Question about Mitsubishi Heating & Cooling
I have had a Mitsubishi Mr. Slim MUZ-A24NA for three (3) years. I have been told that the electronic boards on the outside are bad because the unit outside does not work. Initially, I was told that one electronic board was bad and it would cost $570. Then the company replaced the board and realized that was not the board. Then they told me it was the other two boards and the cost to replace them was $1,117. I thought there were only two electronic boards on the outside unit. Are the electronic boards that expensive which equates to one third of the cost of the unit. Any recommendations?
  • 3 Answers
SOURCE: Mitsubishi Mr Slim mini split outdoor unit fan.
Check the capacitor. Rating must be within 90% of rated microfarads. If it is a dual capacitor test between C and FAN. Set your meter to read microfarads (uF).
Posted on Aug 14, 2009
micromatikal
  • 2777 Answers
SOURCE: after replacing circuit board in
It is possible that the new circuit board has a different remote code programmed into it. The other more obvious answer could be that the remote's batteries have failed? Or did you say it is receiving the remote's output but just not adjusting correctly? Does the remote have lights on it that indicate it is "broadcasting" the signal? It was definitely the exact same circuit board as the one you replaced?
Thanks
Tim
Posted on Sep 15, 2010
SOURCE: Replacement compressor for Mitsubishi Mr. Slim Air Conditioner
pls no overhauling repair no spare part avaliable for hermetic comp[ressor the right is to change it
Posted on May 02, 2009
SOURCE: Mr Slim Model PEH3VK no air in one zone.
The Zone controller needed replacing so I rang for a Serviceman
Posted on Jul 07, 2009
  • 88 Answers
SOURCE: How do your read the serial# of a MUY-A24NA unit ,
hi.right below the model number there is a number that has numbers...model is muy-a24na..this is a 2ton unit...serial is possible the other number...hope this helps you..michael doctor airr appl.repair...843-384-8474...call if need some advice...its free..good luck
Posted on Mar 27, 2010
Mr. Slim aint cool!
Unit short of refrigerant or outside condenser very dirty. Clean outside thoroughly and make sure there is plenty of warmth coming from it when working.
Jul 07, 2012 | Mitsubishi MSZ-D30NA Mr. Slim Wall Heat...
Outside unit do not run.Red light blink 6
That is a trouble code signalling that your unit needs service. It is time to call a professional for help!
Jul 13, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Mar 26, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr Slim unit "spits" water/dust mixture
some of those units are equipped with a condensat pump you could have a loose connection or a small crack in the line
Jul 08, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Copper condendsing lines are cold but the air is not cold
http://www.mrslim.com/UploadedFiles/Resource/MSZ-A24NA_Op_Manu_SG79Y961H03_12-29-08.pdf Try this web site for you manual. It's where I found it.
Jun 14, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Display E4 code then only normal air blow in the room
check your cap also you may have a bad condensor fan
Feb 21, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
142 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
