Sony TV goes to standby - constant red light
Sony Trinitron TV - For the last month the Red (stand-by) light has come on (constant). No picture / no sound. A couple of times over the month, the TV has worked normally when switched on (1% of attempts)Sean
  • sean_c Feb 03, 2009
    What would I need to do to replace the power supply?
    Sergeant:
  • 250 Answers
The Power Supply has gone. It needs replacing.
Posted on Jan 04, 2009
  • John Trigg Feb 04, 2009
    You will need to find a replacement power supply first of all. You may be able to find a second-hand one, but it must be EXACTLY the same as the one you have. After disconnecting from the power point in the wall, take off the back cover and follow the power lead inside the cabinet. You will see the power supply where these leads stop. Carefully make a diagramof the wires, their colors, and where they go, because your next job is to unsolder them and replace the power supply, and ard job, but whether or not is is worthwhile depends on the cost of the replacement power supply compared to the cost of a replacement TV. Let me know how it goes for you.
Red LED light blinks 7 times when the set is turned on; no pictur
if you have the circuit diagram of your tv,check the horizontal polarisation IC closer to the line transformer and replace it.If it doesn't work,send the question again.
Sep 22, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Red standby light flashing no picture or sound
the power supply is faulty, check the following
power trasistor
rectifier diodes
zener diodes
fusable resistors ( less than 20ohms)
and your set will work again
Apr 07, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron KV-32FS12
i think your tv had a lose contact or crack on board
Oct 18, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
SONY WEGA TRINTRON MODEL KV36FV15 RED LITE FLASHING
The model number is KV-36FV15 and blinking is constant no pause
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron Color TV KV-35V65 - No Picture, red light stand/by timer flashing
A reset won't fix this. The standby light should be blinking a repeated count with a 3 second pause inbetween. Post that count here. That will indicate the circuit/condition that is preventing the set from turning on.
Thanks,
Dan
Jul 18, 2008 | Sony KV-35V65 TV
Sony Trinitron blank tv/no picture
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
what is the problem?
Feb 08, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
Electro Med Services...
