Question about Whirlpool Washing Machines
Whirlpool awoe 9140 rear bearing
How to change the bearing on the drum
2 Suggested Answers
  • 6277 Answers
SOURCE: wANT TODO A QUICK SPIN
I think you could do with an user manual ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Posted on Mar 01, 2011
How do I remove the top of whirlpool awoe 9140 front loader washing machine?
there are 2 or 3 screws behind the top cover,but this wont get you to where the odor exists,its in between the inner and outer drum,you need to also remove the front cover including the door then remove the inner drum pulley and belt and then split the outer tub to clean out old detergent and fabric softener if you use this as this is where the smell is coming from
Jan 07, 2013 | Whirlpool Duet GHW9150P Front Load Washer
When on spin the drum bangs is there a burning AWO/D 4605 ser end 104
Sounds like its just out of balance, the feet(1 at each corner) should have threads so you can balance it better by unscrewing or screwing back in as needed. Place a level on top of washer and see how out of balance it is and what corners you need to raise
Sep 24, 2012 | Whirlpool Washing Machines
Whirlpool Awoe 1012 bearing
Check this link for spares and tips to replace: bearing replacement
Jul 05, 2012 | Whirlpool Washing Machines
WANT TODO A QUICK SPIN ONLY WITH A AWOE 9140
Good luck,
John C
Mar 01, 2011 | Whirlpool Washing Machines
AWO/D5556 NEEDS NEW BEARINGS DO I NEED SPECIAL TOOLS TO CHANGE THEM
no just a big hammer and some steel bars try to knock em out evenly take the oil seal off from inside the drum first then knock out the outer bearing from the inside out and last the inner bearing from the outside try not to miss with the hammer it hurts thankyou
Jan 23, 2011 | Whirlpool Washing Machines
Drum has sagged in front ,bad rollers or drum support? motor wont turn drum enless i kinda lift front of drum .i dont have the manuel.Dave
Hi and welcome to FixYa. I am Kelly. If you can provide me with a mmake and model number I can tell you exactly what parts to order and change including the source to correct the problem you describe.
These parts are in most cases are:
1. The drum bearing ring: (not always bad)
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Bearing-ring-for-front-support-item-number-AP2996731.aspx
2. The front drum (Replace)seal: http://www.appliancepartspros.com/part_details.aspx?part_id=3131525
3. The rear drum seal: (replace) http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Rear-drum-felt-seal-with-adhesive--red-thread--item-number-AP3094149.aspx
4. Roller kit and belt: (replace) http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Dryer-repair-kit--29-inch-large-capacity-models--item-number-AP3131942.aspx
These are the most common failures. I would recommend ordering and replacing all parts 2 - 4. Doing this will ensure your dryer will last for a long time trouble free. (tumbling)
See this manual for general help: (Important)
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794/$FILE/4322260.pdf
Thanks for choosing FixYa.
Kelly
Jul 29, 2010 | Dryers
When turning, loud grinding noise.
Can be a tensioner pulley with bad bearings or the rear drum bearing is shot. When the rear drum bearing goes bad, the drum drops slightly and starts rubbing and making all sorts of terrible noises. I would not run it like this as the pivot on the rear of the drum that rides in the bearing could be cutting into the support. Not a good thing.
Good Luck and hope this helps.
Mar 15, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore/Whirlpool 417.99170120 Laundry Center
5303281153 comlete rear bearing kit, should come complete with insrtuction's
Mar 10, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
272 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
