Question about D-Link DGS-1008D 8-Port Gigabit Ethernet Switch (790069252747)
Places used in
Where can we use the four kind's of topologys (bus , star , ring , mesh)
  • 53 Answers
In LAN(local area network) you can use thies topologies( star, ring, bus,mesh). here star topology is popular among them
Posted on Mar 21, 2009
How can I charter a bus in Spain?
It is very easy to charter a bus in Spain Because Spain is a place where you can get a bus charter facility very easily. one of the reason is that it is a tourist place. You can charter a bus from many of the online platforms, According to me, one of the best online platforms is Bus Charter Spain. Here you will get all kinds of bus charter and have many options to choose.
Dec 20, 2017 | Computers & Internet
Logical topology
A logical topology is a concept in networking that defines the architecture of the communication mechanism for all nodes in a network. Using network equipment such as routers and switches, the logical topology of a network can be dynamically maintained and reconfigured.
Mar 18, 2017 | Logical Computers & Internet
How to rebuild dana 60 front?
Fully rebuild, or partial rebuild? Pinion, ring, spider gears, pumpkin, bearings? Rebuilding it FULLY and PROPERLY is a big story, one too big to relate here, and it takes quite a lot of special tooling (differential spreader, dial indicators, etc). Please don't attempt this unless you have a well equipped shop.
If you just need to replace the spider gears, that's easy. Drain the oil, remove the cover, rotate the pumpkin until you can unbolt the crosspin. Push/pull the crosspin out, rotate the spider gears until they come out. Remove the side gears. Remove all four thrust washers.
Replace all four thrust washers, then the new side gears, then mesh the new spider gears with the side gears & rotate them into place. If the crosspin hole won't line up, rotate one axle shaft until it does. Install the new crosspin and bolt it in. Replace the cover gasket and cover, refill.
Going further requires a LOT more work, but you'll need to remove the spider & side gears first anyway. If you're replacing bearings or the pumpkin or the ring & pinion, you'll need a bunch of new shims to work with until you can get the ring-pinion clearance exactly right. You'll also need a differential spreader to get enough space to remove/install the pumpkin with its bearings in place. If you're replacing the pinion gear, you'll need to take some painfully exact measurements or you'll NEVER get the ring/pinion clearances correct.
Jul 29, 2014 | Cars & Trucks
How much power does D-link switch DGS-1224TP cosume?
These are your normal 110-220 volts range with minimal 1.5 to 4.5 amps. Same as any PC or smaller end server.
Feb 07, 2013 | D-Link D Link Websmart Dgs 1224tp Gigabit...
Need to replace broken dewalt 618 magnet ring.
you have to take four screws out from top of router. i used a large flat head screwdriver but actually the screw has a weird head like a cross between flat head and star. anyway once you remove cover you should see the bearing in the center. you need to use a bearing/gear puller to remove it. the magnetic ring lays just beneath the bearing. if its still there. mine was in pieces. clean out the mess and then the magnetic ring slides on flat side down. then LIGHTLY tap the bearing back into place. i used a small hammer. there didn't seem to be any lubrication in there so i didn't add any.
Jun 07, 2010 | Dewalt DW618 Router
Star under mesh on level 10
i maybe wrong but my friend explained to me that you need to earn a different power to kind of -"dig"-if you dont understand...well...im sorry but im only eleven and my friend is NOT good at explaining things!so i am extemely sorry if i have not been able to help your husband!
bibix
Dec 31, 2008 | Nintendo New Super Mario Bros. for DS
WHAT ETHERNET TOPOLOGY IS USED IN SWITCHES
Switches, hubs or routers typically are used in a star topology connection, so if one device fail everything else is still working. Everithing is managed inside but not like a bus topology system. You may need to use a tree topology in some case, keeping in mind the consequence of a failure.
Sep 06, 2008 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
Calculate network topology cost
Answers as follows
  1. $100 ({n(n-1)}/2)
  2. $50 (n links)
  3. 3 (number of pcs/2)
  4. 1 (in any hub topologyonly one pair would commm. at a time)
  5. Bus ( $40 n-1 links)
With Regards,
TPV
Jan 12, 2008 | Compaq NETELLIGENT 3024 24-PORT 10BASE-T...
D-Link DGS-1008D 8-Port Gigabit Ethernet Switch (790069252747) Logo
134 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
