Question about Canon Cameras
My 580ex ii cannot change back to Auto zoom its stuck at 14mm
    Master:
  • Canon Master
  • 442 Answers
If removing the batteries overnight doesn't allow it to reset, try mounting the flash on your camera, turn both on and reset your camera to factory default settings through your camera menu settings.
Posted on Sep 07, 2014
4 Suggested Answers
SOURCE: I have a Nikon SB-600. It will not zoom; it is
Push the cap over the flash head down. When the cap is over the flash it stays at 14mm
Posted on Jul 23, 2010
SOURCE: SB-600 Power Zoom stuck at 14mm
I struggled with this one but then, on the basis that if all else fails read the manual I found the answer. It's soooo simple. The wide-flash adapter is set. That's the little pull-out screen at the top of the flash which folds down over the flash-head. If it's pulled forward it activates the wide angle setting automatically. Push it back in and you'll be fine. tony k
Posted on Feb 19, 2009
  • 685 Answers
SOURCE: flash does not show TTL Balance. Stuck on 14mm
This is not user fixable, send it back to nikon and expect to pay about $ 120 to get it fixed
Posted on Apr 05, 2010
The flash ratio between a master unit mounted on my Canon 5D Mark II and slave doesn't work properly. A couple of shots are fine but then all of sudden the slave unit fires ar full power, then a few week...
If you had the ATG Gold MG8k Flash Kim X3, then your 430EX II or 580EX II can transforms into wireless radio ATG ETTL II.
If you are using the outdated wireless IR ETTL with a 580EX II as a Master. Then you have to set the Slave (ATG/580EX II/430EX II) body facing close to the Master.
atdlee@netzero.com
May 20, 2014 | Canon Speedlite 580EX II TTL Flash
Unlock setting on Cannon Speedlite 580EX II
Place flash on camera.
Go into camera's flash menu and change your setting there.
atdlee@yahoo.com
Apr 26, 2014 | Canon Speedlite 580EX II TTL Flash
Is not working properly
A good possibility is the zoom head is causing the clicking sound. As we zoom the flash, the inside of the head moves to the back and forward. Gently tap it a few times see if that helps. My guess is it needs servicing.
Apr 18, 2014 | Canon SPEEDLITE 580EX TTL Flash
I need a manual for my canon 580ex flashgun
580EX:
http://downloads.canon.com/cpr/software/camera/580EX.pdf
580EX II:
http://downloads.canon.com/cpr/software/camera/Speedlite-580EXII.pdf
Jun 30, 2011 | Canon SPEEDLITE 580EX TTL Flash
Lost autofocus on 40D when using ST-E2 and 2 580EX
Try taking the battery out and putting it back in. If that doesn't work try cleaning the len's contact sesnors with a pencil eraser.
Jun 23, 2009 | Canon EOS 40D Digital Camera
I have a Canon Speedlite 580EX, the flash will not go off.
Perhaps the unit is set to master/slave mode. Look into that.
hint: Press and hold on the zoom button to get into the master/slave menu
Dec 04, 2008 | Canon Speedlite 580EX II TTL Flash
Canon Speedlite 580EX Fault
same problem after a 30 cm falling on the floor. U must open the head of the flash and rearange the flash Bulb on the moving(zooming) track. images of how to u cand find HERE
Aug 21, 2007 | Canon SPEEDLITE 580EX TTL Flash
Cameras Logo
177 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
