2007 Infiniti M35 Sedan Logo
A
Anonymous Posted on Apr 08, 2017
Infinit m35 navigation system cutting out
Navigation system gets lines on screen or gets several different screens at one time with lines. The radio freezes, bluetooth freezes can't turn the radio, a/c, bluetooth etc on or off. It all freezes until you turn the car off then when you start the car the screen is black and the only thing that works is the A/C but you can't turn the fan or temperature up or down. Sometimes turning the car off will start everything again or not. Sometimes you'll get lines across the screen like its going to work, turn the car off and back on and then it works. Infiniti changed out this system but is still is doing all of the above,
John Aman
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 50 Answers
  • Posted on Apr 08, 2017
John Aman
Expert
Level 2:
New Friend:
Greenhorn:
Answers
50
Questions
0
Helped
8994
Points
136
Without knowing too much about this particular unit, I'll make one suggestion. When it does work, see if you can find a reset option in your setup options.
4 Related Answers
Anonymous
  • 10 Answers
  • Posted on May 29, 2009
SOURCE: driver side window not working for g35 infinit coupe
This is a common problem on the G35. The window regulator/motor have most likely gone bad. I've also seen a case where the switch was the culprit. Try clicking the switch up repeatedly a few times and see if that does the trick.
Anonymous
  • 578 Answers
  • Posted on Sep 16, 2009
SOURCE: 2003 Q45 Electrical Problem: Radio/Navigation screen goes blank
YOU HAVE A MODULE PROBLEM THAT IS SHORTING OUT AND TRIGGERING ACCESSORIES CIRCUIT HAVE IT CHECK ''CAN SHORT CIRCUIT AND CAUSE FIRE''
Anonymous
  • Posted on Apr 09, 2010
SOURCE: pop up navigation screen
We also have a 2005 with the same problem. When the screen pops up, the upper limit is determined by the number of revolutions of the motor, not the actual position of the screen. Over time, this limit seems to go out of adjustment.
To "trick" the limit, while the screen is moving up, quickly press down or tap on the screen so it momentarily moves downward then resumes raising as soon as you let go of it. When done correctly, the screen should raise fully; if you hold it too long, the screen will retract. We have been using this method for over a year now, and it has never failed. Hope this helps.
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Feb 16, 2012
SOURCE: I shipped a 2006 infiniti M35 sport from the
You need a new battery, it is triggering the secuirty system lock out
2helpful
3answers
How do I get nav and radio screen to work it says theft lock
If your 2005 Cadillac STS is displaying "TheftLock" on the navigation and radio screen after replacing the battery, it means that the anti-theft system has been activated. Here are the steps you can take to unlock the system:
1. Turn the ignition key to the "On" position. Don't start the car, just turn the key to "On" position.
2. Wait for the "TheftLock" message to disappear from the navigation and radio screen. This may take up to 10 minutes.
3. Press and hold the "1" and "4" buttons on the radio simultaneously for several seconds until "000" appears on the screen.
4. Use the "TUNE" knob to enter the code that was provided with the vehicle's owner's manual. If you don't have the code, you will need to contact a Cadillac dealership or a certified mechanic to retrieve it for you.
5. Once you entered the correct code, press the "AM/FM" button to unlock the radio and navigation system.
If all doesn't work, it's time to contact a Cadillac dealership or a certified mechanic to help you sort it out.
Why would the radio/sat nav/climate screen shut down and start up randomly. When shut down scree goes blank and then returns to BMW screen
Oddly enough something similar recently happened to my 2009 650i recently purchased. The system would intermittently cut out and restart, turning on the radio even with another source selected or radio off. No idea if there is a short or software issue causing it, but it started when I put the navigation DVD in and tried to use it. Took the DVD out and restarted the system, problem hasn’t returned. I’ve read about others having similar issues with the navigation system causing the radio/idrive to cut out as well. It’s a long shot, but worth posting so others don’t spend money chasing a problem solved by using your smartphone instead of the car’s navigation.
How to convert from navigation to non navigation
Is it the Navigation unit in the trunk that has gone bad? Or has your display unit given up? You can find plenty of Navigation units and display screens on ebay.
If it's just the display you can purchase a replacement screen. Search 2000 acura tl navigation screen or Navigation Display on ebay. you'll find plenty of them there. The real fun is removing your old one, to replace with the new one you bought to fix the problem.
To remove and replace the screen, you need to remove everything below it first. Search youtube videos and you'll find some very detailed instructional videos on how to do it. It's not for the faint of heart, or the mechanically inept...
I've done it, and YES.... you need to removed all of that stuff, in that exact order, in order to be able to get to the two lower bolts that hold the screen in place. There is no short cut.
Helpfull hint... before you install your new replacement screen, be sure and write down the serial number of the unit, which is printed on the back side of the assembly. You just might need it some time in the future (like when you need it to retrieve a code from Acura USA, to make your radio and nav unit work after disconnecting the battery)
https://www.youtube.com/watch?feature=player_embedded&v=7PPyaN2fs30
If your screen is ok, but your nav unit is broken, you can buy one of those on eBay as well... a lot easier to install... open the trunk, remove two cables, and four screws, and replace.
Navigation screen on 2007 dodge laramie truck went blank
Yes -I would check the fuses first when any electrical problem happens -cheers Denny
2answers
2009 Jeep Wranger Navigation Radio Touch Screen
look into a radio repair shop or just get a after market radio installed at a audio store best buy-etc
Radio, Navigation system not working 2003 MDX touring
The Navigation system DVD has failed. You can order the load/play mechanism for it from China. (http://alibaba.com) This is where I found the replacement for my system.This is not a hard repair to make. Cost is between $60 and &120 for the part. Alpine and the dealer will want your first born to replace it.
5helpful
How do i change the clock on a sts 2008 cadillac w/navigation sys
Had the same problem...hit CONFIG...then Vehicle on the left side...when the Vehicle screen
shows all the info on languages....hold your finger on the clock in top right corner. The clock
adjust screen should appear. I could never get the clock adjust screen because I was just
touching the time...you have to keep your finger on it until the screen comes up. Hope this helps.
Gary
Virginia
17helpful
2answers
2006 REC navigation radio (screen goes blank)
The same thing happens with my 2005 Jeep.
Top Infiniti Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you an Infiniti Expert? Answer questions, earn points and help others
