Question about Dishwashers
Dishwasher won't start
Model 655.13749k603 lites on panel lite up but will not start
rylee_smith
  • 8619 Answers
SOURCE: dishwasher quits running and clean lite keeps flashing
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 06, 2010
  • 949 Answers
SOURCE: clean lite is flashing
This is an indication that there was a failure to heat the water properly. I have put together some instructions on how to reset the control so you can use the dishwasher and some things to check to avoid this problem again. Follow the link below and let me know if it was helpful.
Clean light flashing
Posted on Jul 25, 2010
rickead1
  • 1998 Answers
SOURCE: On a Kenmore dishwasher-model#66513153K701(techsheet is missing)--clean
if the clean light is blinking 7 times in the unit you would have to check the element if the element is not heating the diswasher shuts down and goes no further into any cycle due to it not being able to heat the water you can also see here by clicking this link as well http://www.youtube.com/watch?v=Hv7xOaucH7I if the element were to test fine then next you would have to test the triac and the relay both are found in the machine control and in order to replace you would have to replace the control alot of people think this is 6 lights also First thing to do is do a continuity test or ohm the element and feel the element for any pits or bumps in the element manufacturer replacement part number is 8537057 on the element if you have any further questions message me back and please remember to rank how this opinion has helped it allows me tocontinue helping others in similar situations in the future. I look forward to if you have any further replies Thanks again Rick
Posted on May 04, 2011
  • 3247 Answers
SOURCE: Kenmore Dishwasher Mod# 66513753K602 control panel lites
If there is no other problem, that is the dishwasher completed the previous cycle successfully and the only issue is all lights on the panel flashing, it is likely a problem with one of the switches in the panel.
Turn off the power and back on. If no change then get to the control panel. You can refer to this diagram item 1.
Might have to replace it.
Posted on Jun 28, 2011
Daniel S
  • 4323 Answers
SOURCE: Mod..#17779 dishwasher problem: Lock On
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then try to reset the dishwasher control by pressing the NO HEAT DRY button and hold it for 15 seconds, if its still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 31, 2011
Heater won t stay lit
check gas pressure sounds like running out of gas meter might be too small
Jun 23, 2013 | Hayward Pool & Spa
My pilot light won't stay lite,replace thermopile and still doesn't stay lite.
Hi there.
Check for wiring errors, fix and tighten all wiring connections. Make sure that the gas pressure is correct.
Check the hi limit and gas valve, one of those component may be bad.
Regards.
Apr 18, 2013 | Cecilware FMP40 Deep Fryer
Climate control panel won't lite up & the fan keeps running
I would start looking for a used panel. Use a online used part search engine is my suggestion.
Oct 04, 2012 | 1996 Buick Park Avenue
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
I have a maytag dishwasher theres a 3 second button to hold in order for it to start but it won't start it's stuck on 3 second lite
hold the heated dry button for till that light goes out. then try to start. it is a child lock that is on
Oct 08, 2011 | Maytag MDB7100AWB Dishwasher
Mod..#17779 dishwasher problem: Lock On lite will not go off so you can start the dishwasher. I push tyhe no-heatbdry, but still won't go off.
Hi
Daniel
Aug 31, 2011 | Kenmore Dishwashers
Clean lite is flashing
Jul 25, 2010 | Kenmore 24 in. 16014 Built-in Dishwasher
Dishwashers Logo
41 people viewed this question
Top Dishwashers Experts
Owen Barnes
