Question about HP T2330 15.4" 250GB QP/w remote PC Notebook
Hp pavilion remote inserted wrongly and it is not coming out?
It is inserted in wrong way i.e. it has been bymistake inserted oppositely.it is stuck in between half the way.
waiting for a reply as early as possible.
How to insert batteries for new Jazz JDC77: _, +, and the end one???
They are almost always opposite. When inserting them into the unit, The first goes in with the pos or neg end in (whichever applies) the second will be the opposite to the first, and the third will be opposite of the second, etc. If you put them in wrong it won't hurt anything, (unless you leave them like that for a long time) it just won't work.
Feb 26, 2015 | Jazz Cameras
Stuck on toshiba logo screen.
Dear Branden,
Please remove the battery and wait for 30 sec, after that insert the battery back and turn on the machine
Regards,
Samy
Aug 10, 2014 | Toshiba SatelliteR C855D-S5900 Laptop...
I removed the brew group and it is now stuck in the remove position. I cannot replace it in the machine. The lever that says push is stuck in the pushed position
On the inner side of the brew group (The side opposite the hand grip) there is a small rectangular slider mechanism with a vertical tab that sticks out and a catch near the funnel where the ground coffee is deposited. This slider must be in the correct position in order for the brew group to be inserted properly. If this slider is in the upper position, push gently on the catch so that the slider slides downward about 5mm or 3/16 inch. (I am replying from memory - it is possible that the slider must be in the upper position to engage). This will realign the funnel slightly and release the thumb lever, allowing the brew group to be inserted.
Jul 27, 2014 | Saeco Odea Go
What is wrong with my Ipod 2? My son was waiting on a game to load and the screen went blank but it still lights up? It seems to be stuck on this screen. Can you help?
did you try to switch it of an then on?
Pressing the button on top of the screen on the left side for a few seconds till it says slide to switch of. Slide and wait till everything is dark (half a minute) Den switch on again, by pressing the same button sir again a few seconds. Wait again about half a minute.
May 22, 2014 | Apple iPod Touch 2 8GB 32GB 64GB Checkers...
I have samsung 3600i having problem of insert sim ...plz help as early as possible...await for ur reply...
Dear User,
Please try referring your manual and insert the SIM as per the guidelines, also before doing this keep the phone off for some time .
your may find it here too:
http://cellphonediagram.com/search/samsung-3600i-manual-download/
May 04, 2011 | Cell Phones
Disc goes half way in but pop back out need to know how to fix it
First, make sure there isn't already a disc in the Wii. Press the eject button and wait a few moments. Next, make sure you are inserting the disc in the proper direction. The "face" of the disc should go the opposite direction of the little rubber feet on the Wii (depending on if you have your Wii lying on it's side or on it's bottom).
Mar 02, 2011 | Nintendo Video Game Consoles & Games
I have a Wisperingtone Cannister 100 purchased in early 80sbeater bar won't turn...something may be stuck...how do I remove cover plate? Thanks.
Take the pwerhead off your vac.
Face the beater bar upwards toward you.
Remove 4 Philips screws.
Remove the plastic shroud from the bottom of pwerhead.
Carefully remove one end of the beater bar, (the end opposite to the belt)
Remove the belt end.
Now depending on your model... you should be able to remove both ends of the bar.
usually there is thread or carpet fiber wrap around the bar.
You mention the 80,s,which also tell me they had a copper fitting where the axle of the beater bar meet. Trying to relace the end pieces may be a task and a half... So purchase the whole unit from the manufacturer.
Have fun vaccuming
Jul 10, 2010 | Kenmore 23313 Whispertone Bagged Canister...
My gas pedel gets stuck half way down some times
The throttle position sensor is most likely bad or it just may be the throttle cable but I think it is the Throttle position sensor it is located near the throttle valve follow the throttle cable to the end this is where the throttle valve is and the Throttle position sensor is located near the throttle valve on the opposite side it will have a plug going to it and it is held on with two torx head screws purchase the tools and replace.
Nov 03, 2009 | 1998 Buick Century
Screen stays blank after starting
look for a tiny pinhole and insert a pin while powered up to reset
May 27, 2007 | Panasonic Palmcorder PV-DV203 Mini DV...
HP T2330 15.4" 250GB QP/w remote PC Notebook Logo
74 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
