Question about Dishwashers
Viking dishwasher error code - Dishwashers
2 Suggested Answers
BElectric
  • 1140 Answers
SOURCE: dishwasher viking model vdb450ss error
Hello there,
If you're certain this model number is correct, the error code indicates a "drain timeout error". This means the machine has tried and failed to pump out within a specified time limit. Please run through the following checklist to correct this problem:
1. Check and clean the filters
2. Check the drain hose isn't kinked and check for any blockages in the drain hose.
3. Make sure the hose has a high loop as per the installation instructions
4. If draining into a garbage disposal . . .
- Remove the plug from the disposal to allow air entry / eliminate any potential vacuum.
- Run water through the disposal to check for blockages
5. Ensure dishwasher is level, front to back and left to right.
When you've checked all of the above, reset the dishwasher by holding the START button for a minimum of four seconds to clear the error message.
My slight question mark over the model number is because you referred to "heavy cycle". The VDB450SS does have a heavy cycle but it's called "pot & pans" on this model. Other Viking dishwashers explicity say "Heavy" but a flashing LED above heavy on another model may indicate an entirely different fault. This is an overfill error code on some models.
If you definitely have the VDB450SS, you should be able to solve the problem using the checklist above. If you have any other model. please reply to me by clicking on "Add a Comment" below your question for further assistance. Please verify the correct model number if/when replying and whether any other LEDs are also flashing.
Thanks,
BElectric
Posted on Mar 04, 2011
I have a brand new Viking dishwasher and it won't start. I get an error code "E 02". Can I fix this or do I have to call Viking service?
Hey Marlene, Your new washer must have a warranty.. use it.. call or go to the store where you purchased it... they should take care of you!!
Sep 23, 2017 | Viking Dishwashers
Dishwasher Repair
get in touch with the retailer
Oct 19, 2014 | Viking Dishwashers
Plate and pot are flashing error code
Unclear what your dishwasher model is. Check the codes on page 37 onwards of this manual to confirm. Most likely it is a drain problem. Ensure the kitchen drain is clear and drain hose is not blocked.
http://www.vikingrange.com/MEDIA_CustomProductCatalog/m2700097_F20407.pdf
Apr 02, 2014 | Viking Dishwashers
Oh my gosh, repairman made things much worse. Initially I was getting the HUBA disconnect error code on my Viking VDB325ss dishwasher. There was a moldy smell after each cycle, but at least the machine...
actually , call your local viking distributor and request parts to fix the unit and rebuild the dw to a vdb325e, software will remedy your situation. electronics are under a 5 yr parts warranty.
Sep 28, 2013 | Washing Machines
Viking dishwasher parts
Yes, please type in " viking dishwasher parts diagram" into your computer, and you will see whatever you need!
Be blessed.
Feb 23, 2013 | Viking 24 in. Professional Series VUD141...
My viking dishwasher won't complete it's cycle. The error code that flashes is the heavy pots and pans. We've checked the filter and drains and nothing is clogged. What else could it be?
Have you checked the kitchen sink drain and air gap if one is installed in your kitchen. If using the garbage disposal unit in kitchen then make sure it is clear.
provide model number of dishwasher for further diagnosis.
Aug 28, 2011 | Dishwashers
30 yr old Viking dishwasher leaks...
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
tyue56
Aug 06, 2009 | Viking DFUD04 Built-in Dishwasher
Link doesn't seem to have any information on Viking dishwashers.
sorry for the delayed response, you can click on the request more assistance button or repost the problem, I don't remember what the button says but other solutions have been offered by other experts.
expert toddg has suggested that there is a 5 year warranty, is it over 5 years old?
if you don't see hes solution just click on the repost problem a few times.
Jul 31, 2008 | Viking 24 in. Professional Series VUD040...
Dishwashers Logo
203 people viewed this question
Top Dishwashers Experts
