Question about Insignia Digital-to-Analog Converter for Analog TVs
Can not get any chanels through the digital converter please help
I hooked up a magnavox tb110mw9 converter according to the instructions w/o a/v jacks. I get nothing. I have run the autoscan and no chnls or no sgnl found. sgnl strngth is 0. I get beautiful clear pictures of all available chnls in my area using only my vhs roof antenna. dstnc from tv twrs is appx 75 mls south with no visable mountain obstructions and no buildings. When i leave the cnvrtr bx hooked up to tv but turned off and chng chnls on the tv there is poor reception not crystal clear as it is w/o the box straight to antenna. i turned the antenna with the box turned on & watching the signal strength meter. the best strength reading was a 15 and only chnl it barely rcvd was OPB that was extremely distorted with pixellets and no audio. my antenna has been secured in this position aprx 15 - 20 ft above ground since 1975 never affected by gale force wind, snow, rain or surrounding trees. If it is picking up the analog signals with perfectly clear reception in this position, shouldnt it be the same for the digital signals? Please give me an answer soon, as I am running out of time. Do I have to raise the antenna? If so how high? Do I need to buy a different antenna? If so what kind?
Thank you.
Tammy C
  • tammyg59 Jan 04, 2009
    in response to the plugs backwards on the tv: how can i have it backwards when there is only one going from box to tv? (I did switch the two on the box and result was as if it was totally disconnected) Re: turning antenna; i have done this turning (spinning slowly 360 degrees) and only found a 15 in signal strength which was only turning an inch from the current position. I didn't, however; change the height of the antenna. Is height of antenna a factor in finding digital signal?
Digital tv signals require a better antenna than we could get by with the old analog tv signal. You need a "fringe" rooftop antenna. I would try the $100 model from Radio Shack. Use only RG6 cable, and as short a run of cable as possible. As you are 75 miles from the broadcast station, you may need additional height on your antenna and/ or a signal booster. Visit antennaweb.org for additional information for your area. Antennas do become corroded after many years and need to be replaced. Point the end of the antenna with the smaller elements toward the broadcast station.
Posted on Feb 09, 2009
  • 3 Answers
Make sure its set to antenna than have someone go up and turn while u seek the signal try a channel thats works good but not perfect than go from there. if not u have ur plugs backwords in the tv not the device.
Posted on Jan 04, 2009
I have a Magnavox sdtv converter TB110MW9 the remote stopped woring. i now have a RCA RCR314WZ/RCR313BZ universl remote. Can't seem to program it. Please help if you can, send codes.
Some of the newer RCA universal remotes can handle STBs. Use code search to find something suitable. If a search through all codes contained in the remote fails, you may have to try a different universal remote. All universal remotes do not contain all possible codes.
Aug 15, 2016 | Magnavox TB110MW9 DTV Digital to Analog...
Need code for a magnavox converter box using a one for all universal remote
Daphne, Try using auto code search feature, found on most universal remotes. Instructions should be in your manual. From one of the forums they suggested this. Place your tv on channel 3.
Point your GE universal remote at the converter box, press and hold the setup button until the red light remains lit, then press and release the DVR/AUX button. The red light will blink once.
Enter 0581 as the code, then press Power and the Converter box will turn on and your channels will pop right up.
Check the attached links,instruction,guides, read through them, as they have fixes to program remote. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
RC Controlling the Magnavox TB100MW9 Digital Analog Converter Page 2 of 2
https://answers.yahoo.com/question/index?qid=20130917205010AAu9Gpg
Remote Code Finder
Apr 27, 2016 | Magnavox TB110MW9 DTV Digital to Analog...
HOW DO I SET MY UNIVERSAL RE MOTE FOR MY CONVERTER BOX
To be honest I never got a universal remote to work Magnavox TB110MW9 DTV Digital to Analog Converter
Nov 16, 2015 | Magnavox TB110MW9 DTV Digital to Analog...
How can I reprogram magnavox TB110MW9 DTV converter?
Go to the setup mode using the remote, connect it to a good antenna and rescan the channels make sure its output is connected to your TV and tune TV to channel 3 exit the menu and you should be good to go
Dec 17, 2014 | Magnavox TB110MW9 DTV Digital to Analog...
We were given the TB110MW9 Digital TV DTV Converter Box for Analog TV but with no remote . we do have other remotes we've kept from our last box that also died.would we be able to use this re
I thought that model number looked familiar. The answer is a qualified yes. If you have a Magnavox or a Philips remote it should work. If you have a universal remote try to search for a code that will control the box.
Nov 29, 2012 | Magnavox TB110MW9 DTV Digital to Analog...
How can you turn on the Magnavox tb110mw9 analog to digital converter box if the remote has been lost?
The Magnavox tb110mw9 has NO controls on the box. without the remote you cannot operate the box.
If anyone knows of a universal remote or similar remote (philco) will operate the box please post.
May 28, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Dtv converter box, no PS2
you need to hook up the ps2 directly to the tv not the converter box the converter box is only for digital Chanel's that will go off air on june 12 but if you have cable or satellite then you don't need a converter box this is only for free Chanel's with they don't requires subscription to cable or satellite your playstation should work with out the box try to hook it up directly to the tv not the box
Apr 28, 2009 | Video Game Consoles & Games
Insignia Digital-to-Analog Converter for Analog TVs Logo
419 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
Curt Larson
Level 1 Expert
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
