Question about GE Home Security
Can the old wireless touchpad (S4006) be programmed into a Simon XT?
This is the wireless pad used when ITI was the manufacturer. I can't seem to find programming instructions.
SOURCE: Programing 1st and 2nd numbers on the Simon XT home alarm
Try entering the programming mode with the dealer code, not the master. It's 4321 by default.
James
Posted on Feb 10, 2009
  • 80 Answers
SOURCE: Simon XT panel does not want to learn motion sensor
try learming the sensor in by removing the back and actavation the tamper switch of the unit. also make sure that the unit is not already learned into the unit and if all else falil default the panel and start over.
mj
Posted on Sep 07, 2009
  • 3 Answers
SOURCE: how do i program a keychain and the smoke dector
to program any new sensors first you must access the installer menu by opening the front cover and using the red buttons typing in the installers code,(4321) is the default code. once that is done press the add button, then the sensor/remote button, then trip sensor(keyfob by pressing both the lock and unlock buttons together until the system beeps) or (removing the smoke detector from the base until it beeps). Once the sensor has been learned it will say keychain remote, press the sensor/remote button repeatedly until it says the correct location, then press done. then enter group code 01 for the keyfob and 26 for the smoke detector. then done.
Posted on Sep 28, 2009
SOURCE: Simon 2 wont call a phone
I found this answer on the web. Should to work, I didn't test it. You need an RJ31X jack, that is where it is trying to dial out. The device shorts out the house line, and resets the line and automatically dials out on a clear line through the RJ31X (your six prong plug line. You can not use a CAT 5 plug or pass through, your need the shorting bar. There are screw terminals on the RJ31X, pins 4 & 5, is what you use with red and green wire of the phone wire. Plug in your six wire plug into the RJ31X and your panel. You should discover your phone dials out to your cell number.
There you have it, and now you know why it is not dialing you.
That smaller jack is for your house phones, not Ma Bell.
Now if you look at my Bio, you will discover I am a Power Quality Engineer specializing in surge suppression and lightning protection for burglar alarms, Fire Alarms, CCTV, and Gate Access. You may think I am trying to sell something, and yes I am, but very little profit if at all. I normally sell to dealers in volume. I make the RJ31XDSL Pacifier (or three stage surge suppression). $55.00 each and I will discount it to $35.00 if you choose to buy one. I also recommend that you use a PMM117 Power monitor/surge suppression plug device for your power. This will protect your burg panel from being damaged from under/over voltage plus impulses and surges. This device will cost $77.00, but I can discount it to $39.00 each. Both units are a good investment with your new tiny computer you installed called a burglar alarm. I understand not much respect by most end users for devices like this, but the first lightning strike will wish you had.
Posted on Feb 25, 2010
  • 74 Answers
SOURCE: Can I disable the low
You cannot disable the low battery detection on the Simon 3. - AlarmProfessor.net
Posted on Aug 23, 2010
Hello. there seems to be a beeping noise coming from the control box itself and it says to check status, but i'm afraid to push anything. thank you
Troubleshooting a GE Simon XT: Clear Errors and Alerts ...
? 3:06
https://www.youtube.com/watch?v=AtOCuthlsTo
Oct 3, 2011 - Uploaded by LiveWatch Security
Troubleshooting a GE Simon XT: Clear Errors and Alerts -Wireless Home Security ... Many times the Simon XT panel willbeep to indicate there is something ... How do you turn off the warning beep when you turn on alarm? I find it very useless and annoying. Can't seem to find a way to turn that feature off.
My Simon XT is beeping every 4 hours. How can I stop it ...
help.livewatch.com/.../20399861-My-Simon-XT-is-beeping-every-4-ho...
Aug 28, 2011 - If your panel has been beeping throughout the day and you want to turn off ... Scroll down on the Simon XT until you see "System Programming".Missing: control ‎hello ‎control ‎box
Jan 11, 2016 | GE Security Simon Xt Wireless Control...
Hi there, i have a Simon XT alarm system and i want to delete a sensor or reinstall it - i took it off the window when replacing them and now th system keeps bleeping to tell me it's been tampered
Try these 2 sites:
http://search.aol.com/aol/search?&s_qt=sb&q=Ge+simon+xt+service+manual&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
Jan 15, 2013 | GE Simon XT Wireless Home Security System
Will the sencors that are on 60-875 work on simon xt system
No,sorry they are totally differnce in system datas programming.
Nov 24, 2011 | GE Security Simon 3 Wireless Home Security...
Just bought a simon xt system and setting up the touchpad. the touchpad can arm the system but it won't disarm the system when I type in the code?
Note: The default master code is 1-2-3-4 when the security system is shipped from the factory. You should change your code after your system is installed. See Code options on page 26.
If you have already changed the default master code, press the numbers in for the correct code and press enter.
Barring a faulty system the correct code and then 'enter' should sub-disarm or disarm.
Aug 25, 2011 | GE Security Simon 3 Wireless Home Security...
mj
Jun 25, 2009 | GE Security Simon 3 Wireless Home Security...
James
Jan 29, 2009 | GE Security Simon 3 Wireless Home Security...
GE Simon XT Home Alarm
http://74.125.95.132/search?q=cache:MppF70E2ihQJ:stonealarm.com/images/SimonXTUsersManual.pdf+ge+simon+xt+users+installation+manual&cd=1&hl=en&ct=clnk&gl=us&client=firefox-a
john copy and past the likk for the installation and programing manual.
mj
Dec 30, 2008 | GE Security Simon 3 Wireless Home Security...
Home Security Logo
230 people viewed this question
Top GE Home Security Experts
Sean
Bill
Level 1 Expert
Electro Med Services...
Are you a GE Home Security Expert? Answer questions, earn points and help others
