Question about Philips 150S (White) 15" LCD Monitor
Green light goes on and off
I have a philips lcd monitor in which nowadays the green light goes off and on continuously . I have speakers in it too but their power light is always on. plzzzzzzzzz some 1 help me out...its urgent. u r help will be truly appreciated....
  • Kunal Asher May 18, 2007
    Thanx for u r reply
    I have inbuilt speakers in my lcd when the power screen in the lcd does not show the green light the green light is visible in the speakers .
    If i connect the lcd alone then it should give the message no video input or something like that but the green light doesnt get on .
    Brigadier General:
  • 6,966 Answers
Hi, aside from the blinking green light, does it display something like "No Signal", if it is it might be possible that it's not your monitor that is on the brink, it is possible that your computer isn't turning on and therefore the monitor cannot display anything since there is no video signal from the computer. Perhaps you can try plugging the Philips monitor to another PC that is known to be operational to check if it will display something. If it does then the other PC is not working, if again no display or green light blinks, then the Philips monitor would require service. You might have to have a qualified service personnel to have a look inside and further diagnose the proble. I wouldn't recommend that you try opening the monitor since it's a bit complicated. Hope this be of some use to you and pls post again how things turn up. Kind regards.
Posted on May 18, 2007
When i swith on the computer, the led light of the monitor doesnt go green nor orange. when i press the swith continuously for many times, at some point the light goes green and unaware when it goes green....
It would be more economical to purchase a new or used LED/LCD monitor very cheaply than it would be to repair a very old CRT monitor.
This has been stated many times now, but the monitor is faulty.
Sep 12, 2012 | HP COMPAQ 7540 CRT Monitor
V7 L17PS speakers wont play sound. do i need to connect something to the tower?
You need to connect an audio cable with stereo miniphone plugs at both ends (Radio Shack), one end goes into the audio line out (green jack) on the PC, another goes into audio line in (green jack) of the monitor. Set the volume conrtrol on the monitor about 1/2 way up, then adjust the volume at the PC.
Apr 14, 2010 | Videoseven L17PS 17" LCD Monitor
Forgot to color coade what goes where when taking out my stereo to put a new on in .. dont know which wire is for what
  1. LT Green - LR Speaker +
  2. Gray - RR Speaker +
  3. Red/Green - LCD Control (Light Dimmer Control)
  4. White/Black - Power
  5. Brown/Black - LF Speaker +
  6. Orange - RF Speaker +
  7. Green/Black - LR Speaker -
  8. Gray/Black - RR Speaker -
  9. Black - Ground
  10. Red/Yellow - LCD Input (Light Power Source)
  11. White - Memory Power Wire
  12. Brown/White - LF Speaker -
  13. Orange/Blue - RF Speaker -
Dec 07, 2009 | 1999 Chevrolet Tracker
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
No sound from headset plugged into monitor
From the manual I found, this model does NOT support ANY audio connections.
http://www.p4c.philips.com/files/1/170b1a/170b1a_dfu_aen.pdf
170B Product Features
- 17" color LCD monitor with excellent display performance.
- Dual input-accepts both DVI Digital and VGA Analog input.
- Advanced AUTO adjustment automatically optimizes picture quality.
- Wide viewing angle technology.
- 7.1 (181mm) small footpring with full detachable cables.
- USB Bay for upgrade to USB Hub.
- Optional protective cover to prevent LCD panel damage.
- Standard VESA mounting holes and optional tilt/swivel Wall Mount Kit.
But if yours does have these ports, I would suggest they are not for a headset, but for connection to the _PC_. I would suggest your model monitor has built in speakers, and the green port is the INPUT from the PC Speaker output. The pink goes back to the PC from the MIC which is built into the screen.
Apr 21, 2009 | Computers & Internet
Monitor trouble
Usually fuses do not allow the operation LED to light. Rarely nowadays are fuses used in LCD monitors. Since you're sure the monitor is the problem, then it will have to go to a reputable repair person.
Apr 04, 2009 | Computers & Internet
Lost manual for hp compact.
The speakers wires are normally color coded if the computer isn't ancient, the Speaker PLUG is green, if you are using the speakers in the monitor, then plug the green one from monitor to green jack on back of PC, (Microphone plug and jack is pink/Red).
If you are using other speakers 3rd party, 4.1,5.1, the hookup is different usually, But I think you need green to green, there should only be one green plug on back of PC, It may be labled sound out. but yours is probably green.
PS you also need to kake sure the monitor speakers dont require their own Power Supply/ AC adapter, Most of them do, while some desktop and monitor speakers do not just connect the cord ffrom monitor to green jack, "sound out". If this helps, thanks for the feedback
Mar 31, 2009 | HP Pavilion F1703 17" LCD Monitor
My monitor comes on for one second then goes black. The green light stays on the whole time.
Check the cables, make sure it is secure on both ends. Also see if you pull up the Monitors on screen menu.
As long as the light is green, that means there is a signal. it could be a bad monitor. Shut off all the lights in the room, then grab a Flashlight and hold it against the LCD screen while it boots into windows. Can you see the desktop now, but very dimm? If you can see the desktop, then connect Your PC to another monitor (if u have one or a friends, perhaps) and boot it up, can you see the desktop on the other monitor fine?, then we just ruled out a Bad video card and narrowed it down to either a Bad Inverter in the Screen or LCD back light issue.
probally not worth fixing, because replacement LCD's arent cheap. nowadays at the right sale you can buy a Brand new LCD monitor for as little as $199
good luck,
djEnigma
Apr 01, 2008 | Computers & Internet
PC starts fine, then the montor blinks and no display. light stays green
This is most probably cause by one or more Faulty Electrolytic Capacitors, I find these are the MOST commonest form of "Fault" in these LCD's TFT's units. I ususally simply replace "On Spec" all High Value Electros, in fact ALL Electro's are suspect and often I just "Shotgun" and replace 'em all. Usually fixes all problems. Always use High Temperature Caps. Try this as it is a common problem I find a lot. Good Luck.
May 24, 2007 | ViewSonic VX900 19" LCD Monitor
Philips 150S (White) 15" LCD Monitor Logo
241 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
