Question about Dishwashers
Asko dishwasher N516 F7 code - Dishwashers
SOURCE: Asko D3350
Code F7 means "The drain is blocked"
I refer to the troubleshooting section : http://www.askousa.com/pub/manuals/dishwashers/current/English-D3350_UCG.pdf
Posted on Jan 19, 2008
Timon90
  • 126 Answers
SOURCE: Asko D3350 code F7
Service manual says:
LED L1+L2/Fault code F7, Pumping out fault
(machines with pressure sensor)
Water not evacuated after 120 seconds’ pumping
out. Programme interrupted.
Check: Drain pump, hoses, installation of drain
hose, control unit and wiring.
Posted on Jan 24, 2008
ginko
  • 19396 Answers
SOURCE: help for my asko diswasher
Unplug the washer for ten minutes, see if this clears the problem.
Posted on Aug 28, 2008
  • 55 Answers
SOURCE: Asko 3350 Dishwasher
The "F7" code means that the drain is blocked. To remove items from the drain: 1.Turn power to unit off. 2. Remove the "Coarse Filter" by squeezing the tabs together and lifting out. 3. Remove the "Fine Filter" and "Main Filter" by removing the screws around the filters and lifting them out. 4.Remove the small black adapter piece and check the sump area for debris. 5.Wash the filters out gently with hot, soapy water. DO NOT RUN THE UNIT WITHOUT THE FILTERS IN PLACE! 6.Replace the black adapter piece to its original position FIRST (Important!). 7.Replace the filters in reverse order of removal and turn the unit back on. The error code should reset and work normally. *In areas with hard-water, the filters should be removed every 8-12 months and submerged in a chemical solution (CLR or LimeAway) to remove mineral deposits. Hope this helps...
Posted on Sep 04, 2008
VOTIT
  • 2071 Answers
Just click below;
WHAT IS WRONG WITH YOUR DISHWASHER?
For a detailed Dishwasher illustration, click below.
Built in
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Hope this may help;
Regards,
VOTIT
Posted on Sep 14, 2008
I have an F7 Asko D5131 dish washer showing F7 how can I fix this?
The "F7" code means that the drain is blocked. To remove items from the drain: 1.Turn power to unit off. 2.Remove the "Coarse Filter" by squeezing the tabs together and lifting out. 3. Remove the "Fine Filter" and "Main Filter" by removing the screws around the filters and lifting them out. 4.Remove the small black adapter piece and check the sump area for debris. 5.Wash the filters out gently with hot, soapy water. Do not run the unit without the filters in place! 6.Replace the black adapter piece to its original position FIRST (Important!). 7.Replace the filters in reverse order of removal and turn the unit back on. The error code should reset and work normally. *In areas with hard-water, the filters should be removed every 8-12 months and submerged in a chemical solution (CLR or LimeAway) to remove mineral deposits
Jun 13, 2016 | Asko Dishwashers
Asko D3350 code F7
you seem rushed
ok
the problem might not be in your senser or timer but in the pump its self
Sep 14, 2008 | Asko 24 in. D3350 Dishwasher
My asko D5155 stops washing and flashes F7
LED L1+ L2/Fault code F7, Pumping out fault (machines with
pressure sensor)
Water not evacuated after 120 seconds pumping out. Program
interrupted.
Check: Drain pump, hoses, installation of drain hose, control unit and wiring.
Dado
Oct 06, 2015 | Asko Dishwashers
I need a manual for my dishwasher ASKO N516 type: DW 20.2
I went to the Askousa website and located manuals for your model, the link below will direct you to select your current model, you can download all your information and manuals from this site.
I hope this helps
www.askousa.com/customer-care/technical_documentation/
Aug 14, 2011 | Dishwashers
F7 code
yes remove filter and water from under filter theres a small chamber at the back of the sump,it may be full of fat clean it with your finger then try running some heavy wash cycles to clean it.
May 02, 2010 | Asko 24 in. D3350 Dishwasher
Sep 04, 2008 | Asko 24 in. D3350 Dishwasher
Help for my asko diswasher
Aug 28, 2008 | Asko 24 in. D3350 Dishwasher
Asko D3350 code F7
Jan 19, 2008 | Asko 24 in. D3350 Dishwasher
D3350 - Code F9
Asko D3350
Steve, according to the codes listed on http://www.repairclinic.com/0078.asp apparently F7 is a bad door latch. It could be just not shutting fully or maybe one of the springs/rods needs looking at.
Is there anything recently that may have happened to the door? Slamming, jarring, etc.
Dec 21, 2007 | Asko 24 in. D3350 Dishwasher
Dishwashers Logo
300 people viewed this question
Top Dishwashers Experts
