
Apr 30, 2010 | Dictaphone 2750 Desktop Cassette...
Foot pedal won't work with hands free microphone
The 3750 won't let you control the telephone record jack. The only way you can get a mic to work using the Tel Rec jack is by pressing and holding the 'Tel Rec' button for about 1 second. But this isn't compatible with the hands-free operation.
If you're looking to do hands-free recording, it uses the built-in conference mic. Press and hold the 'Conf Rec' button for about a second and it should start recording. This built-in mic is located on the right-hand side of the machine near the front by the headset jack.
If you want to control the machine via a foot control while in Conference Record mode, you'll have to change the 'Foot Control Dictate' setting in the menu. Here's how:
1) Press and hold the 'Erase' & 'Search' buttons for about 5 seconds until the menu appears.
2) Scroll through the options until you get to 'Foot Control Dictate' and set this to 'Yes'.
3) Press 'Stop' to exit the menu.
4) Press the 'Conf Rec' button to enter record mode.
Now you should be able to control the start/stop of the record function via the foot control.
Hope this helps...
Apr 13, 2009 | Dictaphone 3750 Desktop Cassette...
Foot pedal FF or Rewinds when pressing Play
It's possible that there's a broken wire in the cable that connects the foot control to the machine. This usually happens near the plug that plugs into the machine, or by the end that goes into the foot control.
You can usually duplicate it if you put the auto-backspace up a bit and then hold down the play pedal on the foot control. While holding down the play pedal, try moving the cable near the machine or near the foot control in a circular motion. If the machine stops, rewinds or fast forwards, then odds are that the problem is with the cable.
Mar 13, 2009 | Dictaphone 3750 Desktop Cassette...
Lost manual for dictaphone 2750
For transcribing, you'll need the machine (2750), the power supply, a foot control, and a headset (unless you use the machine's built-in speaker).
For dictating, you'll need the machine (2750), the power supply, and the microphone.
Mar 11, 2009 | Dictaphone 2750 Desktop Cassette...
Dictaphone Expresswriter 2740 Tape Won't Move
The problem is with the capstan motor. More than likely it has developed a 'flat spot' and won't spin up. The clicking noise you hear is the solenoids trying to pull the heads into place, but because the motor isn't turning, it can't pull the heads into place.
Mar 05, 2009 | Dictaphone 2740 Desktop Cassette...
It would be easier/cheaper to buy another foot pedal.
The older style had "leaf" switches in them and they are adjustable from below the foot control. There are 2 screws underneath each switch. Loosen up the one closer to the front of the pedal (just a little) and tighten the one in the back the same amount. This will raise the angle of the switch to make it more sensitive (lighter pressure to activate).
Oct 10, 2008 | Dictaphone Audio Players & Recorders
Pedal problems
Jul 07, 2008 | Audio Players & Recorders
Dictaphone MicWiz
Catherine, did you ever get an answer for your problem with MicWiz? I am a transcriptionist that works from home and they are having problems getting it to recognize my foot pedal (as well as another MT) with the new software. It is recognized by Express Scribe and ever other system we use, but not Merge.
Thank you, Cindy
Apr 23, 2008 | Dictaphone 2740 Desktop Cassette...
Top Dictaphone Audio Players & Recorders Experts
Alan W Kelly
Alan W Kelly
Pennywhistler
Pennywhistler
Are you a Dictaphone Audio Player and Recorder Expert? Answer questions, earn points and help others
