Question about Sony DAV-S400 System
Sound problems on Sony DVD amp
Hi there, I have a Sony Compact AV System DAV-S400. Recently, the sound to the left channel has started to become intermitent. When you play a DVD or listen to the radio, the front left channel seems to cut in and out. Sometimes you can be using the system for a while before it happens, other times the sound goes almost straight away. I have tried using one of the other speakers and the problem still occurs. There doesn't seem to be a problem with the connection into the rear of the system but I'm not really sure what I should be looking for. Everything else on the system works perfectly, including the other four speakers. Many thanks for any advice you may have, Matt
  • 3 more comments
  • deepo Nov 29, 2007
    Hi there!
    i seem to be having this exact same problem! On my system, both the front left and the back right speaker keeps cutting out. It seems to have something to do with a bad connection between the sockets in the back (where you plug in the speakers) and the reciever. If i push and pull a bit on the plugs it starts working, only to cut out again a minute or an hour later.
  • Anonymous Jan 05, 2008
    no sound on left front channel changed speaker and wire just in case no difference
  • Anonymous Jan 15, 2008
    It's the same problem form me. After a couple of minites, sound on the front left channel goes out. It recovers after a ramdom time (an hour or two, sometrimes even more). What's going on??
  • Anonymous Feb 28, 2008
    I have the same problem, front left channel cuts out and just sounds "fuzzy". It is only one channel and not the speaker... I assume either the channel connector is broken, or something similar to a problem my friend had, where a nearly broken headphone socket cuts out some of the sound... Hmm... any fixes?
  • TLFHooker Aug 03, 2008
    I hav ethe same DAV-S400 and had the same speaker issue, it stopped when it got stuck in headphone mode....now i get no sound at all! It would seem like a lid off job, other than visual checks, are there any clever ways of spotting dry joints.? and y avice would be most welcome before i take the lid off.
    Many thanks
The socket that goes to the headphone jack at the front, should be soldderd if u have the (HP THEATER) come up on the display without haveing headphones plugged in, other wise re-solder the speaker out sockets on PCB again or failing that re-solder the output chips that are in a row with a piece of pcb on top that should fix the problem. Rickardo1
Posted on Sep 08, 2008
It might have to do with dry joints as noted in other questions
i have once re-soldered all points of the amp PCB and the sound did get better for the right, but still cuts to the left... ima try again tonite
Posted on Jun 20, 2008
SOURCE:
My older Sony Home Theatre/DVD player sometimes will not output any sound.
Sony eSupport - DAV-HDX500 - Support
https://esupport.sony.com/.../model-home.pl?...DAVH...
Sony CorporationHCD-HDX500 - DVD/Receiver Component for Home Theater System ... How to troubleshoot if there is no sound or intermittent sound from the speakers.
[PDF]DVD Home Theatre System - Sony
https://docs.sony.com/release/DAVHDX500.pdf
Sony CorporationDVD Home Theatre. System. Operating Instructions. DAV-HDX500/HDX501W ... not expressly approved in this manual could void your authority to operate this ...
Sony DAV-HDX500 No Sound : hometheater - Reddit
https://www.reddit.com/r/.../3nenei/sony_davhdx500_no_sound/
RedditOct 4, 2015 - My Sony DAV-HDX500 only plays sound when using the built in dvd player. ... Sony system you have does have a digital optical input so that's ...
Jan 10, 2016 | Sony DAV-HDX500 System
How to solve sony dav -dz340k Push Power Protector
my dav-340k was working perfectly then after sometimes it lost sound output,even with the full volume no sound at all n no any warning n nor indication. what could be the problem?
Nov 02, 2012 | Sony Dav-dz340k 5.1 Channel DVD Home...
Our Sony c 770 no longer plays DVDs or Cds but it still works as a receiver. Can we connect a DVD player to it and have it come thru the 5.1 speaker system?
Yes, tis unit has 2 video inputs at rear so you can connect any other dvd player sound (analog or digital) to get 5.1 channel surround sound from DAV-C770 speakers.
Click Sony Support to download user manual copy of DAV-C770 that has more details about connection setup.
Hope this info will help you.
Thanks.
Nov 26, 2010 | Sony DAV-C770 System
Have a Sony Compact AV System DAV-SA30 with no sound - everything else OK. Was turned off at mains whilst on Standby - could this have been the problem and what can be done to resolve it?
it sounds like a circuit or capacitor on the inside has blown normally a stand by light is the only form or error code the dvd players are capable of sending when something goes wrong internally
Aug 20, 2010 | Sony Televison & Video
Installation instructions
Hi
here is a link to download user manual from sony...
http://support.sony-europe.com/hav/ha/hta/dav/dav.aspx?site=odw_en_GB&m=DAV-S400
click on user manual tab and you will see english plus other language versions.
Hope that helps?
Dec 20, 2008 | Sony DAV-S400 System
Sony compact AV SYSTEM DAV-S400
Hi Joey - I had exactly the same problem.
In my case, I followed the advice of others and took the thing apart. On the main amp board there is a large brown capacitor. Mine had come completely loose, so I soldered it back in place with a good amount of solder to make sure the contacts were ok. I also dabbed some solder on the headphone connectors on the same board (just follow the wire from the headphone socket to the board). Well, when I put it back together and tried it again everything worked perfectly, and it has so far remained free from the error. Hope that helps !
Nov 14, 2008 | Sony DAV-S400 System
Sharp LC-32D44
Below picture shows Audio inputs of Sony DAV-S400 and you can hook up any one.
Go to menu of home theater system and enable surround.
Need further help, let me know please...
Oct 26, 2008 | Sony DAV-S400 System
After a while the system starts crackling and eventually sound deteriorates to thundering in speakers
Hi, I have exactly the same prob and I belive that it is in the amp module?! I am going to take mine in for repair as my other sony HT amp has just give up the ghost, (STR-DE435), it has a protector prob and is probably not worth repairing, although it is a great amp. If anyone knows the solution to this prob it would be great to hear it!!!
Nov 21, 2006 | Sony DAV-SA30 System
Sony DAV-S400 System Logo
232 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
