Question about Epson STYLUS R350 Photo Printer
Installing fake ink for Epson R230
Does anyone know how to install fake ink catridges for Epson R230 ?
I never had any problem with my other Epson photo stylus printer in installing fake ink catridges, but got stuck with this R230. Can someone help please ? Thanks in advance.
  • eqra_compute May 02, 2009
    memory full
  • Rambamram May 11, 2010
    When you say Fake Ink...do you mean after market cartriges by 3rd party vendors that refile cartriges?
    if so...you may have an Epson cartrige with a chip that has not been reset. There are devices out now on the market to reset the on cartrige chip now which in some cases can be bought at the office supply store that you bought your 'Fake Ink'. The chip is used as a rough counter of how much ink is left in the cartridge. Most other brands of printers that have chips on their cartridges the chip is more of an Identifier and the printer keeps count of how much ink is used.
My Epson photo R230 printer memory full, eror my printer has beeb seen two red light signal everytime.
Posted on Oct 04, 2009
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
Have changed ink catridges but light still flashing
InkJet printers tend to do that. I am guessing the printer has problems reading the information from the cartridge built-in chips.
Try removing each and every cartridge and placing them back in the printer once again.
Mar 05, 2011 | Epson STYLUS R230 InkJet Photo Printer
I want to know the basic operating details for a P50, How to install ink cartridges etc. Trevor I can't express my needs any clearer. You no longer supply a manual book thus leaving the user at a...
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Overview&oid=60202&prodoid=58654761&category=Products
The above link is for the R220 Inkjet Photo Printer.
It is similar to the R230, I believe. It looks similar.
I seem to recall that the R220 and R230 were related closely. So, if you read over the manual for the R220, you probably will see parallels to the R230 which I could not find specifically listed on the U.S. Epson site.
Jan 19, 2011 | Epson STYLUS R230 InkJet Photo Printer
How to reset ink counter for a epson R230
The page counter cannot be set back to 0.
The ink levels on your computer is automatically checked and displayed through the Status Monitor
If any of the ink cartridges installed in the printer is broken, incompatible with the printer model, or improperly installed, EPSON Status Monitor 3 will not display an accurate calculation for the amount of ink remaining in any of the ink cartridges. Be sure to replace or reinstall any ink cartridge indicated by EPSON Status Monitor 3.
Sep 27, 2010 | Epson STYLUS R230 InkJet Photo Printer
Two red lights are blinking simultaneously...I check if there is any paper jam but i don't see anything. anyone can help me would be much appreciated.
first have you checked any clogged papers? have you checked ink cartridges if yes continue doing the following
Before run adjustment program or software resetter Epson Stylus Photo R220 and R230, set date setting in your computer to 12 January 2006. Appearance of adjustment program Epson stylus photo R220 and R230 like adjustment program for Epson C45. Your Epson Stylus Photo R220 and R230 must be installed correctly in your computer before using the software otherwise so this software resetter will not be used.
Here how to use the software
  • Download and extract downloaded software and run it.
  • Click accept button.
  • Set model name, port selection and destination setting and equal to your printer.
  • Click Maintenance Tab.
  • Check mark waste ink pad counter.
  • And the clear the protection counter (reset counter to zero)
  • Then click Ok, Ok
  • done
download link:
http://www.mediafire.com/?9njmgwlxqgj
Nov 10, 2009 | Epson STYLUS R230 InkJet Photo Printer
How can i solve my problem in my EPSON R230." this is the message that will display in my screen...: Parts inside your printer are at the end of their service life. and its ink and paper lights is...
If you are using NON epson ink catridges? This is most likely your problem. I would recommend that you use only Epson products for your Epson printer. These "made in China" inks can ruin printers fast. If you are using only epson cartridges and this is still the case? You may have worn your printer out.
Hope this helps
Sep 24, 2009 | Epson Stylus C86 InkJet Printer
My Epson Stylus R230 has both red lights blinking alternately do you know how i can fix this please??
You need to reset waste ink counter. Use SSC Utility or R230 Adjusment program. Find at indoreset.blogspot.com. Don't forget to replace waste ink pad, or just extend outlet pipe of head cleaning mech to outside bottle.
Aug 28, 2009 | Epson Stylus Photo R200 InkJet Printer
R230 Epson Printer
I cant print coz of my printer (R230 Epson Printer) blinking 2 red light. Printer dosnt ready. It say-Service required. how can I release this problem. Plz tell me.
Apr 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
Help me!
My printer is EPSON STLUS R230. It have a problem. The problem is "Service required for EPSON STYLUS R230". I wanted to solve this problem. Please point out me. How to solve that problem.
Dec 14, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson STYLUS R350 Photo Printer Logo
729 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
