I have youview with talktalk and the volume buttons dont work looking for the code my tv is a hitachi..
  • Marie Hassall
    Marie Hassall Jan 22, 2014
    I had this problem with my new LG. Found this TalkTalk YouView user guide which did the trick copy this link into your browser and go to page 6 where it tells you how to program your remote to your tv. http://m0.ttxm.co.uk/sites/rightnow/PDF_...
3 Suggested Answers
  • 188 Answers
SOURCE: Hitachi TV volume won't work
Is the set in hotel mode?
Posted on Jul 24, 2009
  • 37 Answers
SOURCE: dish network code for a viore, volume/power not working
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Posted on Jul 06, 2010
4 digit TV code to set up to BT youview
You might need to reset the remote control if the codes don't work.
If you've got the BT YouView remote that came with the box (with the 'BT Vision' button on it), hold down the two buttons either side of '0', whilst also holding down the power button for around 5 seconds. The blue light on the remote should flash three times to confirm it's successfully reset.
If you've got the retail YouView remote (with the 'TV' and 'PVR' buttons on it), press and hold the 'TV' button and the red coloured button at the same time for 5 seconds. The 'TV' and 'PVR' buttons should flash red 3 times to confirm.
Try your codes again after. I believe 4483 is the code in the setup guide.
May 28, 2015 | Televison & Video
How do I auto scan my youview box
You must have it connected to an aerial which receives digital signals into the aerial socket at rear.then go into the menu of the youviewbox and auto scan for all the channels it can pick up.i assume your aerial is pointing in the right direction.you can get a rough idea by looking at any aerials on neighbouring houses.once it completes the scan you must save or store those channels before exiting the menu.then the epg ( electronic program guide )will update and you should be able to select any program using the remote.i also assume the box is a working model and not been corrupted by a failed firmware update or damaged in anyway to any rear connectors.these boxes are very simple to set up so if you do get stuck you can try using the free fone number for talktalk.
Apr 24, 2015 | Humax Dtr-T1000 Youview Digital Tv...
Hey guys my youview remote has stopped working, the talktalk button keeps flashing blue though
Test if your remote works by viewing it through a digital camera. (A phone camera works well.) View the front of the remote on the camera's digital display while holding down any of the buttons on the remote. If your remote is working you will see an RF light coming from the front of your remote. (You can only see this through the digital camera. The human eye cannot see the RF signal on its own.) If you don't see the RF try changing the batteries with known good batteries and try again. If you see the RF but your remote doesn't seem too work it needs to be reprogrammed.
Here are the steps for programming the remote to work with my Samsung TV and other brands.
1.) Turn the TV on.
2.) On the remote control hold down TV Power+01 at the same time. If the TV turns off the controller is programmed. If not, try TV Power+02, +03, +04, +05, +06, +07, +08, +09. Different TV BRAND??? ...TRY the codes listed for other TV brands located on the last page of this link.
http://remotes.com/remotes/documents/Samsung/AK59-00104K.pdf
Dec 18, 2014 | Televison & Video
Bush tv remote code for talktalk youview
0059,0052,0050, 0055. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 05, 2014 | Televison & Video
What is the pairing code for youview box
you'll find yours online at
talktalk.co.uk/myaccount
Login to your account.
You can find manuals here:
YouView User Guides TalkTalk Help
Have a look at the troubleshooting pages. Something is said about having to accept the legal terms, if forgotten you will not be able to use On Demand and Search features.
Oct 19, 2014 | Computers & Internet
Why will my remote control for Talktalk Youview no longer change channels etc which means I cannot get recent prgrammes? It only switches the TV on and off. I have got new batteries . This makes no di
Check the remote control for its infra-red emission by pressing all the non-functional buttons on it. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Oct 16, 2014 | Televison & Video
How do I manually tune my new talktalk remote control to my TV
Do a code search procedure. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
Sep 11, 2014 | Televison & Video
Technika Model: LCD 26 920 code For Talk Talk YouView remote
0101. Check this code. It looks very rare to get a code for this brand TV. The only one I got is this. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
Universal remote controls are available at most of the electronic spare part selling shops
Apr 06, 2014 | Televison & Video
Televison & Video Logo
402 people viewed this question
Top Televison & Video Experts
Electro Med Services...
