Question about Garden
Fuel and carburretor problems with Ryobi Weed Hornet MkII
Need a manual for the appliance
Started at the very beginning (of the fuel line) which is a very good place to start. Traced it all the way back to the end (which is a good place to finish) ..... cleaned everything out............including the cap on the fuel tank (took it apart and found a sponge in the top that needed cleaning) and lo and behold.............petrol made its way from the tank to the bit that goes "vroom vroom" and it ''vroomed'' to its hearts content
Posted on Jan 05, 2009
I have Ryobi Weed Hornet Model RWH1100A MKIII and the primer bulb has disintegrated. I'm told spare parts are not available as this model is not made any more. Is there any way I can bypass the pr
The primer only pulls fuel from the carb, into the bulb and dumps back to tank, this is a starting aid so there is always fresh fuel in the carb, you can just blank of the pipe from the carb to the primer, this will just turn it into a standaed non primer carb, if it starts ok just useing the hoke then leave that way
Mar 14, 2012 | Garden
Fuel line for ryobi
hello sir, fuel line routing for ryobi,poulan trimmers, looking at machine from left side,front green line from tank to bottom of port on primmer bulb. rear line from tank which has filter inserted through tank with small white ring pushed up aginst tank & filter fittings, goes to port at bottom of carburetor.top line from primmer bulbgoes to top port of carburetor. that is the way thay go on.it is important to make sure you have the same fuel line I.D.3/32 and O.D.3/16 are very important! also if old line dissolved it will get in carb. and clog ports & small screen inside.clean inside of carb. with carb. cleaner & air pressure. to get your parts and numbers ,go to mtdparts.arinet.com, parts,791-683398,fuel line assembly,this is for most fuel line trimmers~~~hope this helps,don't forget the 4 thumbs up,any comments welcome,thank you. ``
Feb 12, 2012 | Garden
I am looking for a Ryobi weed eater manual. Need to know how much oil to put in my weed eater. Can you give me an answer or where I can get a free manual. Thanks
You did not list which model Ryobi you have, however...
If your Ryobi has a silver or black shaft, then it is an older model and requires a 32:1 fuel mix. In the USA, that is 4 ounces of 2 cycle mix per gallon of gasoline. If your Ryobi has a yellow shaft, then it was made by HCP and uses a 50:1 mix or 2.6 ounces of 2 cycle mix per gallon.
Sep 23, 2010 | Garden
I have a ryobi lawn Hornet (weed trimmer) MKIII, i...
Sounds like it has a fuel blockage. Three things to check are;Inspect the fuel-filter (inside the tank) for contaminants. Inspect fuel lines for cracks. Inspect carby for oil residue (blocking the jet). Hope this helps
May 17, 2010 | Garden
Ryobi Electric Lawn Hornet Model RLT800QF. Need
I went to www.ryobipower.co.uk, I was ynable to find a lawn hornet on the website. But you may have better luck because in the states we do not have lawn hornets.
Good Day Mate
Dec 14, 2009 | Garden
Need a diagram that will show the tubing feeds on ryobi weed trim
If you need a fuel line diagram for ryobi 775r let me have your email address.
tony
Oct 13, 2009 | Garden
Primer button Ryobi lawn hornet
Vacuum created by piston operation after closing the choke pulls fuel into carburetor port into engine. In much the same way as the primer bulb provides fuel for the port. These type engines usually take a few more pulls before they will start. And if there are any leaks in carb. system will be very hard to start.
Apr 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Ryobi Weed Hornet RWH1100 Mk 11 - carby diagram required.
had similar problems with my mum's 77. she was going to throw it out so i adopted it. turns out i just needed to adjust the injection screw. couldn't tell u where it is as i did it five years ago but armed with the knowledge that carbys have them and a bit of dissassembly i was able to fix it pretty easily. still runnin great now till the starter mechanism stuck. time to pull it apart again, hence my visit to this forum....
Mar 12, 2009 | Ryobi Garden
Garden Logo
496 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
