Question about Car Audio & Video
How to set preset stations on alpine tdm-7544
  • 277 Answers
SOURCE: Wiring on tape deck Alpine tdm-7543
hi there is a manual in the model page click on it page 2 there is a description how to connect the unit good luck
Posted on Mar 21, 2006
night71
  • 328 Answers
SOURCE: setting preset channels
Here is the entire owners manual, you can print it out too.
http://vault.alpine-usa.com/products/documents/OM_CDE-7856.PDF
Posted on Oct 31, 2007
freetek
  • 5568 Answers
SOURCE: jvc car cd/radio
The radio was improperly installed; there are two 12V leads, one services the radio when on, the other, only the circuitry for the clock and presets.
Eventually, this shouldn't be needed if the manufacturers ever think about using a little bit of flash memory for the presets and a coin cell for the clock.
You didn't give any model number so researching the manual is impossible.
If you can find the model number, look for a user's (or installation) guide on line to find the wiring info.
Posted on Aug 25, 2008
Eagleeyes
  • 199 Answers
SOURCE: Alpine CDE-7859 **** Preseting the radio stations?****
http://www.alpine-electronics.co.uk/index.php?id=915&L=&manualsearch=CDM-7859RB
User Guide can be downloaded from here
Mark
Posted on Nov 17, 2008
  • 14 Answers
SOURCE: Radio Station Presets wont hold
hi girlygirl 1
the problem is your ignition and your permanant battery live wires are the wrong way round all you have to do is remove the stereo and you will usually see a red wire plug into another red wire and a yellow wire into another yellow wire all you have to do is change the red to the yellow and the yellow to the red and it will hold the memories fine hope that helps !
Posted on Nov 19, 2008
Have an older Alpine TDM-7544. It will not turn on No sign of life...Does this model have a code? If so where can I find it. How does the Remote-on switch works?
Go to the Alpine support site and try and find a user manual, that will tell you whether it can be theft protected with a code. If it does need a code you are well scre......
Aug 12, 2016 | Alpine Car Audio & Video
How to get an ipod to work on an Alpine tdm-7544?
Alpine has a din to RCA connector for that unit. That is the cd changer input.
Or buy a fm modulator and go thru fm.
Or buy one of those cassette tapes with the headphone wire coming off it and plug it into iPod. Like they use to do with Sony Walkman CD players.
Dec 28, 2012 | Car Audio & Video
How do you set stations and clock
1.Select the radio band and tune in a desired radio station you wish to store in the preset memory.
2 .Press and hold any one of the Preset buttons (1 through 6) for at least 2 seconds until the station frequency on the display blinks.
3. Press the Preset button into which you wish to store the station while the frequency display is blinking (within 5 seconds). The display stops blinking once the station has been memorized. The display shows the band, preset No. with a triangle (9) and station frequency memorized
http://vault.alpine-usa.com/products/documents/OM_CDM-7854.PDF is link to full manual
Mar 03, 2011 | Alpine CDE-7853
How do you set the radio stations on a alpine CDa-9855
go to a station you wish to save, then choose a preset number from 1 to 6. press that button for 3 to 5 seconds. the station should be locked into that preset number.
Dec 13, 2010 | Alpine CD Player CDA-9855 LIMITED QUANTITY...
Trying to set the radio stations on Alpine stereo
The radio either does not have the yellow power wire connected(constant 12v) or the wire is connected to a switched source and when the key is turned off the radio has no backup power. You will need to pull the radio out and verify the yellow wire is not connected to switched voltage and connected to constant power. It is also possible that they have the red and yellow wires mixed up. Remember yellow constant power and red is switched power(with ignition key). And also disconnect your negative battery cable when working on the electrical system of your vehicle...you may short something out and damage your vehicle's electrical system or head unit.
Sep 19, 2009 | Alpine TDM-7543
Advice on how to set tuner presets on AlpineCDM 7838R in car stereo CD . Unit has both permanent and switched power supplies, will search stations and hold them when switched off but cannot work out how to...
some of the alpines had an odd way of setting the presets manually. you need to press any of the 1 thru 6 buttons for a few seconds. when the display starts blinking just pick which preset button (1 thru 6) you want to set the station at and press it once.
Aug 25, 2009 | Car Audio & Video
How do I preset the stations for an Alpine TDA-7547 car Stereo. This is an older stereo and setting the stations is not intuitive.
Select the station you want. Then hold down one of the 6 preset buttons for a couple seconds. When the station ID flashes, release the button and it should be saved.
Dec 06, 2008 | Alpine TDA-7547
Station Presets
Get to the station u want an hold the preset u want it to be on for a few sec.
Apr 16, 2008 | Alpine CDA-9827 CD Player
Program stations
Quoting from page 6 of the manual:
"Select the radio band and tune in a desired radio station you wish to store in the preset memory.
Press and hold, for at least 2 seconds, any one of the preset buttons (1 through 6) that you want to store the station on. The selected station is stored. The display shows the band, preset number and station frequency memorized. A total of 18 stations can be stored in the preset memory (6 stations for each band; FM1, FM2 and AM). If you store a station in a preset memory which already has a station, the current station will be cleared and replaced with the new station."
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=934dc6a1672f80b9d320c470df81f04d&q=Alpine+CDE-9842
Feb 25, 2008 | Alpine CDE-9842 CD Player
Car Audio & Video Logo
85 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
